    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Vetiundefined
      Veti
      can you post the output of m122?
      Proschi3Dundefined 2 Replies Last reply Reply Quote 0
      • Proschi3Dundefined
        Proschi3D @Veti
        @Veti I do after work
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          Proschi3D @jay_s_uk
          @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
          ah, that might be difficult then as the networking isn't handled by the control board and instead by the LCD screen.
          That's the problem
            If the pins for the dedicated SPI channel are available on the main board, then you might be able to connect an ESP12-based WiFi module to the main board.
            Proschi3Dundefined 1 Reply Last reply Reply Quote 2
              Proschi3D @dc42
              @dc42 how can I find out ?
                Proschi3D
                again pictures of the motion board
                  jay_s_uk
                  you'll have to find out what pins are broken out to the main header.
                  Better get your multimeter out.
                  Or, contact raise3d and see if they'll give you a pinout
                    A Former User
                    As the board says based on the Duet2Wifi then I suppose they would have to comply with the open source license and provide the schematic (and layout files)?
                      Proschi3D
                      I just wrote to Raise and asked you for a pin assignment.
                      sorry my english comes from google translator;)
                        A Former User
                        Just refer to the CERN OHL 1.2 license for the Duet2Wifi if they don't give you what you want. (Or a link to this thread if they don't understand your request)
                          Proschi3D
                          thank you guys for your support and effort
                            Proschi3D @Veti
                            @Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                            (>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
                            • Vetiundefined
                              Veti
                              so it seems to be running rrf2. not sure if they modified it.
                              if you want to risk it, you can update the firmware with rrf3
                              see
                              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                              Fallback procedure #2
                              Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                                Proschi3D @Veti
                                @Veti this was not a good idea.
                                the printer does not start anymore
                                  jay_s_uk
                                  This should get you back up and running
                                  https://drive.google.com/file/d/1X7L8mZ71x0eZNYgMeaI8VubTBc1Uk9uV/view?usp=sharing
                                  i have built it from the raise3d sources
                                    Proschi3D
                                    (>>) Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>
                                      jay_s_uk
                                      What version are you trying to flash so we can point you at the right file
                                        Proschi3D
                                        @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                          Proschi3D
                                          these data are on the original sd card
                                            Proschi3D @jay_s_uk
                                            @jay_s_uk do you think version 3.3 would work with the bin file you gave me?
