    Controller for my larg format 3D printer
    2.1k
    • MrDuiundefined
      MrDui @bernardomattiucci
      Hello to you, fellow large format printer maker 😉
      @bernardomattiucci said in Controller for my larg format 3D printer:
      This plan should be calibrated every time the Z axis is zeroed, to do this I thought of controlling the 4 motors independently and using the (optical) limit switches, 1 for each motor, in order to have a fixed reference for each edge of the XY plane.
      Instead of this, I'd suggest you to use only one limit switch at the top of one of your Z axis corner and install a BL touch or any other probe you like somewhere on your tool head.
      The printer will first go to its home position, moving until it hits the endstop. Then it will go down until the Z probe hits the bed. Next step will be to probe each corner, near your leadscrews. After that, the printer will adjust the bed to make it leveled automatically.
      I only have 2 Z axis on my printer but that's how I did it, same principle for you there with 4 axis. It's much easier to do it this way.
      bernardomattiucciundefined 1 Reply Last reply Reply Quote 1
      • bernardomattiucciundefined
        bernardomattiucci @MrDui
        @MrDui
        Thanks for the suggestion, very interesting!
          bernardomattiucci
          Ok
          If I am not mistaken, then, I should take the following:
          1 Duet 3 Mainboard 6HC +
          1 Duet Toolboard +
          1 Duet PanelDue 7" +
          1 BLTouch
          Correct?
          • Vetiundefined
            Veti @bernardomattiucci
            1 Duet Toolboard +
            if you want 3 extruders, then you need 3 toolboards or 1 Duet_3_Expansion_board_3HC
            bernardomattiucciundefined 1 Reply Last reply Reply Quote 0
              bernardomattiucci @Veti
              @Veti
              at this moment i only need 1 extruder
              Thank you
              Bernardo
                You might also want to buy a Tool Distribution board. You can manage without it, but it make wiring easier when you add more extruders. If you don't use one, you will need add a CAN termination resistor, and provide a fuse in the VIN feed to the tool board. See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Connecting_CAN_FD_Bus_and_Power.
                  bernardomattiucci
                  Good morning,
                  is there the possibility of having the 4 motors of the Z axis of the "closed loop" type with 4 linear encoders mounted on the recirculating ball guides placed at the 4 edges of the XY plane?
                    Not yet, but we have a closed loop expansion board for Duet 3 under development.
                      bernardomattiucci
                      Ok, then I have to wait ^ _ ^
                      Thank you
                        bernardomattiucci
                        Good evening. I hope everything goes well with you.
                        For my part I completed the zero prototype of the printer I was assembling and I started some tests using, as electronics, Arduino Mega, with a Ramps 1.4, external TB6600 drivers (in reality they are TB67S109AFTG) for Axis X, Axis Y and Axis Z , all powered at 24 volts; while for the extruder I'm using the original DRV8825 mounted on the Ramps.
                        As you well know, the complexity is given by the presence of 4 motors for the Z axis. Currently these motors are connected in parallel, the 2 on the right on one driver and the 2 on the left on another driver.
                        The adjustment is currently done manually ... acting directly on the ball screws SFU1204.
                        The ideal, however, is to have an "independent" control of the 4 motors, to which I intend to add linear encoders mounted on the guides.
                        In the current configuration, the zeroing of the Z axis occurs at the bottom, with a sensor positioned at X0 Y0.
                        The vertical movement of the XY plane (the printing table is fixed) occurs regularly and as long as the speed is not excessive, all 4 motors move simultaneously and with precision.
                        Not wanting to spend too much and wanting to use a Duet2 wifi, what configuration do you recommend the most?
                        First test: https://www.youtube.com/watch?v=N0FEGJcm668
                        Last test: https://www.youtube.com/watch?v=Xsnecz19VRQ
                        EDIT:
                        Duet2 Wi-Fi or Duet2 Maestro
                        Duex2_2
                        PanelDue 7i
                        Questions:
                        1. Is it possible to control Nema17 motors with Encoders (linear or angular) through this card?
                        2. Axis X, Y, Z and Extruder, how should they be distributed on the 2 boards?
                        3. the Duet2 Maestro, can it be enough to control my printer?
