why my web status always starting ?
392
    huai3895
    3.2.0-beta4.1
    the status should show ''normal'' or ''busy'', but it just show ''Starting''now, and mabe that make my "trigger2.g" cant work by m581
      More detail please.
      Where are you seeing "starting" ?
      Can you confirm your firmware version with M122?
      Have you updated the DWC as well?
      If this is with a PanelDue can you confirm you have up to date firmware there as well?
      undefined 1 Reply Last reply 5 Dec 2020, 03:02 Reply Quote 0
        huai3895 @Phaedrux
        @Phaedrux
        M122
        RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
        Board ID: 08DJM-956BA-NA3TN-6J9D6-3S86M-TVB6T
        Used output buffers: 1 of 40 (13 max)
        I have update my duet pi to beta, and i dont have panedue.
          post your config files
          undefined 1 Reply Last reply 5 Dec 2020, 05:59 Reply Quote 0
            huai3895 @Phaedrux
            This post is deleted!
              Send M98 P"config.g" and report the results
              undefined 2 Replies Last reply 5 Dec 2020, 06:08 Reply Quote 0
                huai3895 @Phaedrux
                @Phaedrux
                  huai3895 @Phaedrux
                  @Phaedrux
                  I can see what you mean mabe. I'll check the config line by line
                    Did it work with firmware 3.1.1 and DWC 3.1.1?
                    Are you using a raspberry pi as well?
                    Can you connect via USB and try M122 and the M98 command?
                    undefined 3 Replies Last reply 5 Dec 2020, 06:24 Reply Quote 0
                      huai3895 @Phaedrux
                      @Phaedrux
                      yes ,it work with 3.1.1,
                      yes,im using a raspberry pi(duet pi)
                      And i will try usb,but it may take time
                        huai3895 @Phaedrux
                        @Phaedrux Found the reason,if i del m501,everything normal,because i dont have configoverride at sys/.
                          huai3895 @Phaedrux
                          @Phaedrux
                          Thanks every much,m98 p"config" give me inspire.
                          3 out of 12
