    trigger a macro with toolboard button
    516
    • Pseud3mysundefined
      Pseud3mys
      I tried to trigger a macro when I click on one button of ToolBoard.
      this is the Gcodes on my config file:
      ; Input/Output
      M950 J1 P"!121.button0"
      M581 P1 T1 S1
      and the macro named "trigger1.g":
      ;trigger1.g
      echo "button0"
      M300 S300 P200
      Why this don't work ?
      dc42undefined RodrigoRMaraujoundefined 2 Replies Last reply Reply Quote 0
        What actually happens?
        I'm not sure that's how echo is intended to work.
        https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Echo_command
        T1 would mean trigger1 which I believe means pause the print. I think you'd need to start at trigger2
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
        Trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400 command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
        Pseud3mysundefined 1 Reply Last reply Reply Quote 0
          Pseud3mys @Phaedrux
          @Phaedrux It change to trigger5, to be sure. Still nothing happen, when i click the button.
          I refer to this exemple: https://www.wildbot3d.xyz/control-panel/, but it is a bit old.
            Pseud3mys
            Is there a way to read directly the value of a input ?
              Pseud3mys
              from https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Buttons_and_LEDs
              The buttons can be used to generate triggers in the normal way. Their pin names are "button0" and "button1". The required pullup resistors are enabled automatically on these pins.
              So this is possible normally, but there are no doc to do it...
                dc42 administrators @Pseud3mys
                @Pseud3mys said in trigger a macro with toolboard button:
                The port name parameter in M950 is C, not P.
                  Pseud3mys
                  RESPONSE:
                  It is C parameter for the pin name, and trigger1 is already used.
                  the corrected code:
                  ; Input/Output
                  M950 J1 C"!121.button0"
                  M581 P1 T2 S1
                  AND the triggerX.g must be in /sys/ directory.
                  • RodrigoRMaraujoundefined
                    RodrigoRMaraujo @Pseud3mys
                    @pseud3mys said in trigger a macro with toolboard button:
                    ; Input/Output
                    M581 P1 T1 S1
                    ;trigger1.g
                    echo "button0"
                    M300 S300 P200
                    Pseud3mys , please.
                    I'm trying to figure out what it would be like to connect the wires to the buttons on the board, using a 3 mini 5+ duet. Would you know how to recommend me?
