    M587 unsupported command
    2.3k
    • elmoretundefined
      elmoret
      All of the firmware versions can support Z-homing, they wouldn't be very good firmware if that wasn't the case!
      All of the firmware versions can support Z-homing with either a Z-endstop or a Z-probe.
      If you are having trouble with z-homing, that indicates that either the endstop is not wired/functioning properly, or the board is not configured properly. Please start a new thread and attach images of the endstop wiring, and upload all of the .g files on the SD card (http://www.pastebin.com works well for this).
      As for the wifi, I don't expect it will work without the DuetWebControl file being properly updated. Best to review the firmware updating instructions and retry that.
      • fcwiltundefined
        fcwilt
        @brian:
        Damn, with this version, the home z doesnt work. home all, homes x and y but not z. The very reason i installed v 1.18.2 Now i'm back where is started. No wifi and no home z.
        Why type of printer do you have?
        Can you use the web "control panel" to move on the z axis?
        • brianundefined
          brian
          My endstops are wired correctly! They were working, but my wifi was not, so i upgraded to v 1.19beta6 after installing the z probe so cant know if its configured correctly or not. I will try to get the config.g file configured as it was before and test the endstops, as well as post them here.
          My biggest concern at the moment is the M587 command being unsupported. Yes i can move the all axis with the move command in paneldue. As well as homex and homey icons on the panel.
          I will manually move the z axis and attempt a print later after work today and see how that works. My printer is an kickstarter project out of Australia, a clone of the Stacker. Not a good printer overall but have been printing for exactly one year and made a lot of upgrades.
          • fcwiltundefined
            fcwilt
            Given that 1.19 is a beta it's to be expected that there can be issues.
            Any particular reason you stopped using 1.18?
            • Dougal1957undefined
              Dougal1957
              Brian what type of printer is it Delta/CoreXY/std cartesian etc it may also help if you post your full set of Config files for us to see.
              The problems you seem to be having are all down to Config's etc
              Doug
              • elmoretundefined
                elmoret
                @brian:
                M587 is a new command as of 1.19, if it isn't working that means the firmware wasn't updated fully.
                • brianundefined
                  brian
                  @fcwilt:
                  Because it wasnt connecting to the web control.
                  • brianundefined
                    brian
                    @CaLviNx:
                    @brian:
                    I am a member of another forum, we all have the same printer. It uses the rumba board which many of us are not satisfied with. They have been following my progress with the duet to see if they should get that or another controller. So far at least one is opting to get the smoothie board rather than the duet. Others will follow that path if i dont get this working. Just saying.
                    So let me get this clear. Are you saying Others are basing their buying choice on the progress (or lack thereof) on one person who might or might not be doing things in the correct manner. Sorry but that's Akin to trying to charge a gun with committing murder…. And it also comes across as a very thinly veiled threat.
                    In that forum we all have had numerous issues with the printer, not software, and we all want each other to success, have been supportive of things that worked and cautioned on things that didnt. I want to succeed with this board and post good results so the others will be tempted to pay the higher price for the duet rather than some cheaper board that may not do much better than the original. Sorry if that came across as a threat, at any rate probably an inappropriate statement.
                    • brianundefined
                      brian
                      Calvinx, thanks for your advise, will do as you say and post results. In past attempts i get as far as the SetNetwork macro and it reports M587 command unsupported.
                      • fcwiltundefined
                        fcwilt
                        @brian:
                        Do you mean you could not connect to the printer using a browser to access the printer web control pages?
                        • brianundefined
                          brian
                          Calvinx, it worked! first try. I dont get it, but thanks man. I will run some tests to see if endstops work and repost.
                          • brianundefined
                            brian
                            So at the moment i cant homez, however, the z axis will stop at 0 during the move command and
                            i can print, and the z axis will work at expected during the print.
                            I will post the config file and the homez file tomorrow.
                            Thanks again for the help.
                            • brianundefined
                              brian
                              @fcwilt:
                              @brian:
                              No, i couldnt connect to the printer web control page via wifi from my pc. But happy to say its working now.
                              • fcwiltundefined
                                fcwilt
                                @brian:
                                @fcwilt:
                                @brian:
                                Glad to hear it is now working.
                                Just FYI 1.18 works fine too in that regard if you find that 1.19 beta has any other show stoppers.
                                • Whitewolfundefined
                                  Whitewolf
                                  Yeah 1.18 is the stable build, i suspect there was something else causing an issue. I would advise a word of caution using a beta firmware as an example for others who are weighing the pros and cons of a Duet
