problem attuning bed heater
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Jul 17 2020 20:24:58 GMT+0200 (CEST); General preferences
M550 P" CUBE PRO TRIO" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M569 P9 S1 ; physical drive 9 goes forwards
M584 X0 Y1 Z2 E3:4:9 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
M92 X87.35 Y87.43 Z1076.77 E82.09:82.09:82.09 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15000.00 Y15000.00 Z1200.00 E600.00:600.00:600.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z800 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent (ho modficato la corrente dei motori dell'estrusore da 800 a 1200)
M208 X0 Y0 Z0 S1 ; Imposta valore minimo deli assi
M208 X290 Y295.3 Z205 ; imposta il valore massimo degli assi ho tolto il valore S0 ALLA FINE DELLA RIGA; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M950 S0 C"duex.pwm5" ; creare il servo pin 0 per BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X-11.70 Y-51.2 Z2.75 ; impostare il valore del trigger della sonda Z, l'offset e l'altezza del trigger
M557 X12.3:290 Y24.80:295 S20 ; define mesh grid; Heaters
;Piatto riscaldato
;M570 H0 P90 T20 ; sto cercando di far aspettare fino che il piatto si riscaldi prima che mi dia errore
M143 H0 S110 ; set temperature limit for heater 0 to 120C
;Estrusore numero 1
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S290; set temperature limit for heater 0 to 120C
;Estrusore numero 2
M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S270
;Estrusore numero 3
M308 S3 P"spi.cs3" Y"rtd-max31865" ; M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4725 ; configure sensor 3 as thermistor on pin duex.e2temp
M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
M143 H3 S270 ; set temperature limit for heater 0 to 120C
M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
; Riscaldatore della camera
M141 H4 ; il riscaldatore 4 è il riscaldatore della camera
M950 H4 C"duex.e3heat" T4 ; configura l'uscita per il riscaldamento della camera sull pin e della scheda duex
M308 S4 P"duex.e3temp" Y"thermistor" T100000 B5500 C7.06Ee-8 ; configure sensor 4 as thermistor on pin duex.e2temp
M143 H4 S70 ; set temperature limit for heater 0 to 120C
M301 H4 B1 ; utilizzare il controllo bang-bang per il riscaldatore della camera; Fans
M106 P0 C"ESTRUSORI" S0 H3:2:1 T120 ; set fan 0 name and value. Thermostatic control is turned on
M106 P1 C"NOZZLE" S0 H1:2:3 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 C"LUCI LED" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
M106 P3 C"VENTOLA 6" S0 H-1 ; set fan 3 name and value. Thermostatic control is turned off
M950 F4 C"duex.fan7" Q500 ; create fan 4 on pin duex.fan7 and set its frequency
M106 P4 C"VENTOLA 7" S0 H-1 ; set fan 4 name and value. Thermostatic control is turned off; Tools
M563 P0 S"estrusore 1" D0 H1 F0:1 ; define tool 0
M563 P1 S"estrusore 2" D1 H2 F0:1 ; define tool 1
M563 P2 S"estrusore 3" D2 H3 F0:1 ; define tool 2
G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C; Sensori di folamento degli estrusori se imposto l'ultima S0 disabilita il confronto tra filamento aspetatto e quello realmente estruso,S1 abilita il controllo
M591 D0 P5 C"e0stop" R5:190 E3.0 S0 ; ho configurato il filamento del primo estrusore sull'uscita e0stop valori sensibilità filamneto originale R40:120
M591 D1 P5 C"connlcd.encb" R5:190 E3.0 S1 ; ho configurato il filamento del secondo estrusore sull'uscita stop10(ECN_B) valori sensibilità filamneto originale R40:120
M591 D2 P5 C"e1stop" R5:190 E3.0 S1 ; ho configurato il filamento del terzo estrusore sull'uscita e1stop valori sensibilità filamneto originale R40:120; Custom settings are not defined
M575 P1 S1 B57600 ;per abilitare lcd paneldue
M501 -
@Stephen6309 i don't know the B value in M308, how can i get it?
it should be in your thermistor documentation
@Veti said in problem attuning bed heater:
unfortunately I have no documentation, I made the mistake of getting it on amazon
https://www.amazon.it/dp/B07RJHYRP5/ref=cm_sw_r_wa_api_fabc_hm15Fb6K3JJWZ?_encoding=UTF8&psc=1
@konte1978 Write to the seller and ask for the beta value.
most likely they used the very common B3950 thermistor
What firmware version are you using?
Your screen shot shows the tuning process is running.
Does it ever finish? How long are you waiting?
Does it ever throw an error message?
When it's complete you need to send M500 to save the results. -
@Phaedrux Hi I'm using RepRapFirmware for Duet 2 WiFi / Ethernet version 3.2-RC2.
the test goes on even for 30 minutes without giving any error -
The new heater tuning algorithm in 3.2 can take a long time. Just let it finish.
https://forum.duet3d.com/topic/19761/new-heater-tuning-algorithm
