Tony,
So my concerns with a "one size fits all approach" (and these are just my personal observations) are that we'll have a whole bunch of G and M codes that aren't appropriate for a 3D printer. I've had instances of DWC reporting unsupported commands like M1070. Nobody has as yet come up with an explanation of how or why this happens but the commands are definitely not in the gcode file. This isn't a real issue because no action is taken. But if a command existed that was supported but only for CNC machines, and it somehow crept into a 3D gcode file, by some weird means like the above, or by strange slicer behaviour or by "fat fingered" post slice editing and it got acted on, it could have some weird, unpredictable or detrimental effect. That's why personally I think additive 3D printer firmware should be separate from subtractive CNC 3D printer firmware. (It's at this point that someone will jump on and say they want to build a machine that is both an additive 3D printer as well as a subtractive CNC machine - hell lets throw in laser cutter as well)
As a general observation (and again this is just me) I believe that Duet firmware is already in danger of becoming too bloated. I appreciate that the intention is to give every user what they ask for, but for new users "coming in from the cold" we are already seeing comments about how complicated it all is.
Just my rambling thoughts…...........
I've only seen a few lines of CNC milling code, but it seems, the "." dot has several different meanings there.
1st. The classic decimal dot [c]X1.234[/c]
2nd The subcommand [c]G19.1[/c]
3rd The end of line
[c]G1
Xnnn Ynnn
Xmmm Ymmm
Xmnm Ynmn.
G0[/c]
I'm concerned these different meanings will slow down the gcode parser, especially when integrated in 3D printer fw.
The last thing I want is reduced printquality ( not the right term actually ) for many, just to make some CNC guys happy.It seems the parser needs a rewriting anyway to be able to read several G-commands in one line and properly deal with subcommands a.s.o.
Tony,
Smoothieboard has both not sure how it is implemented, whether it uses different firmware for both functions but I do know that it is used for both CNC and 3D printers. Yes I am one of the people who would like to see the board support both additive and subtraction manufacturing just by switching out tools on my current printer…. Many of the retail printers do something similar, in fact I just linked to a Delta that accomplishes this through magnetic tool heads.
But the functionality can be used to go much further than just swappable tools, Project Escher was designed not to be strictly a 3D printer, but multiple gantries with different tools can work together on a single project. While I understand your concerns on feature creep, Duet is the only opensource board that I am aware of that supports expansion boards and is capable of doing more advanced use cases (after some firmware changes).
Maybe to address your concerns there might be a way to create modules for those who wish to expand the Duets functionality so we are not limited to XYZ printers but instead allowed the freedom to pick from a set of features that apply to our particular application.
3rd The end of line
[c]G1
Xnnn Ynnn
Xmmm Ymmm
Xmnm Ynmn.
G0[/c]
As in my reply to the last person, there should be no reason like many other code bases before it that functionality could not be modular. I find it hard to follow logic that says we shouldnt do it because its not something I am interested in, otherwise why do we have Delta vs Cartesan vs corexy configurations….. I have no interest in Delta printers so why should that code be added in? see my point there.
Modular code bases allow for exactly these kinds of concerns, think of it as plugins for your (insert favorite web application name here), being opensource and being that anyone can compile I do not see a reason to exclude any features when if you wanted just 3d printer functionality and some other guy wanted just CNC functionality and some other guy wanted both CNC and 3D and laser for project X then there is no reason he shouldnt be able to compile the modules to do so.
Changing the gcode parser is not like adding another 3D-printer kinematic. ( AFAIK, they are all based on the same parser )
I'd be happy, when the parser can do all_in_one without compromising, but I have my concernes.Although RRF is opensource, most of the users do not compile their own builds. As a RADDS owner I tried to follow the "how to make your own build" paper from RRF github, but failed to understand the paper. ( Seems written from an insider for insiders )
David and Tony are concerned about the additional support required for two RRF branches, but guess what happens, when everyone builds his own FW, trying to taylor the HW-resources for their needs. -
I don't think changing the gcode parser will be difficult. From what I have seen there are just two additional features we need to support:
1. Multiple GCode commands or multiple MCode commands on one line. The NIST standard has restrictions on what commands can be put on the same line, but I'll probably allow almost any combination of GCodes or any combination of MCodes, with just a few exceptions, and execute them in left to right order.
2. GCode command numbers can have decimal points in them e.g. G92.1
If it is necessary to interpret gcode commands differently according to whether the firmware is driving a 3D printer or a CNC machine, then I'll probably implement codes M451, M452 and M452 as defined at http://reprap.org/wiki/G-code#M291:_Display_message_and_optionally_wait_for_response.
David and Tony are concerned about the additional support required for two RRF branches, but guess what happens, when everyone builds his own FW, trying to taylor the HW-resources for their needs.Forgive me if I am wrong here because I have not yet dug into the firmware side of things (on my list to do) but if we were to implement a pluggable module to keep things clean, is there something in particular preventing an online compiler that pulls directly from github and downloads the resulting binaries based on the users selection? a tool similar to what there is now for downloading configuration.
