    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.8k
    • arhiundefined
      arhi @jay_s_uk
      @jay_s_uk said in DuetLapse available for Alpha testing:
      Now all we need is to be able to call that from within a print file...
      well this script runs duetlapse over and over again so you need to start it once and forget, you could call it from rc.local so it starts when the rpi boots up and it will run till you shut it down
      • agent0810undefined
        agent0810
        Hey guys, have DuetLapse running and its communicating with my Duet 2 wifi board. When it sees a layer change it pauses the print, takes the pic and then does not start the print again. Is there a setting im missing?
        Here is some info of what im doing, at the bottom i am manually restrarting the print from my web interface.
        ./DuetLapse.py -duet 10.1.2.xxx -camera pi -pause yes -movehead 200 200 -detect layer
        it stops, moves the head to the corner then never starts again. any advice would be great, thank you!
        this is a duet 2 wifi board on a Ender 5 pro using cura slicer.
        Note "-pause yes" means this script will pause the printer when the -detect or
        -seconds flags trigger.
        If instead, it is desired that this script detect pauses that are already in
        in the gcode, specify:
        "-detect pause"
        Attempting to connect to printer at 10.1.2.xxx
        Connected to a Duet V2 printer at http://10.1.2.xxx
        Options in force for this run:
        camera = pi
        printer = 10.1.2.xxx
        seconds = 0
        detect = layer
        pause = yes
        camparms =
        vidparms =
        movehead = 200.00 200.00
        dontwait = False
        Waiting for print to start on printer 10.1.2.xxx
        Will take pictures when printing starts,
        and make video when printing ends.
        Or, press Ctrl+C one time to move directly to conversion step.
        Print start sensed.
        End of print will be sensed, and frames will be converted into video.
        Requesting pause via M25
        Moving print head to X200.00 Y200.00
        Capturing frame 0 at X0.00 Y0.00 Z6.12 Layer 6
        Capturing frame 1 at X103.69 Y86.69 Z1.32 Layer 7
        Capturing frame 2 at X79.03 Y101.37 Z1.52 Layer 8
        Capturing frame 3 at X67.97 Y145.27 Z1.72 Layer 9
          A Former User @Danal
          @Danal Hi, I've installed everything needed in my printer and Raspberry PI but when I start the script, as you can see, the Raspy doesn't recognize the (correct) printer IP :
          Could you help me to solve the problem?
          Thanks!
            jay_s_uk @A Former User
            @the_dragonlord @Danal passed away a few months back.
            I'm not sure if anyone has taken this script any further
              A Former User @jay_s_uk
              oh my....I didn't know...so sorry for that...
                This post is deleted!
                • JohnOCFIIundefined
                  JohnOCFII
                  As mentioned in the GitHub ticket - I wanted to see if you could ping the printer from the Pi, just to rule out low-level IP connectivity issues.
                  I just installed the DuetLapse about a month ago, so it is pretty fresh in my brain.
                  John
                  A Former User? 2 Replies Last reply Reply Quote 0
                    A Former User @JohnOCFII
                    @JohnOCFII said in DuetLapse available for Alpha testing:
                    John
                    Reading the very first messages of this thread I've seen a message of a user who suffered the exactly problem I've experienced... Both of us has setted the password and this seems to be the problem. Tomorrow I'll try to take off the password from config.g and see if it works.... I'll let you know
                      John
                      Good morning, I've taken off the password and now the scripts comunicate with the printer but it doesn't work for this error:
                        JohnOCFII
                        What the of camera do you have? Looks like a Raspberry Pi camera? I'll need to look at that tomorrow. I have a USB-type camera.
                        A Former User? stuartofmtundefined 2 Replies Last reply Reply Quote 0
                          Yes. i have a PI camera
                          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                            JohnOCFII @A Former User
                            @the_dragonlord What happens if you try to execute the raspistill -o cam.jpg command? Do you get an image?
                            (I'm just guessing at a first troubleshooting step from here: https://www.raspberrypi.org/documentation/usage/camera/raspicam/raspistill.md )
                            This stack exchange issue mentions some other possibilities -- some were fixed by updating the firmware on the Pi with sudo apt-get update and sudo apt-get upgrade
                            https://raspberrypi.stackexchange.com/questions/13764/what-causes-enospc-error-when-using-the-raspberry-pi-camera-module
                            • stuartofmtundefined
                              stuartofmt
                              EDIT: These changes can be downloaded from here:
                              https://github.com/stuartofmt/DuetLapse
                              First of all - thanks for this very useful program!!
