    Bltouch oddity
    1.2k
    • BjornHundefined
      BjornH
      What i mean is that the probe will stop probing. It will work a few times, then stop responding.
        Wow that's convoluted. M3D really went all out.
        @BjornH said in Bltouch oddity:
        0:/sys/machine_stepperspeed.g
        speed changes/jerk
        One of the errors is from that file. You're missing a ; in front of the comment text.
        I don't see anything obvious in the configs that would interfere with the BLTouch.
        What's in your homeall? That's the only macro we're still missing.
        • BjornHundefined
          BjornH
          Promega
          Send code...
          Status
          Processing
          Tool Position
          X
          31.3
          Y
          129.2
          Z
          0.50
          Extruder Drives
          Drive 0
          885.1
          Drive 1
          0.0
          Speeds
          Requested Speed
          8 mm/s
          Top Speed
          8 mm/s
          Sensors
          Vin
          23.3 V
          MCU Temperature
          43.9 C
          Fan RPM
          0
          Z-Probe
          0
          Tools
          Extra
          Control All
          Tool Heater Current Active Standby
          Nozzle
          T1 - Load Filament Heater 2
          active 235.3 C
          235
          235
          Clay extruder
          T2 - Load Filament n/a n/a
          Bed Heater 0
          active 60.3 C
          60
          0
          Temperature Chart
          System Directory
          0:/sys/homex.g
          ; homex.g
          ; called to home the X axis
          ; October 4, 2018
          ; same as homey.g because of coreXY
          ; Front left corner is (0,0)
          ; ============= PRE-HOMING =====================
          ; Ignore Machine boundaries
          M564 H0 S0
          ; Turn off bed leveling during homing
          G29 S2 ; Does the same as M561!
          ; Switch to Origin Tool
          T0
          ; Relative positioning
          G91
          g1 x-5
          ; Provide Z height clearance
          G1 Z10 F750 S1
          ; ================== HOME Y ============================
          ; Rapid Y until limit switch triggers
          G0 Y450 F1500 S1
          ; Back off to release limit switch
          G0 Y-6 F1500
          ; Slow advance to trigger limit switch
          G0 Y10 F120 S1
          ; ============= HOME X ====================
          ; Rapid X until limit switch triggers
          G0 X450 F1500 S1
          G0 X-6 F1500
          G0 X10 F120 S1
          ; Move away from the limit switch, to prevent damage to it upon next move
          G0 X-12 F1500
          ; Set this location as X = 380mm
          G92 X340
          ; Move the gantry slightly away from back of printer, to allow travel past the bolt mounting the gantry bracket
          G0 Y-10 F1200
          ; Set this location as Y = 384mm
          G92 Y315
          ; ============ Post-Homing ==============
          ; Revert to absolute coordinates
          G90
          ; Re-enable mesh leveling
          ;G29 S1
          M98 Pmachine_axisdimension.g ; Set Axes Limits
          ; Stop movement across limits, enable boundaries, homing requirement
          M564 H1 S1
          Promega
          Send code...
          Status
          Processing
          Tool Position
          X
          69.7
          Y
          99.7
          Z
          0.50
          Extruder Drives
          Drive 0
          900.3
          Drive 1
          0.0
          Speeds
          Requested Speed
          8 mm/s
          Top Speed
          8 mm/s
          Sensors
          Vin
          23.9 V
          MCU Temperature
          43.8 C
          Fan RPM
          0
          Z-Probe
          0
          Tools
          Extra
          Control All
          Nozzle
          active 234.4 C
          235
          235
          Clay extruder
          Bed Heater 0
          active 60.1 C
          60
          0
          Temperature Chart
          System Directory
          0:/sys/homey.g
          ; homey.g
          ; called to home the Y axis
          ; Same as homex.g because of coreXY
          ; Front left is (0,0)
          M98 Phomex.g
          ; homez.g
          ; called to home the Z axis
          M564 H0 S0
          G29 S2 ; Do it twice because once just isn't enough
          T0
          G91
          G1 Z10 F750 S1
          ; ============ HOME Z ==============
          ; Rapid Z until limit switch triggers
          G0 Z450 F1500 S1
          G0 Z-15 F1500
          G0 Z20 F120 S1
          M98 Pmachine_zendstop.g ; Set Z Endstop height
          M98 Pmachine_zprobe.g ; Set Z Probe distance
          G90
          ;G29 S1
          M564 H1 S1
            Phaedrux Moderator @BjornH
            Ok now how bout these ones so we can see what it's doing to home z?
