    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.9k
    • JohnOCFIIundefined
      JohnOCFII
      What the of camera do you have? Looks like a Raspberry Pi camera? I'll need to look at that tomorrow. I have a USB-type camera.
      A Former User? stuartofmtundefined 2 Replies Last reply Reply Quote 0
        A Former User @JohnOCFII
        @JohnOCFII said in DuetLapse available for Alpha testing:
        Yes. i have a PI camera
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          JohnOCFII @A Former User
          @the_dragonlord What happens if you try to execute the raspistill -o cam.jpg command? Do you get an image?
          (I'm just guessing at a first troubleshooting step from here: https://www.raspberrypi.org/documentation/usage/camera/raspicam/raspistill.md )
          This stack exchange issue mentions some other possibilities -- some were fixed by updating the firmware on the Pi with sudo apt-get update and sudo apt-get upgrade
          https://raspberrypi.stackexchange.com/questions/13764/what-causes-enospc-error-when-using-the-raspberry-pi-camera-module
          • stuartofmtundefined
            stuartofmt
            EDIT: These changes can be downloaded from here:
            https://github.com/stuartofmt/DuetLapse
            First of all - thanks for this very useful program!!
            I am using a Duet Wifi2 and have a Pi 3 near it that I use to provide a video stream from here:
            http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
            I also run the Dueui app for local control. I am now adding DuetLapse.
            One thing I noticed with the standard pi camera is that only one process can be connected to it at a time (otherwise you will get ENOSPC errors) - so the standard DuetLapse approach gave errors.
            I added this code (and the appropriate checks for the new camera type etc.)
                if ('ffmpeg' in camera):
                    if (camparms == ''):
                        cmd = 'ffmpeg -y -i ' +weburl+ ' -vframes 1 ' +fn
                    else:
                        cmd = 'ffmpeg '+camparms+' '+weburl+ ' -vframes 1 ' +fn
            I use it like this (where the weburl is the pi camera stream. That way there is only one process connected to the camera but the output is serving two uses.
            /usr/bin/python3 ./DuetLapse.py -duet <duet ip> -camera ffmpeg -weburl http://<camera ip:port>/stream.mjpg -detect layer &
            Hope this helps others.
            P.S. I also added this to the top of DuetLapse.py to prevent multiple instances from running due to my own fat fingering 🙂
            # Added to stop multiple instances running
            import psutil
            procs = [p for p in psutil.process_iter() if 'python3' in p.name() and __file__ in p.cmdline()]
            if len(procs) > 1:
                print('Process is already running...')
                sys.exit(1)
              stuartofmt @JohnOCFII
              @JohnOCFII
              See my post above
              If you have two applications both trying to connect to the same Pi camera you will get these ENOSPC errors. This does not mean this is your exact problem - but is a good place to start.
                stuartofmt
                @Danal
                Another small suggested mod.
                I start DuetLapse.py remotely using a bash script and run it in background. Ctl+C cannot stop it if needed.
                I added the following (just above the main routine) so that I could send a SIGINT to stop the process.
                #Allows process running in background or foreground to be gracefully
                # Shutdown will SIGINt (Kill -2 <pid>
                import signal
                def quit_gracefully(*args):
                    print('Stopped by SIGINT - Post Processing')
                    postProcess()
                    exit(0);
                if __name__ == "__main__":
                    signal.signal(signal.SIGINT, quit_gracefully)
                The bash script to control this is inelegant at this time but here it is to illustrate the use:
                #! /bin/bash
                PROCESS=/home/pi/Lapse/DuetLapse.py
                case "$1" in
                	start)
                       /usr/bin/python3 $PROCESS -duet 192.168.86.235 -camera ffmpeg -weburl http://192.168.86.230:8081/stream.mjpg -detect layer &
                    stop)
                	   PROCESS_PID=`/bin/ps -ef | grep "$PROCESS" | grep -v "grep" | awk '{print $2}'`
                	   kill -2 $PROCESS_PID
                	   echo stopped
                esac
                  Phaedrux Moderator @stuartofmt
                  @stuartofmt said in DuetLapse available for Alpha testing:
                  @Danal
                  Sorry to tell you this, but Danal passed away several months ago now.
                    stuartofmt
                    @Phaedrux
                    Very, very sorry to hear that. Thanks for letting me know.
                    Do you know if anyone is taking over this work? I can do a little but I'm far from a professional programmer. More a programming by (google) example type.