I would even be willing to develop it if need be. The concerns on this subject are valid just seems to me there are workable solutions to those concerns
All of that is certainly possible, and thanks for your offer. However, our policy with RRF is that a single compiled binary should meet the needs of all users, except those with very specialised requirements, or those who want to make their own firmware modifications ("one binary to rule them all"). Other firmwares require some users to recompile the firmware to enable or disable functionality, either because they don't have sufficient load-time configurability, or because the hardware doesn't have enough flash or (more usually) enough RAM to support all of the functions available. In RRF we are only at 75% flash capacity even allowing for the 64Kb kept in reserve to help with flashing new firmware via the web interface - and we could reduce that 64Kb if we needed to. On the Duet WiFi and Duet Ethernet, we have spare RAM as well, and I haven't tried to economise on RAM usage yet (e.g. I use a 8K SD card write buffer, because it gives slightly better file upload speeds than 4K does).
The other issue with using pluggable modules is that they only work well if new functionality can be implemented using the existing interfaces. In fact this is rarely the case. Almost every new features I add cuts across module boundaries and requires changes to the module interfaces.
One particular situation in which a pluggable module might be useful is for supporting additional kinematics. I have refactored the kinematics code extensively in RRF 1.19 to make it easier to support new kinematics. But this still assumes that new kinematics can be implemented using a fixed set of interfaces. In practice, each kinematics appears to have its own specialised requirements. I still haven't worked out an interface for controlling homing behaviour that will work for all of Cartesian, Linear Delta, CoreXY and Scara kinematics. One option is to move much of the homing code into the kinematics classes; but that defeats the objective of making it straightforward to add classes for new kinematics.
So my preference is to make the GCode parsing changes that CNC applications need - and support this extended parsing on 3D printers too unless there is a good reason not to - and to add support for CNC-specific gcodes. Most of this is not likely to happen before firmware version 1.21 because version 1.20 will be mostly about changing RRF for the Duet WiFi and Duet Ethernet to use a RTOS kernel.
There's one minor thing I want to mention early:
It seems that tool diameter, spindle speed, and feed rate have a "golden ratio". At least Fusion360 always changes the spindle speed, when I change tools or reduce feed rate.
My point is, when the planner has to cut feed rate because max. feed rate is lower than gcode numbers, the planner has to reduce spindle RPM as well.
That's only my observation, please feel free to correct me. -
….......................It seems that tool diameter, spindle speed, and feed rate have a "golden ratio". ............................
That's very true in machining terms. There is always an optimum cutting speed, and by that I mean material removal speed. Either too slow, or too fast can result in the tool overheating due to friction, whereby it first goes blue then becomes brittle and breaks. (At least that was the case way back in the 60s when I was an apprentice).
Looking forward to firmware 1.22
After rewriting several mach3-gcode files generated by Fusion360, I saw that there is a "brackets"-editor that allows us to write our own gcode-generator. That way, the firmware-branch for CNC would be much easier to write. It could even stay untouched. Just a few commands would be missing.
I'm wondering, if other CAM-software allow custom-machine gcode generator implementation, too? If so, which one is the most common between Duet/RRF users?
Here's the fusion360_mach3 code generator: ( sorry, I don't know how to attach files )
/** Copyright (C) 2012-2017 by Autodesk, Inc. All rights reserved. Mach3Mill post processor configuration. $Revision: 41432 76c1b5f6cafe0274f1c22e1d96e245a2f903b3b1 $ $Date: 2017-05-17 22:55:14 $ FORKID {AE2102AB-B86A-4aa7-8E9B-F0B6935D4E9F} */ description = "Generic Mach3Mill"; vendor = "Artsoft"; vendorUrl = "http://www.machsupport.com"; legal = "Copyright (C) 2012-2017 by Autodesk, Inc."; certificationLevel = 2; minimumRevision = 24000; longDescription = "Generic milling post for Mach3."; extension = "gco"; setCodePage("ascii"); capabilities = CAPABILITY_MILLING; tolerance = spatial(0.002, MM); minimumChordLength = spatial(0.01, MM); minimumCircularRadius = spatial(0.01, MM); maximumCircularRadius = spatial(1000, MM); minimumCircularSweep = toRad(0.01); maximumCircularSweep = toRad(180); allowHelicalMoves = true; allowedCircularPlanes = undefined; // allow any circular motion // user-defined properties properties = { writeMachine: true, // write machine writeTools: true, // writes the tools useG28: false, // disable to avoid G28 output for safe machine retracts - when disabled you must manually ensure safe retracts useM6: true, // disable to avoid M6 output - preload is also disabled when M6 is disabled preloadTool: false, // preloads next tool on tool change if any showSequenceNumbers: false, // show sequence numbers sequenceNumberStart: 