            • BjornHundefined
              BjornH
              Promega
              Send code...
              Status
              Processing
              Tool Position
              X
              27.0
              Y
              237.3
              Z
              0.50
              Extruder Drives
              Drive 0
              2861.8
              Drive 1
              0.0
              Speeds
              Requested Speed
              8 mm/s
              Top Speed
              8 mm/s
              Sensors
              Vin
              23.3 V
              MCU Temperature
              43.7 C
              Fan RPM
              0
              Z-Probe
              0
              Tools
              Extra
              Control All
              Nozzle
              active 234.9 C
              235
              235
              Clay extruder
              Bed Heater 0
              active 60.1 C
              60
              0
              Temperature Chart
              System Directory
              0:/sys/machine_zendstop.g
              ; machine_zendstop.g
              ; June 29, 2018
              ; IMPORTANT: should you drop the bed or skip a tooth, this value might change and has to be recalibrated!!!
              ; This file sets the Z position of the Z end stop. It is used to determine the height of the build volume.
              ; If this value is incorrect, you either have a nozzle that drags on the bed or is too far from the bed that
              ; the filament won't stick to the surface. It is the single most important file to get right so do spend
              ; some time verifying the Z position after making changes here.
              ; Instructions
              ; 1. Home All
              ; 2. Disable the bed mesh with G29 S2 twice
              ; 3. Run G1 X200 Y200 Z20 F1500
              ; 4. Manually jog the bed up using the <Z-10 to <Z-0.1 using smaller steps as you get close to the nozzle
              ; 5. Have bed touching the nozzle, do not leave a gap. If you can't reach the nozzle, estimate how far the
              ; bed is from the nozzle and add that value to the Z value in the G92 command below and start over.
              ; 6. Record your Z height number as shown in the DWC Machine Status Head Position Window
              ; 7. Calculate the new Z value for the G92 command below:
              ; If your Z value was positive, subtract the value from the current Z value in the G92 command below.
              ; Example: If the measured Z value of the bed touching the nozzle was 2.5 and the current Z value was
              ; 376.4, the new Z value would be 376.4 - 2.5 = 373.9
              ; Don't forget to set the Max Z value in machine_axisdimension.g to 374
              ; If your Z value was negative, add the value to the current Z value in the G92 command below.
              ; Example: If the measured Z value of the bed touching the nozzle was -0.7 and the current Z value was
              ; 376.4, the new Z value would be 376.4 + 0.7 = 377.1
              ; Don't forget to set the Max Z value in machine_axisdimension.g to 378
              ; If your Z value was 0, congratulations, no changes to this file are needed.
              ; 8. Re-enable your bed leveling compensation with G29 S1
              ; Set this location as Z = 376.4mm (Normally the Default Factory Number for Compound)
              ;G92 Z376.6 ; With glass bed and Compound
              endstop should be disabled
              ; machine_probe.g
              ; June 29, 2018
              ; This document tells the printer which Z probe to use and what the offsets of that probe are.
              ; For X and Y offset, use a caliper and measure the distance between the center of the nozzle
              ; and the part of the probe that measures the bed.
              ; If the probe is to the right of the nozzle, the X value is positive
              ; If the probe is to the left of the nozzle, the X value is negative
              ; If the probe is behind the nozzle, the Y value is positive
              ; If the probe is in front of the nozzle, the Y value is negative
              ; To select which probe to use, comment / uncomment ONE of the two M558 lines below.
