Unable to set Z offset with PINDA probe
@CarbonVirus Normally You should not be able to jog Z below 0 (or z min actually) - because normally this would crash nozzle into the bed.
If at Z=0 nozzle is not touching the table that means You still did not follow calibration guide.
Also Z trigger height in G31 - 12mm... how did You manage to get 12mm? This is well outside of pinda probe range.
And... unless You have pinda somehow integrated with nozzle probe x and y offset can not be 0.0 0.0
Can you please send M122 and M98 P"config.g" and post the results?
Also please post homeall.g
Remove this from your homez as it belongs in config.g
M574 Z1 S2 ; Set endstops controlled by probe M558 P5 C"^zprobe.in" I1 H0.7 F1000 T6000 A20 S0.005 ; PINDA
Your homez is setup to use an endstop homing move and not a probing move, which means your probe settings aren't being applied at all.
G1 H1 Z-1000 F500 ; move 1000mm, stopping at the endstop
That should be removed and replaced by
G90 ; absolute position G1 X150 Y150 ; move probe to center of bed G30 ; use probe to find Z0
The same would likely need to change in your homeall.
G31 P500 X0 Y0 Z12 ; set z-probe offset height
Is your trigger height really 12mm? Use the test and calibrate link from BoA above to find it.
@CarbonVirus said in Unable to set Z offset with PINDA probe:
As for the thermistor config, that is what the reprap auto config tool gave me; if it's wrong, I am unsure what to update.
4138 is the default and wrong for your thermistor. what thermistor did you buy?
alright, I've updated the z-probe offset information, updated the homeall.g/homez.g file, ran through the z-probe calibration process outlined on the above link, and updated the config.g file; still after homing, the z-axis raises the bed only to the trigger height of the sensor; it refuses to go negative past the trigger height.
@Veti Currently have the following 24v bed with integrated thermistor; according to the comments it has a NTC 100k 3950B thermistor.
This is a corexy with a moving bed, correct?
Z+ should move the bed up towards the nozzle and Z- should move the bed down away from the nozzle, correct?Flip that. Z- to the nozzle, and Z+ away from nozzle.What exactly do you mean by "negative past the trigger height?"
Your new trigger height in G13 Z is Z-0.490. That would mean the probe is only triggering when the nozzle is pressing into the surface of the bed. That seems unlikely.
Also, can you copy and paste your configs into the post window itself? paste bin is complaining about me viewing so many pastes so quickly.
@Phaedrux Apologies, I'm quite shite at explaining the situation...
It is a Core X/Y, and positive should move the bed down away from the gantry I believe (jogging positive results in the bed descending).Here's the process resulting in failure:
- Home X + Y
- Home Z (with updated homing code provided above)
- Send gantry to x150, y150
- Send gantry to z0
- Observe nozzle is still ~4mm away from print bed
- Observe this distance is right where the PINDA sensor triggers
- Cannot raise bed (send negative movement commands) without disabling axis endstops (M564 S0)
config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:16 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CarbonCube" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z800.00 E418.60 ; set steps per mm M566 X1800.00 Y1800.00 Z400.00 E4000.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z2000.00 E120000.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z400.00 E2000.00 ; set accelerations (mm/s^2) M906 X1450 Y1450 Z1450 E1450 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; set idle timeout ; Axis Limits M208 S1 X0 Y0 Z0 ; set axis minima M208 S0 X300 Y300 Z300 ; set axis maxima ; Endstops M574 X1 S4 ; configure sensorless endstop for low end on X M574 Y1 S4 ; configure sensorless endstop for low end on Y ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P5 C"^zprobe.in" I1 H0.7 F1000 T6000 A20 S0.005; PINDA G31 P500 X30 Y-20 Z-0.490 ; set z-probe offset height M557 X100:200 Y100:200 P2 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:16 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position ; set motors to homing settings M400 ; make sure everything has stopped before we make changes M574 X1 Y1 S4 ; set endstops to use motor stall