Problem with circles and diagonal moves
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 12 2020 20:53:52 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Voron 2.4 350mm^3" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 P192.168.178.164 S1 ; enable network and acquire dynamic address via DHCP M554 P192.168.178.1 ; gateway M553 P255.255.255.0 ; subnet mask M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives for XY M569 P0.4 S1 ; A motor (X) M569 P0.5 S1 ; B motor (Y) ; Drives for Z M569 P0.0 S1 ; Front left M569 P0.1 S0 ; Back left M569 P0.2 S1 ; Back right M569 P0.3 S0 ; Front right ; Drive for extruder M569 P1.0 S1 ; physical drive 1.0 goes forwards M572 D0 S0.1 ; pressure advance ; Drive mappings M584 X0.4 Y0.5 Z0.0:0.1:0.2:0.3 E1.0 ; set drive mapping ; General drive config like speeds, accel, jerk, etc M350 X16 Y16 Z16:16:16:16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E410.00 ; set steps per mm M566 X40.00 Y40.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X15000.00 Y15000.00 Z2100.00 E1200 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z350.00 E250.00 ; set accelerations (mm/s^2) M906 X1500 Y1500 Z1500 E850 I70 ; set motor currents (mA) and motor idle factor in per cent M84 S3600 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z-0.85 S1 ; set axis minima M208 X346 Y355 Z320 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!io1.in" ; X Hall effect endstop M574 Y2 S1 P"!io2.in" ; Y Hall effect endstop M574 Z1 S1 P"io3.in" ; Z microswitch endstop ; Z-Probe M558 P8 C"!io4.in" T18000 F1200 H5 A5 S0.01 B0 R0.2 ; set Z probe type to switch and the dive height + speeds M671 X-46:-46:396:396 Y0:418:418:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) G31 P500 X0 Y23 Z5.235 ; set Z probe trigger value, offset and trigger height <######################## M557 X20:320 Y30:330 S100:100 ; define mesh grid (for G32) - überschreibt Grideinstellungen in DOW nach Neustart ; Hotbed M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenovo" ; Thermistor R3950 M308 S2 P"temp2" Y"thermistor" T100000 B3950 A"Heizbett direkt" ; Schraub-Thermistor am Heizbett R3400 M950 H0 C"out0" T2 ; Heater M307 H0 A261.9 C549.2 D0.7 V24.0 B0 ; Heater 0 model: gain 261.9, time constant 549.2, dead time 0.7, max PWM 1.00, calibration voltage 24.0, mode PID M140 H0 ; Map heated bed to heater 0 - Keenovo 220V, 750W M143 H0 P1 T0 A2 S125 C0 ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 110°C. Use Heater monitor 1 for it M143 H0 P2 T0 A1 S135 C0 ; Shut off (A1) bed heater (H0) if pad sensor (T0) exceeds 120°C. Use Heater monitor 2 for it ; Hotend M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.196220e-7 A"Mosquito" ; Thermistor R-Wert eicht die Temp R3950 M950 H1 C"out1" T1 ; Heater M307 H1 A593.7 C180.4 D7.6 V24.0 B0 ; Heater 1 model: gain 593.7, time constant 180.4, dead time 7.6, max PWM 1.00, calibration voltage 24.0, mode PID M143 H1 S350 ; Sets temperature limit for extruder - Mosquito ; DHT22 sensor ;M308 S10 P"0.spi.cs0" Y"dht22" A"Chamber Temp" ; Temperature (connected to cs0 port on the temp daughterboard slot ;M308 S11 P"S10.1" Y"dhthumidity" A"Chamber Hum[%]" ; Humidity ; Main fans M950 F0 C"1.out6" Q100 ; Part cooling fan M106 P0 S0 B0.2 H-1 ; Default off; booststart for 0.2s; thermostatic control off M950 F1 C"out7" Q500 ; Hotend cooling fan M106 P1 S1 H1 T45 ; Default on; thermistatic control on above 45C ; Aux fans (option to control daughter board fans based on main board temp sensor coming in RRF3.3, for now has to be manual) M950 F2 C"1.out7" Q500 ; Electronics compartment fan 1 M106 P2 S1.0 H-1 ; Default on; thermostatic control off M950 F3 C"1.out8" Q500 ; Electronics compartment fan 2 M106 P3 S1.0 H-1 ; Default on; thermostatic control off M950 F6 C"out8" Q500 ; Noctua exhaust filter fan M106 P6 S0 H-1 ; Default off ; LED-Stripes ;M950 F5 C"out9" Q500 ; LED-Streifen rechts --> derzeit nicht installiert ;M106 P5 S1.0 H-1 ; Default on; thermostatic control off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M575 P1 S1 B57600 ; enable support for PanelDue M501 M292 -
It's better with higher speed...
i assume you are on firmware 3.1.1?
how did you generate the circle movement commands?
can you try and enable a different jerk Policy (M566 P1)
The extra 16s on Z there are unnecessary.