10, // first sequence number sequenceNumberIncrement: 5, // increment for sequence numbers optionalStop: true, // optional stop separateWordsWithSpace: true, // specifies that the words should be separated with a white space useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words. dwellInSeconds: true // specifies the unit for dwelling: true:seconds and false:milliseconds. }; var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-"; var mapCoolantTable = new Table( [9, 8, 7], {initial:COOLANT_OFF, force:true}, "Invalid coolant mode" ); var nFormat = createFormat({prefix:"N", decimals:0}); var gFormat = createFormat({prefix:"G", decimals:1}); var mFormat = createFormat({prefix:"M", decimals:0}); var hFormat = createFormat({prefix:"H", decimals:0}); var pFormat = createFormat({prefix:"P", decimals:(unit == MM ? 3 : 4), scale:0.5}); var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true}); var rFormat = xyzFormat; // radius var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG}); var feedFormat = createFormat({decimals:(unit == MM ? 0 : 1), forceDecimal:true}); var inverseTimeFormat = createFormat({decimals:4, forceDecimal:true}); var toolFormat = createFormat({decimals:0}); var rpmFormat = createFormat({decimals:0}); var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999 var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999 var taperFormat = createFormat({decimals:1, scale:DEG}); var xOutput = createVariable({prefix:"X"}, xyzFormat); var yOutput = createVariable({prefix:"Y"}, xyzFormat); var zOutput = createVariable({prefix:"Z"}, xyzFormat); var aOutput = createVariable({prefix:"A"}, abcFormat); var bOutput = createVariable({prefix:"B"}, abcFormat); var cOutput = createVariable({prefix:"C"}, abcFormat); var feedOutput = createVariable({prefix:"F"}, feedFormat); var inverseTimeOutput = createVariable({prefix:"F", force:true}, inverseTimeFormat); var sOutput = createVariable({prefix:"S", force:true}, rpmFormat); var pOutput = createVariable({}, pFormat); // circular output var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat); var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat); var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat); var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ... var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19 var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91 var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G93-94 var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21 var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ... var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99 var WARNING_WORK_OFFSET = 0; // collected state var sequenceNumber; var currentWorkOffset; /** Writes the specified block. */ function writeBlock() { if (properties.showSequenceNumbers) { writeWords2(nFormat.format(sequenceNumber % 100000), arguments); sequenceNumber += properties.sequenceNumberIncrement; } else { writeWords(arguments); } } /** Output a comment. */ function writeComment(text) { writeln("(" + filterText(String(text).toUpperCase(), permittedCommentChars) + ")"); } function onOpen() { if (properties.useRadius) { maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC } if (false) { var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], cyclic:true, preference:1}); machineConfiguration = new MachineConfiguration(aAxis); setMachineConfiguration(machineConfiguration); optimizeMachineAngles2(1); // map tip mode } if (!machineConfiguration.isMachineCoordinate(0)) { aOutput.disable(); } if (!machineConfiguration.isMachineCoordinate(1)) { bOutput.disable(); } if (!machineConfiguration.isMachineCoordinate(2)) { cOutput.disable(); } if (!properties.separateWordsWithSpace) { setWordSeparator(""); } sequenceNumber = properties.sequenceNumberStart; if (programName) { writeComment(programName); } if (programComment) { writeComment(programComment); } // dump machine configuration var vendor = machineConfiguration.getVendor(); var model = machineConfiguration.getModel(); var description = machineConfiguration.getDescription(); if (properties.writeMachine && (vendor || model || description)) { writeComment(localize("Machine")); if (vendor) { writeComment(" " + localize("vendor") + ": " + vendor); } if (model) { writeComment(" " + localize("model") + ": " + model); } if (description) { writeComment(" " + localize("description") + ": " + description); } } // dump tool information if (properties.writeTools) { var zRanges = {}; if (is3D()) { var numberOfSections = getNumberOfSections(); for (var i = 0; i < numberOfSections; ++i) { var section = getSection(i); var zRange = section.getGlobalZRange(); var tool = section.getTool(); if (zRanges[tool.number]) { zRanges[tool.number].expandToRange(zRange); } else { zRanges[tool.number] = zRange; } } } var tools = getToolTable(); if (tools.getNumberOfTools() > 0) { for (var i = 0; i < tools.getNumberOfTools(); ++i) { var tool = tools.getTool(i); var comment = "T" + toolFormat.format(tool.number) + " " + "D=" + xyzFormat.format(tool.diameter) + " " + localize("CR") + "=" + xyzFormat.format(tool.cornerRadius); if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) { comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg"); } if (zRanges[tool.number]) { comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum()); } comment += " - " + getToolTypeName(tool.type); writeComment(comment); } } } if (false) { // check for duplicate tool number for (var i = 0; i < getNumberOfSections(); ++i) { var sectioni = getSection(i); var tooli = sectioni.getTool(); for (var j = i + 1; j < getNumberOfSections(); ++j) { var sectionj = getSection(j); var toolj = sectionj.getTool(); if (tooli.number == toolj.number) { if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) || xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) || abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) || (tooli.numberOfFlutes != toolj.numberOfFlutes)) { error( subst( localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."), sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)), sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1)) ) ); return; } } } } } if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) { for (var i = 0; i < getNumberOfSections(); ++i) { if (getSection(i).workOffset > 0) { error(localize("Using multiple work offsets is not possible if the initial work offset is 0.")); return; } } } // absolute coordinates and feed per min writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gFormat.format(91.1), gFormat.format(40), gFormat.format(49), gPlaneModal.format(17)); switch (unit) { case IN: writeBlock(gUnitModal.format(20)); break; case MM: writeBlock(gUnitModal.format(21)); break; } } function onComment(message) { var comments = String(message).split(";"); for (comment in comments) { writeComment(comments[comment]); } } /** Force output of X, Y, and Z. */ function forceXYZ() { xOutput.reset(); yOutput.reset(); zOutput.reset(); } /** Force output of A, B, and C. */ function forceABC() { aOutput.reset(); bOutput.reset(); cOutput.reset(); } /** Force output of X, Y, Z, A, B, C, and F on next output. */ function forceAny() { forceXYZ(); forceABC(); feedOutput.reset(); } var currentWorkPlaneABC = undefined; function forceWorkPlane() { currentWorkPlaneABC = undefined; } function setWorkPlane(abc) { if (!machineConfiguration.isMultiAxisConfiguration()) { return; // ignore } if (!((currentWorkPlaneABC == undefined) || abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) || abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) || abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) { return; // no change } onCommand(COMMAND_UNLOCK_MULTI_AXIS); // NOTE: add retract here writeBlock( gMotionModal.format(0), conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)), conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)), conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z)) ); onCommand(COMMAND_LOCK_MULTI_AXIS); currentWorkPlaneABC = abc; } var closestABC = false; // choose closest machine angles var currentMachineABC; function getWorkPlaneMachineABC(workPlane) { var W = workPlane; // map to global frame var abc = machineConfiguration.getABC(W); if (closestABC) { if (currentMachineABC) { abc = machineConfiguration.remapToABC(abc, currentMachineABC); } else { abc = machineConfiguration.getPreferredABC(abc); } } else { abc = machineConfiguration.getPreferredABC(abc); } try { abc = machineConfiguration.remapABC(abc); currentMachineABC = abc; } catch (e) { error( localize("Machine angles not supported") + ":" + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x)) + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y)) + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z)) ); } var direction = machineConfiguration.getDirection(abc); if (!isSameDirection(direction, W.forward)) { error(localize("Orientation not supported.")); } if (!machineConfiguration.isABCSupported(abc)) { error( localize("Work plane is not supported") + ":" + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x)) + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y)) + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z)) ); } var tcp = true; if (tcp) { setRotation(W); // TCP mode } else { var O = machineConfiguration.getOrientation(abc); var R = machineConfiguration.getRemainingOrientation(abc, W); setRotation(R); } return abc; } function onSection() { var insertToolCall = isFirstSection() || currentSection.getForceToolChange && currentSection.getForceToolChange() || (tool.number != getPreviousSection().getTool().number); var retracted = false; // specifies that the tool has been retracted to the safe plane var newWorkOffset = isFirstSection() || (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes var newWorkPlane = isFirstSection() || !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()); if (insertToolCall || newWorkOffset || newWorkPlane) { if (properties.useG28) { // retract to safe plane retracted = true; writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(machineConfiguration.getRetractPlane())); // retract writeBlock(gAbsIncModal.format(90)); zOutput.reset(); } } writeln(""); if (hasParameter("operation-comment")) { var comment = getParameter("operation-comment"); if (comment) { writeComment(comment); } } if (insertToolCall) { forceWorkPlane(); onCommand(COMMAND_STOP_SPINDLE); onCommand(COMMAND_COOLANT_OFF); if (!isFirstSection() && properties.optionalStop) { onCommand(COMMAND_OPTIONAL_STOP); } if (tool.number > 256) { warning(localize("Tool number exceeds maximum value.")); } if (properties.useM6) { writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6)); } else { writeBlock("T" + toolFormat.format(tool.number)); } if (tool.comment) { writeComment(tool.comment); } var showToolZMin = false; if (showToolZMin) { if (is3D()) { var numberOfSections = getNumberOfSections(); var zRange = currentSection.getGlobalZRange(); var number = tool.number; for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) { var section = getSection(i); if (section.getTool().number != number) { break; } zRange.expandToRange(section.getGlobalZRange()); } writeComment(localize("ZMIN") + "=" + zRange.getMinimum()); } } if (properties.preloadTool && properties.useM6) { var nextTool = getNextTool(tool.number); if (nextTool) { writeBlock("T" + toolFormat.format(nextTool.number)); } else { // preload first tool var section = getSection(0); var firstToolNumber = section.getTool().number; if (tool.number != firstToolNumber) { writeBlock("T" + toolFormat.format(firstToolNumber)); } } } } if (insertToolCall || isFirstSection() || (rpmFormat.areDifferent(tool.spindleRPM, sOutput.getCurrent())) || (tool.clockwise != getPreviousSection().getTool().clockwise)) { if (tool.spindleRPM < 1) { error(localize("Spindle speed out of range.")); return; } if (tool.spindleRPM > 99999) { warning(localize("Spindle speed exceeds maximum value.")); } writeBlock( sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4) ); } // wcs if (insertToolCall) { // force work offset when changing tool currentWorkOffset = undefined; } var workOffset = currentSection.workOffset; if (workOffset == 0) { warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET); workOffset = 1; } if (workOffset > 0) { if (workOffset > 6) { var p = workOffset; // 1->... // G59 P1 is the same as G54 and so on if (p > 254) { error(localize("Work offset out of range.")); } else { if (workOffset != currentWorkOffset) { writeBlock(gFormat.format(59), "P" + p); // G59 P currentWorkOffset = workOffset; } } } else { if (workOffset != currentWorkOffset) { writeBlock(gFormat.format(53 + workOffset)); // G54->G59 currentWorkOffset = workOffset; } } } forceXYZ(); if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode // set working plane after datum shift var abc = new Vector(0, 0, 0); if (currentSection.isMultiAxis()) { forceWorkPlane(); cancelTransformation(); } else { abc = getWorkPlaneMachineABC(currentSection.workPlane); } setWorkPlane(abc); } else { // pure 3D var remaining = currentSection.workPlane; if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) { error(localize("Tool orientation is not supported.")); return; } setRotation(remaining); } // set coolant after we have positioned at Z { var c = mapCoolantTable.lookup(tool.coolant); if (c) { writeBlock(mFormat.format(c)); } else { warning(localize("Coolant not supported.")); } } forceAny(); gMotionModal.reset(); var initialPosition = getFramePosition(currentSection.getInitialPosition()); if (!retracted) { if (getCurrentPosition().z < initialPosition.z) { writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z)); } } if (insertToolCall || retracted) { var lengthOffset = tool.lengthOffset; if (lengthOffset > 256) { error(localize("Length offset out of range.")); return; } gMotionModal.reset(); writeBlock(gPlaneModal.format(17)); if (!machineConfiguration.isHeadConfiguration()) { writeBlock( gAbsIncModal.format(90), gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y) ); writeBlock(gMotionModal.format(0), gFormat.format(43), zOutput.format(initialPosition.z), hFormat.format(lengthOffset)); } else { writeBlock( gAbsIncModal.format(90), gMotionModal.format(0), gFormat.format(43), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y), zOutput.format(initialPosition.z), hFormat.format(lengthOffset) ); } } else { writeBlock( gAbsIncModal.format(90), gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y) ); } } function onDwell(seconds) { if (seconds > 99999.999) { warning(localize("Dwelling time is out of range.")); } if (properties.dwellInSeconds) { writeBlock(gFormat.format(4), "P" + secFormat.format(seconds)); } else { milliseconds = clamp(1, seconds * 1000, 99999999); writeBlock(gFormat.format(4), "P" + milliFormat.format(milliseconds)); } } function onSpindleSpeed(spindleSpeed) { writeBlock(sOutput.format(spindleSpeed)); } function onCycle() { writeBlock(gPlaneModal.format(17)); } function getCommonCycle(x, y, z, r) { forceXYZ(); return [xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + xyzFormat.format(r)]; } function onCyclePoint(x, y, z) { if (isFirstCyclePoint()) { repositionToCycleClearance(cycle, x, y, z); // return to initial Z which is clearance plane and set absolute mode var F = cycle.feedrate; var P = (cycle.dwell == 0) ? 0 : cycle.dwell; // in seconds switch (cycleType) { case "drilling": writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); break; case "counter-boring": if (P > 0) { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82), getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P), feedOutput.format(F) ); } else { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); } break; case "chip-breaking": // cycle.accumulatedDepth is ignored if (P > 0) { expandCyclePoint(x, y, z); } else { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73), getCommonCycle(x, y, z, cycle.retract), "Q" + xyzFormat.format(cycle.incrementalDepth), feedOutput.format(F) ); } break; case "deep-drilling": if (P > 0) { expandCyclePoint(x, y, z); } else { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83), getCommonCycle(x, y, z, cycle.retract), "Q" + xyzFormat.format(cycle.incrementalDepth), // conditional(P > 0, "P" + secFormat.format(P)), feedOutput.format(F) ); } break; case "tapping": if (tool.type == TOOL_TAP_LEFT_HAND) { expandCyclePoint(x, y, z); } else { if (!F) { F = tool.getTappingFeedrate(); } writeBlock(mFormat.format(29), sOutput.format(tool.spindleRPM)); writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); } break; case "left-tapping": expandCyclePoint(x, y, z); break; case "right-tapping": if (!F) { F = tool.getTappingFeedrate(); } writeBlock(mFormat.format(29), sOutput.format(tool.spindleRPM)); writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); break; case "fine-boring": writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76), getCommonCycle(x, y, z, cycle.retract), "I" + xyzFormat.format(cycle.shift), "J" + xyzFormat.format(0), "P" + secFormat.format(P), // "Q" + xyzFormat.format(cycle.shift), feedOutput.format(F) ); break; case "back-boring": var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0; var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0; var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0; writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(87), getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom), "I" + xyzFormat.format(cycle.shift), "J" + xyzFormat.format(0), "P" + secFormat.format(P), feedOutput.format(F) ); break; case "reaming": if (P > 0) { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89), getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P), feedOutput.format(F) ); } else { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); } break; case "stop-boring": writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86), getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P), feedOutput.format(F) ); break; case "manual-boring": writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(88), getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P), feedOutput.format(F) ); break; case "boring": if (P > 0) { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89), getCommonCycle(x, y, z, cycle.retract), "P" + secFormat.format(P), feedOutput.format(F) ); } else { writeBlock( gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85), getCommonCycle(x, y, z, cycle.retract), feedOutput.format(F) ); } break; default: expandCyclePoint(x, y, z); } } else { if (cycleExpanded) { expandCyclePoint(x, y, z); } else { writeBlock(xOutput.format(x), yOutput.format(y)); } } } function onCycleEnd() { if (!cycleExpanded) { writeBlock(gCycleModal.format(80)); zOutput.reset(); } } var pendingRadiusCompensation = -1; function onRadiusCompensation() { pendingRadiusCompensation = radiusCompensation; } function onRapid(_x, _y, _z) { var x = xOutput.format(_x); var y = yOutput.format(_y); var z = zOutput.format(_z); if (x || y || z) { if (pendingRadiusCompensation >= 0) { error(localize("Radius compensation mode cannot be changed at rapid traversal.")); return; } writeBlock(gMotionModal.format(0), x, y, z); feedOutput.reset(); } } function onLinear(_x, _y, _z, feed) { var x = xOutput.format(_x); var y = yOutput.format(_y); var z = zOutput.format(_z); var f = feedOutput.format(feed); if (x || y || z) { if (pendingRadiusCompensation >= 0) { pendingRadiusCompensation = -1; writeBlock(gPlaneModal.format(17)); switch (radiusCompensation) { case RADIUS_COMPENSATION_LEFT: pOutput.reset(); writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, f, pOutput.format(tool.diameter)); break; case RADIUS_COMPENSATION_RIGHT: pOutput.reset(); writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, f, pOutput.format(tool.diameter)); break; default: writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f); } } else { writeBlock(gMotionModal.format(1), x, y, z, f); } } else if (f) { if (getNextRecord().isMotion()) { // try not to output feed without motion feedOutput.reset(); // force feed on next line } else { writeBlock(gMotionModal.format(1), f); } } } function onRapid5D(_x, _y, _z, _a, _b, _c) { if (!currentSection.isOptimizedForMachine()) { error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath.")); return; } if (pendingRadiusCompensation >= 0) { error(localize("Radius compensation mode cannot be changed at rapid traversal.")); return; } var x = xOutput.format(_x); var y = yOutput.format(_y); var z = zOutput.format(_z); var a = aOutput.format(_a); var b = bOutput.format(_b); var c = cOutput.format(_c); writeBlock(gMotionModal.format(0), x, y, z, a, b, c); feedOutput.reset(); } function onLinear5D(_x, _y, _z, _a, _b, _c, feed) { if (!currentSection.isOptimizedForMachine()) { error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath.")); return; } if (pendingRadiusCompensation >= 0) { error(localize("Radius compensation cannot be activated/deactivated for 5-axis move.")); return; } var x = xOutput.format(_x); var y = yOutput.format(_y); var z = zOutput.format(_z); var a = aOutput.format(_a); var b = bOutput.format(_b); var c = cOutput.format(_c); // get feedrate number var f = {frn:0, fmode:0}; if (a || b || c) { f = getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed); } else { f.frn = feedOutput.format(feed); f.fmode = 94; } if (x || y || z || a || b || c) { writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), x, y, z, a, b, c, f.frn); } else if (f.frn) { if (getNextRecord().isMotion()) { // try not to output feed without