    MK2A Heated Bed causes board to crash
    2.4k
    • Vetiundefined
      Veti
      yes. you would need a 2mm^2 wire for that.
      bdeliaundefined 1 Reply Last reply Reply Quote 0
      • bdeliaundefined
        bdelia @Veti
        @Veti said in MK2A Heated Bed causes board to crash:
        2mm^2
        I am using 14Gauge wire from my external Mosfet to the Bed.
          If you set your multimeter to read resistance and then short the two probes together, what reading do you get? You need to subtract that reading from the 1.6 ohms that you measured.
          • bdeliaundefined
            bdelia @dc42
            @dc42 said in MK2A Heated Bed causes board to crash:
            When I read resistance by shorting the MultiMeter leads it reads .2 Ohms. So, if I understand you then that would mean my bed resistance, if measured at 1.6 is really 1.4 Ohms?
            If the above is accurate then it seems the bed is on the fringe of 24V compatible? Does that sound correct?
              Does your board have 2 solder pads or 3? The photo is a bit blurry.
              @bdelia said in MK2A Heated Bed causes board to crash:
              No. 1.4ohms would still indicate 12v. I think you're hoping pretty hard that this is just going to somehow work. I think your seller is clueless and is leading you astray. There's no way I would connect 24v power to that heatbed and leave it unattended in my own house.
              • bdeliaundefined
                bdelia @Phaedrux
                @Phaedrux said in MK2A Heated Bed causes board to crash:
                No. 1.4ohms would still indicate 12v. I think you're hoping pretty hard that this is just going to somehow work. I think your seller is clueless and is leading you astray. There's no way I would connect 24v power to that heat bed and leave it unattended in my own house.
                Thanks for your thoughts. I have sent an email to my supplier for the bed and am waiting for a response. Worst case I am out about $50 for the bed and will have to source another one.
                Does anyone here have a recommendation for a 24V 300x300 heated bed? I would prefer to source in the USA if possible for shipping timeliness.
                Thanks
                Brett
                  https://www.filastruder.com/products/e3d-varipower-heated-bed-pack?_pos=1&_sid=80bc0b874&_ss=r
                  Not sure if that suits your bed shape though.
                    Do you have a link to the item you've purchased?
                    • Vetiundefined
                      Veti
                      e3d makes 300x300 beds
                      https://e3d-online.com/collections/printer-parts-electrical/products/high-temperature-heated-beds
                      but they are ac beds.
                      their variopower bed 24v is only available in 300x200
                      https://e3d-online.com/collections/printer-parts-electrical/products/varipower-bed
                      you could try and source a voron 2 buildplate with a Keenovo heat pad
                      https://store.digmach.com/collections/voron-parts/products/build-plate-for-voron-2-3d-printer?variant=31774400675885 (us store but sold out, you could ask on the voron discord for other suppliers)
                      the matching kenoovo heater is avaiable in 24v (though voron guide says go with ac version at nearly twice the power)
                      https://keenovo.store/collections/standard-keenovo-silicone-heaters/products/keenovo-square-silicone-heater-3d-printer-build-plate-heatbed-heating-pad?variant=8324020895799
                      but to be honest if you are going for a 300x300 bed, you are in the territory of ac beds.
                        https://www.amazon.com/310x310mm-Aluminum-HeatBed-Thickness-Creality/dp/B07H8DXVQD/ref=sr_1_6?dchild=1&keywords=cr-10+heated+bed&qid=1607369292&sr=8-6
                        • JamesMundefined
                          JamesM
                          You could get a nice cast aluminum bed and put a 24v silicone heater on it. 713maker.com has some nice stuff. This is a 300x300 bed https://713maker.com/ft-5/ft-5-heated-bed
                          • bdeliaundefined
                            bdelia @Phaedrux
                            Here is a link to what I purchased:
                            http://www.zyltech.com/zyltech-3mm-aluminum-heated-heat-bed-3-sizes-available/
                            If you look at the description I purchased the one labeled as 300 x 300 MK2A Heated Bed.
                            300 x 300mm MK2A Heated Bed
                            Outside dimension: 330x330 mm
                            Usable size: 300x300mm
                            Resistance: 1.05-1.3 ohm
                            Voltage: 12-24 V (recommend 24V for better performance)
                            Pre-wired with thermistor and power cable
                              Thanks. That helps.
                              In that case your measurement of 1.4 ohms is closer to the 1.3 ohms they specify.
                              Still not clear how it's capable of 12 or 24 without different wiring, but at least Zyltech is a recognizable brand and not just some ebay seller or something.
                                A Former User @Phaedrux
                                From the specs it is effectively a powerful 24V bed, at 24V it is nominal 0.52W/cm^2 which is a little over the recommended 0.4 and at 12v it is at 0.13W/cm^2 which is borderline useless imho - so calling it dual voltage is BS.
                                At 24W and 1R05 to1R3 it's 550W to 450W and 23-18A, but OP is using a external mosfet so that should be fine, leaving voltage drop due to thin wiring or power supply over current protection kicking in (prematurely).
                                Phaedruxundefined BoAundefined 2 Replies Last reply Reply Quote 1
                                  Phaedrux Moderator @A Former User
                                  @bearer said in MK2A Heated Bed causes board to crash:
                                  Ok that makes more sense and explains why the reviews of the heater say using it at 12v is pointless because it can't reach even moderate temps.
                                  • BoAundefined
                                    BoA @A Former User
                                    @bearer Well... If You are on the lower R side, and close to 23A then bed alone is 550W + hotend 50W + motors + duet and over current protection might be triggered not so prematurely as You might think. Best would be to measure current from PSU, but not many multimeters can do it for range higher than 15-20A
                                    • Vetiundefined
                                      Veti
                                      Mosfet
                                      the duet will definatly not handle the current of that heated bed.
                                      maybe the mosfet you have can not either.
                                      Just to be on the save side, for 23-18A you need 10 AWG wire btw!
                                        A Former User @Veti
                                        thtas a good point, but i don't think an under dimensioned mosfet would cause the board to reset
                                        the peak current also probably won't last long due to the ptc characteristic of the copper traces, so I'd use silicone wirng for the flexibility and the increased temperature rating means you can probably get away 14 or even 16 gauge. (given op measured the resistance and putting himself in the lower power range, even the 18A rating of the Duet could work, but too close for comfort imho)
                                          Your 24V PSU probably has a voltage adjustment potentiometer. If you turn it down to the minimum, which is probably about 20V, then the current should be just about within the rating of the Duet. The hot end power will drop too, however most hot end heaters are over powered anyway.
                                          • bdeliaundefined
                                            bdelia
                                            Thanks for all of this discussion folks.
                                            If I read the comments after I posted the link to the bed and specs, can I assume you all feel this board can be used safely at 24V?
                                            I do run an external Mosfet and I will get 10 gauge wire to help with safety from the Mosfet to the bed.
                                            I am in a email conversation with the seller and am trying to determine if I should ask to return this board and look for something else. I do not want to introduce AC power as I am not yet comfortable with that concept, it feels more nuanced from a safety lense.
                                            Thanks
                                            Brett