M913 X30 Y30 ; drop motor current to 20% M915 X Y S1 F0 H400 R0 ; set sensitivity , do nothing when stall, unfiltered ; home x G1 H1 X-1000 F4000 ; move 1000mm, stopping at the endstop ; home y G1 H1 Y-1000 F4000 ; move 1000mm, stopping at the endstop ; home z G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X150 Y150 F6000 ; go to first probe point G30 ; use probe to find Z 0 G91 ; relative positioning G1 Z10 F6000 ; lift Z relative to current position G90 ; absolute positioning ; set motors to print settings M400 ; make sure everything has stopped before we reset the motor current M913 X100 Y100 ; motor current back to 100% G91 ; relative positioning G1 Z10 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 x10 y10 F6000 ; move x/y relative to current position
homez.g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:17 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X150 Y150 F6000 ; go to first probe point G30 ; use probe to find Z 0 G91 ; relative positioning G1 Z10 F6000 ; lift Z relative to current position G90 ; absolute positioning
@Phaedrux said in Unable to set Z offset with PINDA probe:
Z+ should move the bed up towards the nozzle and Z- should move the bed down away from the nozzle, correct?Flip that. Z- to the nozzle, and Z+ away from nozzle.Sorry. My mistake there.
Yes. That is correct. Sorry for the confusion.
I think this is because of your odd trigger height.
Send gantry to z0
Observe nozzle is still ~4mm away from print bedWhat your G31 Z-0.4 trigger height is saying, is that when you send G30 to probe the bed, when the probe triggers the nozzle is at -0.4mm inside the surface of the bed. You can't send a negative value after that because it already thinks you're touching the bed.
If your nozzle is still far away from the bed at that point, you need to redo the trigger height calibration because something went wrong.
alright, achieved proper z-offset with following configs
config.g; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 17:19:16 GMT-0400 (Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CarbonCube" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z800.00 E418.60 ; set steps per mm M566 X1800.00 Y1800.00 Z400.00 E4000.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z2000.00 E120000.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z400.00 E2000.00 ; set accelerations (mm/s^2) M906 X1450 Y1450 Z1450 E1450 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; set idle timeout ; Axis Limits M208 S1 X0 Y0 Z0 ; set axis minima M208 S0 X300 Y300 Z300 ; set axis maxima ; Endstops M574 X1 S4 ; configure sensorless endstop for low end on X M574 Y1 S4 ; configure sensorless endstop for low end on Y ; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P5 C"^zprobe.in" I1 H0.7 F1000 T6000 A20 S0.005; PINDA G31 P500 X30 Y-20 Z2.75 ; set z-probe offset height M557 X100:200 Y100:200 P2 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
homez.g
I think the stem of the entire issue was the incorrect homing command (using the endstop style command instead of a probe G30); still need to determine what could be wrong with my thermistor
Thank you very much @Phaedrux for the assistance; I got all turned about when messing with the offset/axis limit/homing commands and your assistance was quite helpful (as well as all others who chimed in)! -
Do you mean the pinda thermistor?
@Phaedrux
I believe @Veti was indicating the default thermistor my bed uses based off the reprap auto configuration tool is wrong. I wasn't planning on using the PINDA thermistor as I only ever print with the bed at 60c and plan to do the mesh grid probing at that temp so there shouldn't be variance, correct?
Reading up on the PINDA temp compensation was rather perplexing TBH. -
Right. Do you know what kind of thermistor you have? What kind of printer is it? did it come with the hotend? What is it?
It's a fully custom printer I've been tinkering with 2+ years; Core X/Y with a single Z axis drive and a 20x20 cube chassis.
The thermistor is the standard thermistor included with the E3D V6 Lite. The bed thermistor is outlined in the above comments. -
So the B value for your bed is 3950
this one has 2 values B4725 C7.06e-8
Excellent, I've updated the thermistor values and am running a test print ATM; thank you for the assistance @Veti
