Unable to set Z offset with PINDA probe
1.1k
    CarbonVirus
    Hello all,
    Installed a PINDA probe and I'm experiencing major issues with setting the z-offset; I set the offset with G10 P0 X0 Y0 Z4 and after probing the z-axis I see that it reports the z-axis as positive 4mm when I tell it to go to 0mm with G1 Z0. When I attempt to jog up past 4mm it does nothing; jogging with any settings results in the printer refusing to go past the point the probe reported as 0mm...
    I've removed the z-axis minima value from my config.g file, and I'm at a loss for figuring out how to get this to work.
    Please see my config.g and homez.g.
    undefined 1 Reply Last reply 4 Dec 2020, 17:14 Reply Quote 0
      Veti
      the offset is set with G31 not G10
        BoA @CarbonVirus
        @CarbonVirus
        1. Restore axis minima
        2. Set tool Z offset to 0 as pointed by @Veti in G10
        3. Configure z probe properly:
          G31 P500 X<x probe offset> Y<y probe offset> Z<trigger height>
        As a start point You can set Z trigger height for pinda at 0mm
        And follow this:
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          Veti
          your thermistor config is incorrect. find the correct beta value in your thermistor documentation.
            CarbonVirus
            Alright, I updated the G10/G31 commands as instructed and still cannot get the printer to jog negatively past 0mm.
            Here's my updated config.g.
            As for the thermistor config, that is what the reprap auto config tool gave me; if it's wrong, I am unsure what to update.
            undefined undefined 2 Replies Last reply 4 Dec 2020, 18:12 Reply Quote 0
              BoA @CarbonVirus
              @CarbonVirus Normally You should not be able to jog Z below 0 (or z min actually) - because normally this would crash nozzle into the bed.
              If at Z=0 nozzle is not touching the table that means You still did not follow calibration guide.
              Also Z trigger height in G31 - 12mm... how did You manage to get 12mm? This is well outside of pinda probe range.
              And... unless You have pinda somehow integrated with nozzle probe x and y offset can not be 0.0 0.0
                Can you please send M122 and M98 P"config.g" and post the results?
                Also please post homeall.g
                Remove this from your homez as it belongs in config.g
                M574 Z1 S2 ; Set endstops controlled by probe
                M558 P5 C"^zprobe.in" I1 H0.7 F1000 T6000 A20 S0.005 ; PINDA
                Your homez is setup to use an endstop homing move and not a probing move, which means your probe settings aren't being applied at all.
                G1 H1 Z-1000 F500 ; move 1000mm, stopping at the endstop
                That should be removed and replaced by
                G90 ; absolute position
                G1 X150 Y150 ; move probe to center of bed
                G30 ; use probe to find Z0
                The same would likely need to change in your homeall.
                G31 P500 X0 Y0 Z12 ; set z-probe offset height
                Is your trigger height really 12mm? Use the test and calibrate link from BoA above to find it.
                  Veti @CarbonVirus
                  @CarbonVirus said in Unable to set Z offset with PINDA probe:
                  4138 is the default and wrong for your thermistor. what thermistor did you buy?
                  undefined 1 Reply Last reply 4 Dec 2020, 21:06 Reply Quote 0
                    CarbonVirus
                    alright, I've updated the z-probe offset information, updated the homeall.g/homez.g file, ran through the z-probe calibration process outlined on the above link, and updated the config.g file; still after homing, the z-axis raises the bed only to the trigger height of the sensor; it refuses to go negative past the trigger height.
                      CarbonVirus @Veti
                      @Veti Currently have the following 24v bed with integrated thermistor; according to the comments it has a NTC 100k 3950B thermistor.
                      undefined 1 Reply Last reply 5 Dec 2020, 04:04 Reply Quote 0
                        This is a corexy with a moving bed, correct?
                        Z+ should move the bed up towards the nozzle and Z- should move the bed down away from the nozzle, correct? Flip that. Z- to the nozzle, and Z+ away from nozzle.
                        What exactly do you mean by "negative past the trigger height?"
                        undefined undefined 2 Replies Last reply 4 Dec 2020, 21:12 Reply Quote 0
                          Your new trigger height in G13 Z is Z-0.490. That would mean the probe is only triggering when the nozzle is pressing into the surface of the bed. That seems unlikely.
                            Also, can you copy and paste your configs into the post window itself? paste bin is complaining about me viewing so many pastes so quickly.
                              CarbonVirus @Phaedrux
                              @Phaedrux Apologies, I'm quite shite at explaining the situation...
                              It is a Core X/Y, and positive should move the bed down away from the gantry I believe (jogging positive results in the bed descending).
