Duet2 WiFi Firmware on Raise 3d E2 ?
Firmware installation
10.9k
    Proschi3D @jay_s_uk
    @jay_s_uk On the motion board map.
    The control board on the display has no card in it.
    it boots from internal memory
    Love my Duet 3 Mini.
    https://www.instagram.com/proschi3d
    https://youtube.com/@proschi3d
    https://www.proschi3d.de
      Proschi3D @jay_s_uk
      @jay_s_uk thanks, I'll test that at noon today
        Proschi3D
        here again the pictures of the two cards.
        with a description of the connectionsMotionboard.jpg Controller.jpg Controler 2.jpg
          jay_s_uk
          ah, that might be difficult then as the networking isn't handled by the control board and instead by the LCD screen.
          undefined 1 Reply Last reply 17 Dec 2020, 11:05 Reply Quote 0
            Veti
            can you post the output of m122?
            undefined 2 Replies Last reply 17 Dec 2020, 11:00 Reply Quote 0
              Proschi3D @Veti
              @Veti I do after work
                Proschi3D @jay_s_uk
                @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                That's the problem
                  If the pins for the dedicated SPI channel are available on the main board, then you might be able to connect an ESP12-based WiFi module to the main board.
                  undefined 1 Reply Last reply 17 Dec 2020, 11:32 Reply Quote 2
                    Proschi3D @dc42
                    @dc42 how can I find out ?
                      Proschi3D
                      again pictures of the motion board
                        jay_s_uk
                        you'll have to find out what pins are broken out to the main header.
                        Better get your multimeter out.
                        Or, contact raise3d and see if they'll give you a pinout
                          A Former User
                          As the board says based on the Duet2Wifi then I suppose they would have to comply with the open source license and provide the schematic (and layout files)?
                            Proschi3D
                            I just wrote to Raise and asked you for a pin assignment.
                            sorry my english comes from google translator;)
                              A Former User
                              Just refer to the CERN OHL 1.2 license for the Duet2Wifi if they don't give you what you want. (Or a link to this thread if they don't understand your request)
                                Proschi3D
                                thank you guys for your support and effort
                                  Proschi3D @Veti
                                  @Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                  (>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
                                    Veti
                                    so it seems to be running rrf2. not sure if they modified it.
                                    if you want to risk it, you can update the firmware with rrf3
                                    see
                                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                                    Fallback procedure #2
                                    undefined 1 Reply Last reply 17 Dec 2020, 16:24 Reply Quote 0
                                      Proschi3D @Veti
                                      @Veti this was not a good idea.
                                      the printer does not start anymore
                                        jay_s_uk
                                        This should get you back up and running
                                        https://drive.google.com/file/d/1X7L8mZ71x0eZNYgMeaI8VubTBc1Uk9uV/view?usp=sharing
                                        i have built it from the raise3d sources
                                        undefined 1 Reply Last reply 17 Dec 2020, 17:20 Reply Quote 0
                                          Proschi3D
                                          (>>) Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>
                                          22 out of 169