              ; Determine the Probe Z Offset:
              ; 1. Heat the bed to 60C and the nozzle to 150C
              ; 2. Move the head near the center with G1 X200 Y200
              ; 3. Move the bed near the nozzle with G1 Z20
              ; 4. Disable the bed mesh with G29 S2, do this twice
              ; 5. Move the bed in small steps so it just touches the nozzle, 1mm steps first, then 0.1mm steps
              ; 6. Set the Z0 position with G92 Z0
              ; 7. Move the bed back to Z20, with G1 Z20
              ; 8. Deploy the probe if necessary
              ; 9. Get the Z Probe value with G30 S-1
              ; 10. Note the Z value in the Web UI and update it in the G31 Z parameter below
              ; 11. Put the Z probe away if necessary
              ; Toggle by uncommenting, depending on preference
              ; M558 P1 X0 Y0 Z1 H5 F120 T5000 ; Set Z probe type -- Enable IR_PROBE
              ; M558 P4 I1 X0 Y0 Z1 H5 F100 T5000 ; Set Z probe type -- Enable LIMIT SWITCH
              M558 P9 H5 F100 T2000
              ; Remember to update your Z-probe offset with the Z parameter below
              ; Follow this guide or the instructions above: http://promega.printm3d.com/books/user-manual/page/bed-leveling-probing#bkmrk-the-limit-switch-pro
              ; G31 P450 X30.4 Y30.7 Z10 ; Set Z probe (IR) trigger value and offset
              ; G31 P999 X-42 Y31 Z15.0 ; Set Z probe (Metrol switch) trigger value, offset
              G31 P9 X30 Y-5 Z3.6 ; Set Z probe (limit switch) trigger value, offset
              • BjornHundefined
                BjornH
                I have yet cleaned up all the files from M3D yet, as i have been strugling just to get this piece to work correctly. Bltouch to work optimal will be last piece
                  I can't see anything in there that should cause the bltouch to stop, but it's a bit hard to follow.
                  For troubleshooting I would suggest generating a basic config using the web configurator and see if you can get it working with a basic config. If it works, then you know it was a config problem. If it still has the same problem then it's a BLtouch hardware problem. Either the probe itself or the wiring.
                  • BjornHundefined
                    BjornH
                    Thank you for looking into it, i will clean up the files and try the configurator.
                    • BjornHundefined
                      BjornH
                      • Update to those who may have the same problem.
                      I can now confirm this is a wiring problem, as the dupont connection/wire is very bad.
                      After several tries and then squeezing the cable more onto the bltouch it suddenly worked fine again.
                      • Vetiundefined
                        Veti @BjornH
                        @BjornH
                        yes as i said earlier, the extension wire is causing a lot of headaches.
                        BjornHundefined 1 Reply Last reply Reply Quote 0
                        • BjornHundefined
                          BjornH @Veti
                          @Veti I will swap out all, but i think the main problem is in the dupont connector itself, i will open it and tighten the connectors.
                          TampaPrinterundefined 1 Reply Last reply Reply Quote 0
                          • Vetiundefined
                            Veti
                            just swap to a different connector.
                            these are the ones i use for small wires
                            https://de.aliexpress.com/item/32856368582.html
                            • TampaPrinterundefined
                              TampaPrinter @BjornH
                              I have a CR10 that does this too. Once in a while, like every 20 prints or so the bltouch simply checks out and goes on vacation for the initial home. Gives a message about already triggered but the Duet isn’t bothered by probe issues...it drives the Z into the bed until I stop it. Never fails during the 81 probe mesh, just the initial home. I’ve changed the BLTouch, swapped a new wire to the daughterboard then ditched it altogether and ran a new wire all the way to the Duet. Still does it with the same seldom frequency.
                              Though I have changed all of it, I get that it could still be a BLTouch issue or a wiring issue and have nothing to do with the Duet but the firmware should halt the Z when it knows the probe has failed. I find it odd that it doesn’t, though it is entirely possible I just haven’t found how to make it do so yet.
                              SkGo2 Corexy-Duet2wifi-Duex5-PanelDue7-HemeraVolcano
                              CR10V2 -Duet2wifi-Linear-HemeraVolcano
                              BjornHundefined 3dMLundefined 2 Replies Last reply Reply Quote 0
                              • BjornHundefined
                                BjornH @TampaPrinter
                                @TampaPrinter I have not corrected my fault yet, since i have to dissasemble my extruder. I belive the problem lays in the pins (dupont) connection to the bltouch as they are not thight enough
                                • 3dMLundefined
                                  3dML @TampaPrinter
                                  @TampaPrinter
                                  You can check for BLTouch sensor error before probing to detect some errors.
                                  if sensors.probes[0].value[0]!=1000 ; if probe is not in error state
                                  	M291 P"BLTouch ready to use" S1 T2
                                          G30
