Duet2 WiFi Firmware on Raise 3d E2 ?
where did you put the file on the sd card?
you are missing a 2 in the filename
@Veti
yes
ok after restart it works
which firmware file did you use?
the files you send me
i did not send you any files
@Veti sorry I confused you with Jay
which one did you use? the one from the dropbox or the one from the 3.0 one?
the one from dropbox could be 3.0 to be fair. i just built it from their github
then does not flash the return value
@Proschi78
btw when you says your printer does not work, what do you mean?there are configuration changes required for going from 2.0 to 3.0
@Veti the printer no longer starts with firmware 3.0
it does. you posted the m122 output.
