    Confusion on M558 for Duet Maestro with RRF3
    IR Height Sensor
    728
    • j3dundefined
      j3d
      Is that required for P1 or P8?
        P8 is digital mode.
        • j3dundefined
          j3d
          Great, now I see the expected two blinks, however it's still reporting 0 - I guess I'll have to look at the board more closely. It's brand-new, so I'm a bit confused as to why it isn't working properly.
          Aside, when I read the documentation, if it says Duet 2, could I assume that it also means the Maestro as well if not specified otherwise? For instance, the documentation on M558 says: "Enable pullup resistor with ^ if using Duet 2, running RRF3, using the Z probe input pin, and the probe type is a switch or BLTouch." I passed over this because it didn't mention the Maestro and I didn't believe the sensor would be designated as a switch because it outputs a distance. (Or is this only in analog mode?)
          @dc42 , on your webpage you say "About 4 seconds after power is applied, the LED on the sensor should flash twice, indicating that the board has started in digital output mode." Perhaps you should add that you must enable the pull-up to enter that mode?
          • j3dundefined
            j3d
            I've checked the voltages, and they seem to be the same as those provided by fotomas here: https://forum.duet3d.com/topic/19864/duet-ir-sensor-stopped-working
            The only difference is that when I probe the point next to R1 the LED starts flashing rapidly:
            https://forum.duet3d.com/assets/uploads/files/1605648225764-untitled.png
            • j3dundefined
              j3d
              I have confirmed that the IR emitters are active.
              Is there anything else I can do to try and diagnose the issue? The only thing I can think of is trying to plug it into an Arduino and see if I can get any data from it directly, however given the fact that it gets power and can sense whether it is in digital or analog mode would imply that the connections are correct.
              I was able to get data from it once, but haven't been able to get anything since - and I haven't changed any of the wiring or configuration of the board. It is connected to Z_PROBE_IN, GND and 3.3V on the Z Probe header.
              The following is the contents of my config.g:
              G90                                         ; send absolute coordinates...
              M83                                         ; ...but relative extruder moves
              M550 P"Printer"                         ; set printer name
              M551 P"redacted"                           ; set password
              M552 P0.0.0.0 S1                            ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                  ; enable HTTP
              M586 P1 S0                                  ; disable FTP
              M586 P2 S0                                  ; disable Telnet
              M569 P0 S1                                  ; physical drive 0 goes forwards
              M569 P1 S1                                  ; physical drive 1 goes forwards
              M569 P2 S1                                  ; physical drive 2 goes forwards
              M569 P3 S1                                  ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                            ; set drive mapping
              M350 X128 Y128 E64 I0                       ; configure microstepping without interpolation
              M350 Z16 I1                                 ; configure microstepping with interpolation
              M92 X711.00 Y711.00 Z400.00 E400.00         ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00         ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z360.00 E1200.00     ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z50.00 E250.00         ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                     ; Set idle timeout
              M208 X-20 Y0 Z0 S1                          ; set axis minima
              M208 X275 Y150 Z150 S0                      ; set axis maxima
              M574 X2 S1 P"!xstop"                        ; configure active-high endstop for high end on X via pin !xstop
              M574 Y2 S1 P"!ystop"                        ; configure active-high endstop for high end on Y via pin !ystop
              M574 Z1 S1 P"!zstop"                        ; configure active-high endstop for low end on Z via pin !zstop
              M558 P8 C"^zprobe.in" H-5 F120 T6000         ; set Z probe type to unmodulated and the dive height + speeds
              G31 P50 X6.5 Y-35 Z2.5                      ; set Z probe trigger value, offset and trigger height
              M557 X-30:215 Y15:125 S20                   ; define mesh grid
              M140 H-1                                    ; disable heated bed (overrides default heater mapping)
              M308 S0 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 0 as thermocouple via CS pin spi.cs1
              M950 H0 C"e0heat" T0                        ; create nozzle heater output on e0heat and map it to sensor 0
              M307 H0 B0 S1.00                            ; disable bang-bang mode for heater  and set PWM limit
              M950 F0 C"fan0" Q500                        ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H0 T45                           ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"fan1" Q500                        ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S0 H-1                              ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"fan2" Q500                        ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S0 H-1                              ; set fan 2 value. Thermostatic control is turned off
              M563 P0 D0 H0 F0:1                          ; define tool 0
              G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
              G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
              T0                                          ; select first tool
              I'm using RepRapFirmware for Duet 2 Maestro version 3.1.1 running on Duet Maestro 1.0
                Your config looks fine. The Maestro is a Duet 2 series board.
                When you do a probe test with G30 as described here, what happens?
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                Does the probe trigger and halt movement?
                Your config also shows a Z endstop configured. But what do you have in your homing files to home Z?
                • j3dundefined
                  j3d
                  It does nothing. If I hadn't stopped it, it would have crashed into the bed. Nothing seems to trigger it.
                  Yes, I still have a Z end stop configured, and the home Z script utilizes it - I have yet to convert it over to using the Z probe due to this issue.
                  • Vetiundefined
                    Veti
                    @j3d said in Confusion on M558 for Duet Maestro with RRF3:
                    H-5 is a bit strange.
                    can you test with M119. If it not shows as triggered and the probe light is on full it might be your wiring.
                    • j3dundefined
                      j3d
                      I finally was able to look at the board up-close with a loupe to see what was going on. It looked like the solder underneath the IR receiver had not reflowed completely. Putting a dab of solder at one end seems to have fixed it, and I now have a functioning z probe. Hooray!
                      Hopefully it remains reliable. I don't have much faith in my soldering skills - however I'm pretty sure that taking a soldering iron to the board terminates the warranty anyways, even if it was a factory defect... 😕
                      • j3dundefined
                        j3d
                        Also, my board seems to be missing a component - C1. Is this intentional? @dc42
                          In this case I don't think we'd terminate the warranty unless you really melted the hell out of it. 😉 Since reflowing the solder point has made it functional it was clearly a defect in manufacturing. If you wish, you can contact your vendor and seek a warranty replacement. Include a link to this thread as authorization. Sorry for the inconvenience.
                            C1 is intentionally not fitted.
                            I am glad you found the problem. Soldering the side-looking IR receiver can indeed be a problem because of the unusual location of the pads, and that is the first thing we check when a sensor doesn't respond to a nearby surface.
                            • j3dundefined j3d referenced this topic
