    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • lui2004undefined
      lui2004 @Phaedrux
      @Phaedrux
      in the slicer i have 1.5 at 40mm
      M207 S1.5 F2400 Z0.075 do i need Z ?
        Z is for Z hop. Leave it at 0 for starters. But if you ever want to use Z hop that's where you set the distance.
        lui2004undefined 1 Reply Last reply Reply Quote 0
        • lui2004undefined
          lui2004 @Phaedrux
          @Phaedrux ok thanks a lot
          i still printing the retraction stl
          • lui2004undefined
            lui2004
            @Phaedrux @Veti printing the two towers for retraction test no filament comes ot the nozzle
            • Vetiundefined
              Veti
              what changes did you make since the last print where it worked
              • lui2004undefined
                lui2004
                This post is deleted!
                • lui2004undefined
                  lui2004 @Veti
                  @Veti nothing special, finetuning temptower,retract settings
                  all seems fine but with the M207 i have problems
                  • Vetiundefined
                    Veti
                    so without m207 its extruding again?
                    • lui2004undefined
                      lui2004 @Veti
                      @Veti yes with normal retractin from slicer all fine
                      with M207 no extrusion , it will print only the base and not the 2 towers for retracting test
                      Edit:
                      now i have see what cause that no filament come out.
                      after retract its during to much time to reload the filament
                      i dont know which parameter can set to solve it
                      • lui2004undefined
                        lui2004
                        @Phaedrux @Veti
                        i forgot to check '' use realtive E distances '' in the printer Settings, now it works.
                        do i need to go higher with my retract settings ?
                        at this moment i got this settings for firmware retractions:
                        M207 P0 S1.5 R0 F2100 T2100 Z0 ; Firmware Retraction
                        or i need to print the retractions stl and post pictures ?
                        thanks
                        • Vetiundefined
                          Veti
                          start the print. if its stringing increase the retraction setting in the console while printing.
                          • lui2004undefined
                            lui2004 @Veti
                            @Veti ok
                            with which one i begin ? retraction Speed,distance ... ?
                            • Vetiundefined
                              Veti @lui2004
                              distance
                              • lui2004undefined
                                lui2004 @Veti
                                @Veti ok
                                right now i am at:
                                M98 P"0:/macros/Tuning/Report Current Retraction Settings.g"
                                Tool 0 retract/reprime: length 0.25/0.25mm, speed 35.0/35.0mm/sec, Z hop 0.00m
                                without stringing,is it good ?
                                • Vetiundefined
                                  Veti
                                  you have to decide that by yourself if you are happy with the result.
                                  • lui2004undefined
                                    lui2004 @Veti
                                    @Veti
                                    it looks great !
                                    but one question why with slicer retraction i have 1.5mm and with firmware retract i have 0.25mm ?
                                    the distance are good ,now i will check with speed right ?
                                    • Vetiundefined
                                      Veti
                                      yes you can, but 35mm/sec is a good speed for retraction
                                      lui2004undefined 2 Replies Last reply Reply Quote 0
                                      • lui2004undefined
                                        lui2004 @Veti
                                        @Veti
                                        ok i will leave so !
                                        i will reprint the benchy to check if its ok
                                        • lui2004undefined
                                          lui2004 @Veti
                                          @Veti
                                          i want print the benchy but the first layer adhesion is terrible what i can do now ? before it was all good
                                          • Vetiundefined
                                            Veti
                                            can you post a picture of the result?
