    Det 3d 6hc using expansion 1XD, stepper not moving
    • dkraja42undefined
      dkraja42
      ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 11:43:55 GMT+0530 (India Standard Time)
      M550 P"Duet 3" ; set printer name
      ;M569 P0.0 S1 ; physical drive 0.0 goes forwards
      ;M569 P0.1 S1 ; physical drive 0.1 goes forwards
      ;M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards (Extruder)
      M569 P40.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (X-axis)
      M569 P41.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Y1-axis)
      M569 P42.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Y2-axis)
      M569 P43.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Z1-axis)
      M569 P44.0 S1 R0 T5:5:5:5 ; physical drive 0.0 goes forwards (Z2-axis)
      M584 X40.0 Y41.0:42.0 Z43.0:44.0 E0.0 ; set drive mapping
      ;M584 X40.0 Y41.0 Z43.0 E0.0 ; set drive mapping (single X,Y,Z & E)
      M350 X11 Y1 Z1 E16 I1 ; configure microstepping with interpolation
      M92 X3200.00 Y3200.00 Z3200.00 E90.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
      M906 X7000 Y7000 Z7000 E2000 ; set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      M208 X230 Y230 Z230 S0 ; set axis maxima
      M574 X1 S1 P"!^40.io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
      M574 Y1 S1 P"!^41.io1.in" ; configure active-high endstop for low end on Y1 via pin !^io1.in
      M574 Y1 S1 P"!^42.io1.in" ; configure active-high endstop for low end on Y2 via pin !^io1.in
      M574 Z1 S1 P"!^43.io1.in" ; configure active-high endstop for low end on Z1 via pin !^io1.in
      M574 Z1 S1 P"!^44.io1.in" ; configure active-high endstop for low end on Z2 via pin !^io1.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:220 Y15:220 S20 ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B5000 ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"out2" T0 ; create bed heater output on out2 and map it to sensor 0
      M308 S1 P"temp0" Y"thermistor" T100000 B5000 ; configure sensor 1 as thermistor on pin temp0
      M143 H1 S230 ; set temperature limit for heater 1 to 230C
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
      ; Custom settings
      M575 P1 S1 B57600
      M570 H0 P999 S240
      M552 S1
      M552 192.168.0.120
      dkraja42undefined 1 Reply Last reply Reply Quote 0
      • dkraja42undefined
        dkraja42 @dkraja42
        @dkraja42 showing error on stepper driver :
        Er 03: Position error; The position deviation counter exceeds the set value
        • JoergS5undefined
          JoergS5 @dkraja42
          @dkraja42 0.0 is undefined and microstepping 11 is unusual:
          but only 0.3 defined.
          don't know whether 11 is valid, I expect not.
            Can you send M122, M122 B1, and M98 P"config.g" and post the results?
              As @Phaedrux says, but also post the results of sending M122 B40, M122 B41, M122 B42, M122 B43 and M122 B44.