                    I'll post my modifications in full, here, later today. I have some more slight mods coming but likely not for a couple of weeks
                      @stuartofmt starting a fork of the project on Github might be the best way forward. Then you can tinker away and it's available for others to use as well. I know Danal would have approved.
                        stuartofmt
                        I have created a fork of my changes so far and will update as I make additional tweaks.
                          JohnOCFII @stuartofmt
                          @JohnOCFII
                          See my post above
                          I have a solution in place that is working for me. I have ustreamer controlling the camera, and I have DuetLapse grabbing the images from ustreamer. I have both started by systemctl on my CentOS system. I have a script running that'll start capturing with DuetLapse by layer whenever a print starts.
                          The only modification I'd like to do is an ffmpeg input to add 2 seconds of the last jpeg image to the timelapse. I know it is possible - just need to figure it out.
                          John
                          stuartofmtundefined 3 Replies Last reply Reply Quote 0
                            @JohnOCFII
                            Good to hear. When you say add 2 seconds - do you mean continue recording for 2 second after Duet reports that it is no longer printing ?
                              @JohnOCFII
                              Maybe a small change like this at the end ?
                                      elif (printerState == 2):
                                          onePhoto()
                                          time.sleep(2)
                                          onePhoto()
                                          postProcess()
                                @JohnOCFII
                                Seeing I'm on a (UNTESTED) role. This may be better than the crude suggestion above. Note that it requires ffmpeg from Nov 2018 or newer.
                                I'll try it later today as I have a print to get done.
                                def postProcess():
                                    print()
                                    print("Now making {0:d} frames into a video at 10 frames per second.".format(int(np.around(frame))))
                                    if (250 < frame): print("This can take a while...")
                                #    fn = basedir+'DuetLapse'+time.strftime('%m%d%y%H%M',time.localtime())+'.mp4'
                                    fn = basedir+'DuetLapse'+time.strftime('%a-%H:%M',time.localtime())+'.mp4'
                                    if (vidparms == ''):
                                        cmd  = 'ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 tpad=stop_mode=clone:stop_duration=2 '+fn
                                #        cmd  = 'ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 '+fn
                                    else:
                                        cmd  = 'ffmpeg '+vidparms+' -i /tmp/DuetLapse/IMG%08d.jpeg tpad=stop_mode=clone:stop_duration=2 '+fn
                                #        cmd  = 'ffmpeg '+vidparms+' -i /tmp/DuetLapse/IMG%08d.jpeg '+fn
                                    subprocess.call(cmd, shell=True)
                                    print('Video processing complete.')
                                    print('Video file is in '+basedir+' directory, named '+fn)
                                    exit()
                                  @stuartofmt Yes -- something like that. Basically hold the last image for 2 seconds.
                                  Here's how OctoPrint refers to it:
                                    stuartofmt
                                    Seems like the tpad filter is missing from my version (4.1.6) of ffmpeg Debian Buster on Pi.
                                    Also the syntax above may (or not) work ....
                                    I may have to compile ffmpeg from the latest source - will let you know.
                                      I seem to have the same version of ffmpeg:
                                      ffmpeg version 4.1.6-1~deb10u1+rpt1 Copyright (c) 2000-2020 the FFmpeg developers
                                      I should troll through the OctoPrint/OctoPi code to see what they do.
                                      • oozeBotundefined
                                        oozeBot
                                        In case it went overlooked, I just wanted to toss out there that I came up with a solution for timelapse video when using a Duet 3 with attached Raspberry Pi..
                                        https://forum.duet3d.com/topic/19225/timelapse-video-through-execonmcode
                                        stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                          stuartofmt @oozeBot
                                          @oozeBot
                                          Thanks - a nice piece of work. I looked at it at one time but did not want to fiddle with generating the additional slicer code (likely an irrational reaction).
                                          In my case I could replace the wget with ffmpeg for the stream output from the app I am using and also the modified aggregation ffmpeg.
                                          I may end up back at your script - but for now I am wrestling with recompiling ffmpeg to get some additional filters that are not present in the somewhat old Pi version.
                                          oozeBotundefined 1 Reply Last reply Reply Quote 0
                                          • oozeBotundefined
                                            oozeBot @stuartofmt
                                            @stuartofmt I get it, but maybe there is something there that could be built upon. It would also be possible to put the trigger in daemon.g but I wanted to control the trigger within the gCode at precisely the same point, etc..