Can you post a sample of gcode file that produces the problem?
Do the motors behave the same with the belt disconnected?
@Phaedrux said in Problem with circles and diagonal moves:
How is it correct?
@medicusdkfz how is what correct?
This is a video with various speeds with the circle movement...
It's a lot better now but not perfect.
This is the new M566:
M566 P1 X1000.00 Y1000.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) -
@medicusdkfz do you have mesh compensation active? Increase your z jerk to 60
I have isolated the noisy problem. It's kind of a resonance frequency with biggest peak at 67 mm/s and a smaller peak at 133 mm/s in x and y direction.
I've started a macro with various speeds from 1000 mm/min up to 10000 for x and y. Mesh is not active at this time. Only for real printing purposes.
Regardless, still a good idea to raise your Z jerk if you intend to use mesh compensation.
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Troubleshooting
the biggest problem lies in the stepper motor setting. I reduced the acceleration and increased the maximal speed and currents a little bit. Now it fine. The noise is almost gone!
Thank you,
Pierre -
Can you link the specs of the motor?
What did you end up with for settings?
Might helps someone in the future. -
Yes, a little bit later. While I'm printing, I have the strange issue, that my web interface lost the connection to the Duet3 6HC. After some minutes my Duet reboots.
@medicusdkfz
please post the M122 after the reboot -
For the moment I cut the web connection to the board while printing.
After connection lost and reboot of the Duet3 6HC while printing (!), here is my M122...
Therefore normally I close any web connection in every browser to the 6HC! That is the only way to prevent this issue... I'm running the RRF3 3.2-beta4!M122
RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
Board ID: 08DJM-956L2-G43S8-6J1DJ-3SN6M-9S0YG
Used output buffers: 1 of 40 (12 max)
Static ram: 123212
Dynamic ram: 168800 of which 488 recycled
Never used RAM 99692, free system stack 180 words
Tasks: NETWORK(ready,189) ETHERNET(blocked,110) HEAT(blocked,297) CanReceiv(blocked,898) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,51) MAIN(running,1127) IDLE(ready,19)
Owned mutexes:
Last reset 00:13:05 ago, cause: software
Last software reset at 2020-12-06 11:17, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 99652, slot 2
Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0444a804 BFAR 0x00000016 SP 0x2040b928 Task ETHE
Stack: 20423888 00000000 ffffffff 00000002 204098a4 0040fdf9 004109a2 61000000 204098ec 20423830 2042384c 0040fdf9 2041df64 2041b3cc 2041de94 0040c7a9 20411574 00000000 00000001 2041b3cc 204098a4 00000002 00000002 2041b3cc 20409872 a4b2a8c0 2040ba34
Error status: 0x00
MCU temperature: min 36.5, current 36.7, max 39.5
Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
Driver 0: position 0, standstill, reads 12266, writes 14 timeouts 0, SG min/max 0/0
Driver 1: position 0, standstill, reads 12266, writes 14 timeouts 0, SG min/max 0/0
Driver 2: position 0, standstill, reads 12267, writes 14 timeouts 0, SG min/max 0/0
Driver 3: position 0, standstill, reads 12268, writes 14 timeouts 0, SG min/max 0/0
Driver 4: position 0, standstill, reads 12269, writes 14 timeouts 0, SG min/max 0/0
Driver 5: position 0, standstill, reads 12270, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2020-12-06 11:30:20
Slowest loop: 5.04ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.6ms, write time 0.0ms, max retries 0
=== MainDDARing ===
Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 6.42ms; fastest: 0.03ms
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 0 0 0
Socket states: 2 2 2 2 2 0 0 0
=== CAN ===
Messages queued 3151, send timeouts 0, received 3152, lost 0, longest wait 10ms for reply type 6027, free buffers 47
Thank you,
Pierre - Ethernet -
Can you try beta 4.1?
I have but there are more problems. My 3HC don't wake up after a soft reboot. Only when I switch off the power and power on, the 3HC is there...
I changed back to 3.1.1... -
Did you update the firmware on the 3hc as well?
Of course, I did...
