    Cnc breakout board for 4 axis milling machine.
    CNC
    cnc milling metalwork
    907
    • bigdaveundefined
      bigdave
      Also, to clarify my intent.
      I’d like to get a complete kit from you that will allow me to build a multi use control panel that will allow me to move my motors between a number of machines. Mill, lathe, router, 3D printer, scanner ect.
      I’d like to be able to setup machine profiles in the software to drive the different systems.
      I’ve probably gone overkill on the (350w x4), drivers and motors and installed them into a mobile cabinet.
      I’ll be installing breakers, surge protection and line filters into the panel.
      Your system seems to be very intuitive and from what I’ve seen if it could be done then you’d be the people doing it.
      I’m happy to incorporate anything you think appropriate to ensure a good outcome.
      Thanks and regards
      Dave
      • bigdaveundefined
        bigdave @jay_s_uk
        @jay_s_uk
        That’s ok, I’m not in a rush. In the meantime I want to keep building so I’d like engage with you on the rest of the system so I get it right.
        Can that be done offline? It would just be easier is all.
        mccaw.d@gmail.com
          Those stepper drivers need step and direction signals with a minimum signal level of 5V. As we don't yet have a Duet 3 board that supports external drivers, the best solution we can currently offer is Duet 2 WiFi or Duet 2 Ethernet, plus the Expansion Breakout Board.
          We're planning a Duet 3 main board to support external drivers, but it probably won't be available this year.
          bigdaveundefined 1 Reply Last reply Reply Quote 0
          • bigdaveundefined
            bigdave @dc42
            Is the duet 3 capable of driving the motors directly?
              jay_s_uk
              @bigdave not the ones you've linked to
              • bigdaveundefined
                bigdave @jay_s_uk
                @jay_s_uk
                I still have to install Ballscrews an mount my motors so I might try to wait it out
                tenajaundefined 1 Reply Last reply Reply Quote 0
                  A Former User @bigdave
                  @bigdave said in Cnc breakout board for 4 axis milling machine.:
                  Duet3 6HC is rated for 4.45A RMS (6A peak) and the motors are 6A, so you'd not make full use of the motors, but unless the low resistance pr coils is a problem it ought be possible to drive them at 4.45A.
                    jay_s_uk
                    Except they have closed loop feedback which couldn't be used, which IMO would be a bit of a waste
                      A Former User @jay_s_uk
                      @jay_s_uk said in Cnc breakout board for 4 axis milling machine.:
                      closed loop
                      d'oh! yes!
                      • mikedahlgrenundefined
                        mikedahlgren
                        @dc42 Looking forward to doing something similar, is there any update on the Duet 3 with external drivers might be available? Or should I buy a Duet 3 mini with 3 1XD's?
                          I'm sorry, we don't yet have an update on when Duet 3 with external driver support on the main board will be available. We are aware that a number of users are waiting for this.
                          The Duet 3 Mini can in theory support two external drivers using a breakout expansion board (as well as further external drivers using the 1XD expansion board).
                          • tenajaundefined
                            tenaja @bigdave
                            @bigdave
                            How is your project coming?
                            I'm surprised you are using ball screws and a control without backlash compensation. Do you just need fast, without concern for precision? Is there something else drawing you to duet?
                            If duet had backlash comp, I'd put it on one (or more) of my desktop machines, but without it, I'm sticking with the existing LinuxCNC. I suppose one could use a Marlin or Beagle board, but I haven't used either yet, so I don't have a favorite or a reason to migrate. (Like standardization.)
