Unsolved Stuttering print, only on CW circles
Not sure how much value this video will provide, but here it is.
https://youtu.be/QqNdBj9SzWs the video playback is kind of glitchy, so the hesitations are hard to pick out from printer stutters. The audio helps identify stutters.Printer is a Raise3D N2+ cartesian with a Duet2 Wifi board. Firmware is 2.05.1
At this point in the print the parts are concentric cylinders with no features on the inside or outside walls. Printing these with no infill, just perimeter shells and single extrusion fill.
The mesh started off pretty tight as this is a product I sell and I don't like visible faceting - I had about 1.5mm pitch on the mesh for this video.What I find odd is that the the printer doesn't stutter when printing the outer perimeters, only the inner ones. One part is split to clamp (not in the video) and the printer stutters only on the ID perimeters, not the OD, even though they are the same line. It will always stutter at the same spot, so it will leave a vertical line in the cylinder wall. It's not major, but I'm getting super clean prints otherwise, so this is frustrating.
I loosened up the mesh to 4mm pitch and that helped reduce the stuttering but didn't eliminate it. It is still only when doing a CW circle, not CCW. That just seems real strange to me.
Print speed is 80mms - I slow it down to 50% for single extrusion fill. Slicer is S3D. I read that S3D can be problematic for stuttering while printing. I have tried Cura, Prusa, and Ideamaker on these parts, but those slicers don't handle the single extrusion fill nearly as well as S3D and end up breaking into little pieces creating all kinds of build issues compared to S3D.
Any thoughts on why it would only stutter when drawing a circle CW and not CCW?
Here's my config.g
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 07:37:21 GMT-0400 (Eastern Daylight Time); General preferences
M501 ; process config-override.g
M550 P"N2+" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
M566 X400.00 Y400.00 Z100.00 E400.00:400.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z1200 E1200:1200 ; set maximum speeds (mm/min)
M201 X2000 Y2000 Z250 E25000:25000 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y-13 Z0 S1 ; set axis minima
M208 X305 Y305 Z608 S0 ; set axis maxima; Endstops
M574 X1 Y1 S0 ; set active low and disabled endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H2 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X12.5 Y51.05 Z3.5 ; set Z probe trigger value, offset and trigger height
M557 X25:275 Y50:300 S50 ; define mesh grid; Heaters
M307 H0 B1 ; bang-bang mode for the bed heater
M305 P0 X200 ; configure PT100 for heater 0
M305 P1 X152 ; configure thermocouple for heater 1
M143 H1 S310 ; set temperature limit for heater 1 to 310C
; M305 P2 X153 ; configure thermocouple for heater 2
; M143 H2 S310 ; set temperature limit for heater 2 to 310C; Fans
M106 P1 S0 I0 F500 H1:2 T40 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 L0.4 X1.0 B1 F30 H100 T40:65 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
; M563 P1 D1 H2 F0 ; define tool 1
; G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
; G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings
M591 D0 P1 C4 S1 ; filament runout sensor EXT 0, Low=Filament Present, endstop 1
G29 S1 ; load bed mesh; Miscellaneous
M501 -
@zemlin said in Stuttering print, only on CW circles:
did it stutter with them as well?
can you try again with M566 P1 ?
I suspect that it is speed-dependent. For a given segment size, there is a maximum speed that can be maintained when there is a long sequence of vert short moves. Firmware 3.2beta2 and later can maintain higher speeds than earlier versions under some conditions.
@Veti said in Stuttering print, only on CW circles:
I never tried printing the files from those other slicers. The single extrusion fill was a mess in the previews.
I will try M566 P1. Thank you.
as dc42 said. if the fragments are to small then this will cause a problem.
that is why using a different slicer is a quick way to test. -
@dc42 said in Stuttering print, only on CW circles:
Thank you. I have two basically identical printers that I've been upgrading to Duet. I have just a little work left to do on the second machine. Once I get the second wrapped up I'll start moving to the V3 firmware on one of them.
I tried adding P1 to the M566 line in my config.g.
Did not resolve the issue.That was an easy one to test - more in-depth testing will need to wait. Might be motivation to move to the V3 firmware sooner than later before I bang my head against the wall too much on this.
Thanks for the input.
Is this because the STL model is too fine?
IIRC, there are way to simplify the STL model, when exporting the STL, with STL editors or with slicer's resolution settings.