                              Here's the process resulting in failure:
                              • Home X + Y
                              • Home Z (with updated homing code provided above)
                              • Send gantry to x150, y150
                              • Send gantry to z0
                              • Observe nozzle is still ~4mm away from print bed
                              • Observe this distance is right where the PINDA sensor triggers
                              • Cannot raise bed (send negative movement commands) without disabling axis endstops (M564 S0)
                                CarbonVirus
                                config.g
                                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:16 GMT-0400 (Eastern Daylight Time)
                                M550 P"CarbonCube" ; set printer name
                                M669 K1 ; select CoreXY mode
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                M569 P1 S0 ; physical drive 1 goes forwards
                                M569 P3 S0 ; physical drive 3 goes forwards
                                M92 X160.00 Y160.00 Z800.00 E418.60 ; set steps per mm
                                M566 X1800.00 Y1800.00 Z400.00 E4000.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X12000.00 Y12000.00 Z2000.00 E120000.00 ; set maximum speeds (mm/min)
                                M201 X1000.00 Y1000.00 Z400.00 E2000.00 ; set accelerations (mm/s^2)
                                M906 X1450 Y1450 Z1450 E1450 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; set idle timeout
                                M208 S1 X0 Y0 Z0 ; set axis minima
                                M208 S0 X300 Y300 Z300 ; set axis maxima
                                M574 X1 S4 ; configure sensorless endstop for low end on X
                                M574 Y1 S4 ; configure sensorless endstop for low end on Y
                                M558 P5 C"^zprobe.in" I1 H0.7 F1000 T6000 A20 S0.005; PINDA
                                G31 P500 X30 Y-20 Z-0.490 ; set z-probe offset height
                                M557 X100:200 Y100:200 P2 ; define mesh grid
                                T0 ; select first tool
                                homeall.g
                                ; homeall.g
                                ; called to home all axes
                                G91 ; relative positioning
                                ; set motors to homing settings
                                M400 ; make sure everything has stopped before we make changes
                                M574 X1 Y1 S4 ; set endstops to use motor stall
                                M913 X30 Y30 ; drop motor current to 20%
                                M915 X Y S1 F0 H400 R0 ; set sensitivity , do nothing when stall, unfiltered
                                ; home x
                                G1 H1 X-1000 F4000 ; move 1000mm, stopping at the endstop
                                ; home y
                                G1 H1 Y-1000 F4000 ; move 1000mm, stopping at the endstop
                                ; home z
                                G90 ; absolute positioning
                                G1 X150 Y150 F6000 ; go to first probe point
                                G30 ; use probe to find Z 0
                                G1 Z10 F6000 ; lift Z relative to current position
                                ; set motors to print settings
                                M400 ; make sure everything has stopped before we reset the motor current
                                M913 X100 Y100 ; motor current back to 100%
                                G1 x10 y10 F6000 ; move x/y relative to current position
                                homez.g
                                ; homez.g
                                ; called to home the Z axis
                                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:17 GMT-0400 (Eastern Daylight Time)
                                  Phaedrux Moderator @Phaedrux
                                  @Phaedrux said in Unable to set Z offset with PINDA probe:
                                  Sorry. My mistake there.
                                    Yes. That is correct. Sorry for the confusion.
                                    I think this is because of your odd trigger height.
                                    Send gantry to z0
                                    What your G31 Z-0.4 trigger height is saying, is that when you send G30 to probe the bed, when the probe triggers the nozzle is at -0.4mm inside the surface of the bed. You can't send a negative value after that because it already thinks you're touching the bed.
                                    If your nozzle is still far away from the bed at that point, you need to redo the trigger height calibration because something went wrong.
                                      CarbonVirus
                                      alright, achieved proper z-offset with following configs
                                      config.g
                                      G31 P500 X30 Y-20 Z2.75 ; set z-probe offset height
                                      homez.g
                                      ; homez.g
                                      I think the stem of the entire issue was the incorrect homing command (using the endstop style command instead of a probe G30); still need to determine what could be wrong with my thermistor 😕
                                      Thank you very much @Phaedrux for the assistance; I got all turned about when messing with the offset/axis limit/homing commands and your assistance was quite helpful (as well as all others who chimed in)!
                                      undefined 1 Reply Last reply 4 Dec 2020, 22:13 Reply Quote 1
                                        Phaedrux Moderator @CarbonVirus
                                        Do you mean the pinda thermistor?
                                        undefined 1 Reply Last reply 4 Dec 2020, 22:25 Reply Quote 0
                                          @Phaedrux
                                          I believe @Veti was indicating the default thermistor my bed uses based off the reprap auto configuration tool is wrong. I wasn't planning on using the PINDA thermistor as I only ever print with the bed at 60c and plan to do the mesh grid probing at that temp so there shouldn't be variance, correct?
                                          Reading up on the PINDA temp compensation was rather perplexing TBH.
                                          5 out of 24
