    Black Beauty Arises!
    My Duet controlled machine
    16
    65
    4.9k
    • gtj0undefined
      gtj0 @yellowedplastic
      @yellowedplastic said in Black Beauty Arises!:
      @gtj0 said in Black Beauty Arises!:
      I'm trying to picture your arrangement. With a cantilevered toolhead, I'd expect the rails to be "vertical", one above the other with their open faces facing the front of the printer, yeah? Or am I thinking something different? A lot depends on the length of the unsupported span and the mass of the toolhead but the rails are stiffest in that orientation so I wouldn't expect a problem. You may want to think about using a single 40mm wide rail and carriage though.
      That's still up in the air a bit. I'm planning to implement a Frank Herrmann style tool changer, though any tool changer will be easier with a cantilevered head. I doubt I'll be putting more than 500g on it, but am aiming for much less. The whole machining thing is new to me, so I'll probably be spending some evenings learning and wasting aluminum at my makerspace, figuring out what's most practical to end up with. Two horizontal rails of 17mm, or one of 27mm or 40mm, should allow for the least weight with a lot of rigidity, and least alignment work (IE, make the whole axis out of one piece of aluminum, like E3D's/Jubilee's, with rail lips and screw holes, with most of the work done by CNC milling), so I would lean that way, for now.
      Did you opt for a fixed/floating mix on the X axis, or all 4 fixed?
      In my design all 4 are fixed but that's because I have the ability to adjust the center-to-center distance of the rails. I align the front X rail so it's square with the Y rails, then adjust the back X rail so the toolhead slides with consistent friction across the span and with no twisting.
      Gotcha. So in that arrangement, you could go with either 2 smaller rails or one 40mm one. The 40mm rail makes alignment easy but it's heavier and you can't see through it. If you go with 2 rails, you'd use 2 carriages in the top rail and just 1 in the bottom rail. The bottom one could swivel to prevent binding.
      • QuintBrandundefined
        QuintBrand @mrehorstdmd
        @mrehorstdmd Interesting wear on the idler. Figures me a bit; would you agree that probably the debris there is cause by the belt rubbing over each other, with debris falling right down at the spot and another part at the idlers where the belts "Bend open"? Or do you think the wear is caused by the belt rubbing on the idlers itself?
        @gtj0: did you notice any debris on your printer yet? You have the spacer in the middle that prevents the rubbing between the belts, so...
        Also what is the minimum length you feel needed for the "twisting trick"?
        I also do hard to figure out reading post if it is really better to have smooth idlers v.s toothed ones. Pffff. Feels to me that toothed idlers are not an issue because there is no load on them...
        mrehorstdmdundefined gtj0undefined 2 Replies Last reply Reply Quote 0
        • mrehorstdmdundefined
          mrehorstdmd @QuintBrand
          @QuintBrand It's hard to say. I suspect the belts rubbing on the flanges of the pulleys were causing some wear in addition to the belt to belt contact. Gates belts have nylon facing on the teeth, not the back side of the belt, so the belt on belt wear would still occur. In some machines that cross the belts on one level people add a plastic separator, usually PTFE, to keep the belts from sliding against each other.
          QuintBrandundefined 1 Reply Last reply Reply Quote 0
            @mrehorstdmd Ok, so your feeling is that wear was at three places: left and right Idlers and in the middle the belt contact. THX.
            • gtj0undefined
              gtj0 @QuintBrand
              @QuintBrand said in Black Beauty Arises!:
              Oops, lost track here. Been too busy with other stuff.
              Nope, no debris at either the center or the idlers and the printer's been very busy. I have a belt span of about 650mm and wouldn't attempt the twist with a span of less than maybe 550mm. I have no data to back that up though as I haven't tried any shorter spans. As for toothed vs smooth idlers... It's true that there's no drive load of course but the inward force of just the belt teeth on a smooth idler surface would seem to cause the teeth to compress and expand more than if the teeth were riding in mating grooves of a toothed idler. Whether this is an issue in real use I'm not sure. I went with the toothed ones because it just made sense to me.
                QuintBrand @gtj0
                @gtj0 thanks for the answers! Great, I'll go twisted in my core to be too. So thanks for sharing, you helped me a lot!
                Thinking about the idlers... Yes toothed could be better actually that way 👍. I go toothed too, but saw some discussions bearings would be better. Nah, I like the toothed stuff!
                Cheers!
                gtj0undefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                • gtj0undefined
                  gtj0 @QuintBrand
                  Cheers!
                  Ah toothed idlers as opposed to bearings not smooth idlers. The bearing sandwich, such as that used by @mrehorstdmd, has a large enough diameter that there's much more surface area to spread the load so having the belt teeth ride over that smooth surface is not an issue. I went with the idlers just because of space constraints.
                    @QuintBrand The problem with the toothed pulleys is that the bearings in them are very tiny and wear out quickly. They typically have 3 or 5 mm bore which means the balls have to be very small which puts a lot of force on the races.
                    The 3D printer pulleys, smooth, but with 3 mm bore, I originally used in my sand table lasted for about a year of sporadic use before they started squeaking and binding.
                    A Gates manual about timing belts recommended a minimum of 9 teeth in contact with the pulley surface if using smooth pulleys. The belts bend over about 90 degrees of each pulley in a corexy machine. So if you're going to have 9 teeth over 90 degrees, that suggests 36 teeth going around the pulley. With 2 mm pitch, the circumference should be approximately 72 mm (a little less, actually), which leads to about 23 mm diameter. 608 bearings are 22 mm in diameter, are made in huge quantities for skates, motors, and machines, so are very cheap and readily available. They will last long time under the loads presented by a 3D printer.
                    QuintBrandundefined 1 Reply Last reply Reply Quote 1
                      @mrehorstdmd
                      Thanks for the nice additions a remarks! Wear and tear is not something I was think of to be honest ;-). I've also studied some of the Gates documentation, which is really nice till you want to do the math yourself: have you ever found the Specific Stiffness of GT2? I didn't unfortunately and once you start searching for the specifics I got lost in the fast amount of info ;-).
                      I thought driven pulleys require a lot of teeth, but was not away non-driven should be too. Makes sense when it comes to compression of the belt on the idlers though.
                      Most pulleys are 21 tooth on Ali, bit strange in view of your comments. These bearings are tiny indeed ;-0!!!
                      • gtj0undefined
                        gtj0
                        Someone asked for a link to the pics...
                        https://imgur.com/gallery/H9qKVcL