@zapta said in Stuttering print, only on CW circles:
It does improve with a coarser STL export, but the fact that it only stutters when printing inner CW circles and not the outer CCW paths when the STL segments are identical lengths inside and outside the cylinder walls is what I find particularly baffling.
Are both the inner and the outer circles of the same feature type from slicer's perspective? (outer perimeter, inner perimeter, infill, top, bottom, etc).
The slicer may set different parameters for different features. Also, you can look with an STL viewers at the triangles at both sides and see if you see any difference, e.g. with triangle density.
BTW, from the video, it looks as a high quality motion system, speed of movement, sound and such.
@zapta - yes - feature type is the same. Both inner perimeters and outer perimeters stutter. Only when printing the inside of the cylinder, not the outside.
Can you send M122 after a print and post the results?
8:33:49 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L4MSN-6JKD0-3SJ6S-K93AQ
Used output buffers: 1 of 24 (11 max)
Static ram: 25712
Dynamic ram: 93240 of which 0 recycled
Exception stack ram used: 448
Never used ram: 11672
Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3760) IDLE(ready,160)
Owned mutexes:
Last reset 02:01:13 ago, cause: software
Last software reset at 2020-12-07 18:32, reason: User, spinning module GCodes, available RAM 11728 bytes (slot 1)
Error status: 0
Free file entries: 10
MCU temperature: min 51.8, current 52.9, max 53.9
Supply voltage: min 23.1, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/1023
Driver 1: standstill, SG min/max 0/1023
Driver 2: standstill, SG min/max 0/542
Driver 3: standstill, SG min/max 0/1023
Date/time: 2020-12-07 20:33:47
Slowest loop: 156.72ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 79, MaxWait: 43293ms
Bed compensation in use: mesh, comp offset -0.016
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 172, 0
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.4
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.32ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b3:59:bd
WiFi Vcc 3.41, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24816
WiFi IP address 192.168.1.130
WiFi signal strength -63dBm, reconnections 0, sleep mode modem
=== Filament sensors ===
Extruder 0 sensor: ok
- WiFi -
Can you share the stl and the sliced gcode file?
This post is deleted! -
@Phaedrux - gcode is 6MB and the forum doesn't allow zip files. Suggestions? Do I need to post it on drop box or something? What's up with no zip files?
GCODE: https://drive.google.com/file/d/1_aMcfSjBaq4Vxs93n-LVL8NGJz0dkshM/view?usp=sharing
There are 2 STL files in that print.
nafs600f28edvr2-sleeve-hk35.stl nafs600f28edvr2-ring-hk35-b.stl
Try another slicer. Simplify is generating a 6MB gcode file and PrusaSlicer with similar settings is 3MB.
@Phaedrux I have tried slicing my models with Cura, Prusa, and Ideamaker. The other components I run in these builds have extensive single-extrusion fill requirements. Only S3D produces the results I want on the fill - the other slicers won't do a continuous single extrusion fill in many of the layers.
I am printing lens hoods for large camera lenses, so numerous variants of the same basic design. I have printed dozens of sets without issue. Just once in a while I have an issue with the stuttering.
From what I had read on other threads, I though it would be related to bed mesh compensation, but I disabled the bed mesh yesterday and that didn't change the stuttering.
I was beginning to think it was machine related as I had only seen the stuttering on the N2+, not the N2, but I put the stuttering g-code on the N2 yesterday and it stuttered the same. That's good news from a troubleshooting standpoint because the machines are identical.
I've had to very nearly identical prints run - one that stuttered and one that didn't - same STL, same slicer, slightly different settings in the slice (like extruder multiplier, horizontal offset, part scaling - all very small tweaks between setups or material lots).
I might have to run some test prints stair-stepping some settings to see if I can force it to turn on and off on the same print job.
I think prusa slicer should if thin wall detection and gap fill is enabled, though you might have to play with the extrusion width a bit.
Otherwise it would be interesting to see how 3.2 beta 4.1 handles it as suggesting by DC42 earlier.
There were no hiccups, you're not using high microstepping, and you've ruled out mesh compensation interacting with low z jerk.
Just this week I got both printers to a "finished" state with my upgrades and conversions. Needed to get to that point before potentially taking one down with a muffed update. Might be able to try that this weekend. Thanks for your insight.
