    Firmware list
    Firmware installation
    • pabomanundefined
      paboman
      Hi there,
      my last installed firmware on the duet2 is 2.03 beta 3.
      Where can i find a list of all the available firmwares ? github is somehow tricky to me
      Is the latest firmware (3.2) still compatible with my duet (not the duet3) ?
      thx 🙂
        2.05.1 is the most recent RRF2 version. 3.1.1 is the current stable release of RRF3.
        You can update directly to 2.05.1 if you want to stay on RRF2
        you should be able to upload the 2.05.1 zip file, as is, don't extract it, straight to the /sys folder. It should detect and update the firmware and web interface and reboot.
        Then if you wanted to update to RRF3, do the same for the 3.0 and 3.1.1 zip files.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
        That should get you up to date and then you can upload a config file set zip file you get from the configurator https://configtool.reprapfirmware.org/Start
        Then if you still have some issues we can tackle them then. It will be easier once you're on modern firmware.
        pabomanundefined 1 Reply Last reply Reply Quote 1
        • alankilianundefined
          alankilian
          Here's a list of the releases.
          Click the "Assets" tab to see all the binaries.
          There are Duet2 binaries for all the 3.2 releases.
          • pabomanundefined
            paboman @Phaedrux
            @Phaedrux said in Firmware list:
            thx!
            my question was if my duet ethernet is compatible with the 3.x series firmwares, I understand that it is compatible.
            Can you confirm please ?
            • pabomanundefined
              paboman @alankilian
              @alankilian said in Firmware list:
              thx !
                Yes it is compatible.
                • pabomanundefined
                  paboman
                  many thx !