                              I am using a Duet Wifi2 and have a Pi 3 near it that I use to provide a video stream from here:
                              http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
                              I also run the Dueui app for local control. I am now adding DuetLapse.
                              One thing I noticed with the standard pi camera is that only one process can be connected to it at a time (otherwise you will get ENOSPC errors) - so the standard DuetLapse approach gave errors.
                              I added this code (and the appropriate checks for the new camera type etc.)
                                  if ('ffmpeg' in camera):
                                      if (camparms == ''):
                                          cmd = 'ffmpeg -y -i ' +weburl+ ' -vframes 1 ' +fn
                                      else:
                                          cmd = 'ffmpeg '+camparms+' '+weburl+ ' -vframes 1 ' +fn
                              I use it like this (where the weburl is the pi camera stream. That way there is only one process connected to the camera but the output is serving two uses.
                              /usr/bin/python3 ./DuetLapse.py -duet <duet ip> -camera ffmpeg -weburl http://<camera ip:port>/stream.mjpg -detect layer &
                              Hope this helps others.
                              P.S. I also added this to the top of DuetLapse.py to prevent multiple instances from running due to my own fat fingering 🙂
                              # Added to stop multiple instances running
                              import psutil
                              procs = [p for p in psutil.process_iter() if 'python3' in p.name() and __file__ in p.cmdline()]
                              if len(procs) > 1:
                                  print('Process is already running...')
                                  sys.exit(1)
                                stuartofmt @JohnOCFII
                                @JohnOCFII
                                See my post above
                                If you have two applications both trying to connect to the same Pi camera you will get these ENOSPC errors. This does not mean this is your exact problem - but is a good place to start.
                                  stuartofmt
                                  @Danal
                                  Another small suggested mod.
                                  I start DuetLapse.py remotely using a bash script and run it in background. Ctl+C cannot stop it if needed.
                                  I added the following (just above the main routine) so that I could send a SIGINT to stop the process.
                                  #Allows process running in background or foreground to be gracefully
                                  # Shutdown will SIGINt (Kill -2 <pid>
                                  import signal
                                  def quit_gracefully(*args):
                                      print('Stopped by SIGINT - Post Processing')
                                      postProcess()
                                      exit(0);
                                  if __name__ == "__main__":
                                      signal.signal(signal.SIGINT, quit_gracefully)
                                  The bash script to control this is inelegant at this time but here it is to illustrate the use:
                                  #! /bin/bash
                                  PROCESS=/home/pi/Lapse/DuetLapse.py
                                  case "$1" in
                                  	start)
                                         /usr/bin/python3 $PROCESS -duet 192.168.86.235 -camera ffmpeg -weburl http://192.168.86.230:8081/stream.mjpg -detect layer &
                                      stop)
                                  	   PROCESS_PID=`/bin/ps -ef | grep "$PROCESS" | grep -v "grep" | awk '{print $2}'`
                                  	   kill -2 $PROCESS_PID
                                  	   echo stopped
                                  esac
                                    Phaedrux Moderator @stuartofmt
                                    @stuartofmt said in DuetLapse available for Alpha testing:
                                    @Danal
                                    Sorry to tell you this, but Danal passed away several months ago now.
                                      stuartofmt
                                      @Phaedrux
                                      Very, very sorry to hear that. Thanks for letting me know.
                                      Do you know if anyone is taking over this work? I can do a little but I'm far from a professional programmer. More a programming by (google) example type.
                                      I'll post my modifications in full, here, later today. I have some more slight mods coming but likely not for a couple of weeks
                                        @stuartofmt starting a fork of the project on Github might be the best way forward. Then you can tinker away and it's available for others to use as well. I know Danal would have approved.
                                          stuartofmt
                                          I have created a fork of my changes so far and will update as I make additional tweaks.
                                            JohnOCFII @stuartofmt
                                            @JohnOCFII
                                            See my post above
                                            I have a solution in place that is working for me. I have ustreamer controlling the camera, and I have DuetLapse grabbing the images from ustreamer. I have both started by systemctl on my CentOS system. I have a script running that'll start capturing with DuetLapse by layer whenever a print starts.
                                            The only modification I'd like to do is an ffmpeg input to add 2 seconds of the last jpeg image to the timelapse. I know it is possible - just need to figure it out.
                                            John
                                            stuartofmtundefined 3 Replies Last reply Reply Quote 0
