    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Vetiundefined
      Veti
      you are missing a 2 in the filename
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
      • Proschi3Dundefined
        Proschi3D @Veti
        @Veti 🙂 yes
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          Proschi3D
            Proschi3D
            ok after restart it works
              Proschi3D
              Version 3.0 still on it
              • Vetiundefined
                Veti
                which firmware file did you use?
                  Proschi3D
                  the files you send me
                  • Vetiundefined
                    Veti
                    i did not send you any files
                      Proschi3D @Veti
                      @Veti sorry I confused you with Jay
                      • Vetiundefined
                        Veti
                        which one did you use? the one from the dropbox or the one from the 3.0 one?
                          jay_s_uk
                          the one from dropbox could be 3.0 to be fair. i just built it from their github
                            Proschi3D
                            • Vetiundefined
                              Veti
                              the src says 2.02
                              https://github.com/Raise3D/Reprap-Raise3D-E2-Series/blob/master/RepRapFirmware/src/Version.h
                                Proschi3D
                                then does not flash the return value
                                • Vetiundefined
                                  Veti @Proschi3D
                                  @Proschi78
                                  btw when you says your printer does not work, what do you mean?
                                  there are configuration changes required for going from 2.0 to 3.0
                                    Proschi3D @Veti
                                    @Veti the printer no longer starts with firmware 3.0
                                    • Vetiundefined
                                      Veti
                                      it does. you posted the m122 output.
                                        Proschi3D @Veti
                                        @Veti (>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SS-6J9FD-3S46R-TVSHD<LF>Used output buffers: 1 of 24 (3 max)<LF>=== RTOS ===<LF>Static ram: 30516<LF>Dynamic ram: 91744 of which 68 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 8488<LF>Tasks: NETWORK(ready,1888) HEAT(blocked,1476) MAIN(running,3764) IDLE(ready,156)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:15 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8440 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 26.0, current 28.1, max 28.4<LF>Supply voltage: min 1.4, current 1.5, max 1.6, under voltage events: 0, over voltage events: 0, power good: no<LF>Dr[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
                                        • Vetiundefined
                                          Veti
                                          yes so the printer starts.
                                            Proschi3D
                                            @Proschi78 said in
                                            this is befor updating
                                            Duet2 WiFi Firmware on Raise 3d E2 ?:
                                            (>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
