    PanelDueFirmware 3.2.4 released
    PanelDue
    14
    64
    4.2k
    • wilrikerundefined
      wilriker @oozeBot
      @oozeBot Thanks. This is definitely not intended behavior. I have a theory what is causing this and will investigate.
      Manuel
      My Tool Collection
      oozeBotundefined 1 Reply Last reply Reply Quote 1
      • oozeBotundefined
        oozeBot @wilriker
        @wilriker Glad to know this isn't intentional! Thanks for the hard work on this..
        • wilrikerundefined
          wilriker @oozeBot
          @oozeBot I found it and have fixed it in the source code already. I will probably release a new version early next week.
          Manuel
          My Tool Collection
            A Former User
            (If you push the changes to git it might get tested, in a totally hypothetical scenario)
            ((in a less hypotetical scenario; kudos!))
            • wilrikerundefined
              wilriker @A Former User
              @bearer Usually I'd done that but I have too many incomplete changes that I'd like to finish first and I was too lazy for git add -p. 😉
              Maybe tonight.
              Manuel
              My Tool Collection
              • wilrikerundefined
                wilriker @BoA
                @BoA said in PanelDueFirmware 3.2.4 released:
                Did anyone notice small dot's in corners, when screen saver is active? Are they suppose to be there?!
                I guess you are using the light theme, aren't you? The reason for these dots is that I used a display element with rounded corners for the screensaver. I'll see if changing this to another display element will help.
                Manuel
                My Tool Collection
                BoAundefined A Former User? 2 Replies Last reply Reply Quote 0
                • BoAundefined
                  BoA @wilriker
                  @wilriker I am using dark theme 2 🙂
                    A Former User @wilriker
                    @wilriker btw i'm seeing the same thing with a dark2 theme, and unrounding the corners will most likely resolve it indeed
                    • wilrikerundefined
                      wilriker
                      @bearer I have now pushed a lot of bugfixes. If you feel like testing, go ahead! 🙂
                      Manuel
                      My Tool Collection
                        A Former User
                        Looking good, both wrt full redraws and "disconnecting the dots", will keep an eye on the display for a print job tomorrow.
                        Much ❤
                        • wilrikerundefined
                          wilriker
                          I have now released PanelDueFirmware 3.2.5. Please continue in this thread.
                          Manuel
                          My Tool Collection