motion feedOutput.reset(); // force feed on next line } else { writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), f.frn); } } } // Start of multi-axis feedrate logic /***** Be sure to add 'useInverseTime' to post properties if necessary. *****/ /***** 'inverseTimeOutput' must be defined. *****/ /***** 'headOffset' should be defined when a head rotary axis is defined. *****/ /***** The feedrate mode must be included in motion block output (linear, circular, etc. *****/ var dpmBPW = 0.1; // ratio of rotary accuracy to linear accuracy for DPM calculations var inverseTimeUnits = 1.0; // 1.0 = minutes, 60.0 = seconds var maxInverseTime = 999999.9999; // maximum value to output for Inverse Time feeds /** Calculate the multi-axis feedrate number. */ function getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed) { var f = {frn:0, fmode:0}; if (feed <= 0) { error(localize("Feedrate is less than or equal to 0.")); return f; } var length = getMoveLength(_x, _y, _z, _a, _b, _c); if (true) { // inverse time f.frn = inverseTimeOutput.format(getInverseTime(length[0], feed)); f.fmode = 93; feedOutput.reset(); } else { // degrees per minute f.frn = feedOutput.format(getFeedDPM(length, feed)); f.fmode = 94; } return f; } /** Calculate the DPM feedrate number. */ function getFeedDPM(_moveLength, _feed) { // moveLength[0] = Tool tip, [1] = XYZ, [2] = ABC if (false) { // TCP mode is supported, output feed as FPM return feed; } else { // DPM feedrate calculation var moveTime = ((_moveLength[0] < 1.e-6) ? 0.001 : _moveLength[0]) / _feed; var length = Math.sqrt(Math.pow(_moveLength[1], 2.0) + Math.pow((toDeg(_moveLength[2]) * dpmBPW), 2.0)); return length / moveTime; } } /** Calculate the Inverse time feedrate number. */ function getInverseTime(_length, _feed) { var inverseTime; if (_length < 1.e-6) { // tool doesn't move if (typeof maxInverseTime === "number") { inverseTime = maxInverseTime; } else { inverseTime = 999999; } } else { inverseTime = _feed / _length / inverseTimeUnits; if (typeof maxInverseTime === "number") { if (inverseTime > maxInverseTime) { inverseTime = maxInverseTime; } } } return inverseTime; } /** Calculate the distance of the tool position to the center of a rotary axis. */ function getRotaryRadius(center, direction, toolPosition) { var normal = direction.getNormalized(); var d1 = toolPosition.x - center.x; var d2 = toolPosition.y - center.y; var d3 = toolPosition.z - center.z; var radius = Math.sqrt( Math.pow((d1 * normal.y) - (d2 * normal.x), 2.0) + Math.pow((d2 * normal.z) - (d3 * normal.y), 2.0) + Math.pow((d3 * normal.x) - (d1 * normal.z), 2.0) ); return radius; } /** Calculate the linear distance based on the rotation of a rotary axis. */ function getRadialDistance(axis, startTool, endTool, startABC, endABC) { // rotary axis does not exist if (!axis.isEnabled()) { return 0.0; } // calculate the rotary center based on head/table var center; if (axis.isHead()) { var pivot; if (typeof headOffset === "number") { pivot = headOffset; } else { pivot = tool.getBodyLength(); } center = Vector.sum(startTool, Vector.product(machineConfiguration.getSpindleAxis(), pivot)); center = Vector.sum(center, axis.getOffset()); } else { center = axis.getOffset(); } // calculate the radius of the tool end point compared to the rotary center var startRadius = getRotaryRadius(center, axis.getEffectiveAxis(), startTool); var endRadius = getRotaryRadius(center, axis.getEffectiveAxis(), endTool); // calculate length of radial move var radius = Math.max(startRadius, endRadius); var delta = Math.abs(endABC[axis.getCoordinate()] - startABC[axis.getCoordinate()]); if (delta > Math.PI) { delta = 2*Math.PI - delta; } var radialLength = (2 * Math.PI * radius) * (delta / (2 * Math.PI)); return radialLength; } /** Calculate tooltip, XYZ, and rotary move lengths. */ function getMoveLength(_x, _y, _z, _a, _b, _c) { // get starting and ending positions var moveLength = new Array(); var startTool; var endTool; var startXYZ; var endXYZ; var startABC = new Array(getCurrentDirection().x, getCurrentDirection().y, getCurrentDirection().z); var endABC = new Array(_a, _b, _c); if (currentSection.getOptimizedTCPMode() == 0) { startTool = getCurrentPosition(); endTool = new Vector(_x, _y, _z); startXYZ = machineConfiguration.getOrientation(startABC).getTransposed().multiply(startTool); endXYZ = machineConfiguration.getOrientation(endABC).getTransposed().multiply(endTool); } else { startXYZ = getCurrentPosition(); endXYZ = new Vector(_x, _y, _z); startTool = machineConfiguration.getOrientation(getCurrentDirection()).multiply(startXYZ); endTool = machineConfiguration.getOrientation(new Vector(_a, _b, _c)).multiply(endXYZ); } // calculate the radial portion of the move var radialLength = Math.sqrt( Math.pow(getRadialDistance(machineConfiguration.getAxisU(), startTool, endTool, startABC, endABC), 2.0) + Math.pow(getRadialDistance(machineConfiguration.getAxisV(), startTool, endTool, startABC, endABC), 2.0) + Math.pow(getRadialDistance(machineConfiguration.getAxisW(), startTool, endTool, startABC, endABC), 2.0) ); // calculate the lengths of move // tool tip distance is the move distance based on a combination of linear and rotary axes movement var linearLength = Vector.diff(endXYZ, startXYZ).length; moveLength[0] = linearLength + radialLength; moveLength[1] = Vector.diff(endXYZ, startXYZ).length; moveLength[2] = 0; for (var i = 0; i < 3; ++i) { var delta = Math.abs(endABC[i] - startABC[i]); if (delta > Math.PI) { delta = 2*Math.PI - delta; } moveLength[2] += Math.pow(delta, 2.0); } moveLength[2] = Math.sqrt(moveLength[2]); return moveLength; } // End of multi-axis feedrate logic function onCircular(clockwise, cx, cy, cz, x, y, z, feed) { if (pendingRadiusCompensation >= 0) { error(localize("Radius compensation cannot be activated/deactivated for a circular move.")); return; } var start = getCurrentPosition(); if (isFullCircle()) { if (properties.useRadius || isHelical()) { // radius mode does not support full arcs linearize(tolerance); return; } switch (getCircularPlane()) { case PLANE_XY: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed)); break; case PLANE_ZX: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed)); break; case PLANE_YZ: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed)); break; default: linearize(tolerance); } } else if (!properties.useRadius) { switch (getCircularPlane()) { case PLANE_XY: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed)); break; case PLANE_ZX: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed)); break; case PLANE_YZ: writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed)); break; default: linearize(tolerance); } } else { // use radius mode var r = getCircularRadius(); if (toDeg(getCircularSweep()) > (180 + 1e-9)) { r = -r; // allow up to <360 deg arcs } switch (getCircularPlane()) { case PLANE_XY: writeBlock(gFeedModeModal.format(94), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), feedOutput.format(feed)); break; case PLANE_ZX: writeBlock(gFeedModeModal.format(94), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), feedOutput.format(feed)); break; case PLANE_YZ: writeBlock(gFeedModeModal.format(94), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), feedOutput.format(feed)); break; default: linearize(tolerance); } } } var mapCommand = { COMMAND_STOP:0, COMMAND_OPTIONAL_STOP:1, COMMAND_END:2, COMMAND_SPINDLE_CLOCKWISE:3, COMMAND_SPINDLE_COUNTERCLOCKWISE:4, COMMAND_STOP_SPINDLE:5, COMMAND_ORIENTATE_SPINDLE:19, COMMAND_LOAD_TOOL:6, COMMAND_COOLANT_ON:8, // flood COMMAND_COOLANT_OFF:9 }; function onCommand(command) { switch (command) { case COMMAND_START_SPINDLE: onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE); return; case COMMAND_LOCK_MULTI_AXIS: return; case COMMAND_UNLOCK_MULTI_AXIS: return; case COMMAND_BREAK_CONTROL: return; case COMMAND_TOOL_MEASURE: return; } var stringId = getCommandStringId(command); var mcode = mapCommand[stringId]; if (mcode != undefined) { writeBlock(mFormat.format(mcode)); } else { onUnsupportedCommand(command); } } function onSectionEnd() { writeBlock(gPlaneModal.format(17)); if (((getCurrentSectionId() + 1) >= getNumberOfSections()) || (tool.number != getNextSection().getTool().number)) { onCommand(COMMAND_BREAK_CONTROL); } forceAny(); } function onClose() { writeln(""); onCommand(COMMAND_COOLANT_OFF); if (properties.useG28) { writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(machineConfiguration.getRetractPlane())); // retract zOutput.reset(); } setWorkPlane(new Vector(0, 0, 0)); // reset working plane if (!machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) { if (properties.useG28) { writeBlock(gFormat.format(28), gAbsIncModal.format(91), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0)); // return to home } } else { var homeX; if (machineConfiguration.hasHomePositionX()) { homeX = "X" + xyzFormat.format(machineConfiguration.getHomePositionX()); } var homeY; if (machineConfiguration.hasHomePositionY()) { homeY = "Y" + xyzFormat.format(machineConfiguration.getHomePositionY()); } writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), homeX, homeY); } onImpliedCommand(COMMAND_END); onImpliedCommand(COMMAND_STOP_SPINDLE); writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off } [/i][/i]
I have just implemented M codes 3, 4, 5, 450, 451, 452 and 453. So the 1.20beta1 release will have spindle support.
That's good news.
I've noticed in MACH3 the G2&G3 commands often come with a "K" parameter too. I can only guess it defines a z plane?
Also the code looks like this:G3 X... Y... I... ( When J or I are 0, they don't appear in the line ) X... Y... I... ( The last command "G3" is still valid )
This output can be changed in brackets. But it doesn't make much sense to change that while RRF changes too.
It would be a temporary solution. -
I'm working with- Fusion360 and a Shapeoko 3 CNC router, wishing i could use my Duet. A few observations about Fusion 360's Post-processor and G-code preview/senders.
-Brackets mentioned above to edit post processors in Fusion360 is just a text editor from Adobe that Fusion automatically opens. I prefer Notepad++.
-Some report Autodesk threw these together hastily and have added features like speed dial adjustment calibration: https://discuss.inventables.com/t/a-better-fusion360-grbl-postprocessor/27607
-Shapeoko had a nice summary and wiki here: https://www.shapeoko.com/wiki/index.php/Communication_/_Control. They also discuss rationale for limiting Gcode implementation.
-I found a 3D preview to be paramount. I liked Candle: https://github.com/Denvi/Candle
-GRBL Panel had good features and UI too: https://github.com/gerritv/Grbl-Panel/wiki
Can you tell me which Gcodes not supported by the Duet are preventing you from using it for CNC?