                        Thanks
                        Bernardo
                          Encoders are not currently supported. Same situation as the last reply from DC42. So if encoders are a hard requirement you'd have to wait a bit longer yet.
                          The Maestro is no longer being produced and is being supplanted by the Duet 3 Mini 5+ which is coming in the new year.
                          Given your requirement of 4 Z drivers, X Y E I think your best bet is probably a Duet 2 + Duex 5. With all 4 Z drivers on the Duex.
                          Some would question whether encoders are really useful anyway given the fact when properly configured skipped steps are quite rare and stall detection for X Y is fairly reliable for when the print head gets caught up on the print causing it to skip.
                            bernardomattiucci
                            Good morning
                            Thanks for the reply
                            We arrived at the shopping list:
                            Duet2 Wi-fi
                            Duex5
                            PanelDue 7i
                            Do you need anything else to mount everything and make the printer work?
                            For example, the temperature sensors and the heater for the hotend, do they need some other additional card?
                            Thanks
                            Bernardo
                            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @bernardomattiucci
                              Genuine Duets comes with crimp and shell packs for the wiring. You'd need a crimping tool and wire obviously.
                              Standard NTC thermistors can connect directly to the board. PT100 and thermocouples require a their own specific daughterboards.
                                dc42 administrators @bernardomattiucci
                                Good morning
                                Duet2 Wi-fi
                                Duex5
                                PanelDue 7i
                                Thanks
                                Bernardo
                                If you still intend to use external drivers for the Z axis then you don't need the DueX5, you need the EBOB instead. Duet WiFi + EBOB will give you 5 internal drivers, plus 5 outputs for external drivers.
                                  bernardomattiucci @dc42
                                  @dc42 said in Controller for my larg format 3D printer:
                                  I prefer, on this printer that uses nema17, to use the Duet2 wi-fi + DueX5 internal drivers
                                  In the future, on the bigger and more powerful one (nema23), I will evaluate the Duet3.
                                  auto_awesome
                                  Forse cercavi: Preferisco, su questa stampante che usa nema 17, usare i driver interni della Duet2 wi-fi + DueX5 In futuro, su quella più grossa e potente (nema23), valuterò la Duet3. grazie
                                  175 / 5000
                                  Risultati della traduzione
                                  thanks
                                    bernardomattiucci
                                    We have finally come to the end.
                                    We bought the electronics (from the Italian dealer) and it arrived yesterday morning.
                                    Before moving on to the assembly, however, I wanted to create a wiring diagram of the connections, to be sure there are no surprises.
                                    I would like to know from you if it is correct or if there is any error.
                                    Then I have questions:
                                    1. 12 volt 30 Amp or 24 volt 15 Amp power supply?
                                    2. Is it possible to install the electronics and relative display on a "console" external to the printer and connected to it with a cable of about 2 meters? I mean ... can the length of the connections affect the correct operation of the printer?
                                    Thank you
                                    Bernard
                                    • fcwiltundefined
                                      fcwilt
                                      Just for your information it is perfectly feasible to have multiple Z endstops.
                                      On my printer I have 3 Z steppers each with their own endstop.
                                      When homing using the endstops the firmware runs each Z stepper until it's associated endstop is activated.
                                      BUT I also have a Z probe which I can (and do) use with Auto Bed Leveling (ABL) to insure the bed is level as possible.
                                      Now it may be that I have the Z probe configured wrong but I can home Z much faster using the endstops than I can if I configure things to home Z with the Z probe.
                                      • fcwiltundefined
                                        fcwilt
                                        I forgot to mention that with firmware v3.2.0 there is a problem with multiple endstops that occurs under certain circumstances.
                                        I use v3.1.1 and it works just fine.
                                        fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                          bernardomattiucci @fcwilt
                                          @fcwilt
                                          Thanks so much.
                                          Beautiful ... 4 Z limit switches, at the moment, are ideal.
                                          I have to connect them to the E2, E3, E4 and E5 inputs of the Duex5, right?
                                          Correct?
                                          • fcwiltundefined
                                            fcwilt @fcwilt
                                            @fcwilt said in Controller for my larg format 3D printer:
                                            I also forgot to mention that the cause of the problem with v3.2.0 has been found and a fix is being devised.
