need some help please Duet 2 Wifi BL touch Ender 3
@Veti ; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
G31 P50 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S310 ; set temperature limit for heater 1 to 310C; Fans
M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Dec 27 2020 15:42:16 GMT-0600 (Central Standard Time)
G91 ; relative positioning
G1 H1 Z-265 F3000 ; move Z down until the endstop is triggered
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-240 F240 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Dec 27 2020 15:42:15 GMT-0600 (Central Standard Time)
G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-240 F240 ; move slowly to X axis endstop once more (second pass)
; Example Homing file for RepRapFirmware on delta printer
M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
;G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
;G1 S1 X320 Y320 Z320 F2500 ; move all carriages up 320mm, stopping at the endstops
;G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
;G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
;G1 Z-5 F2000 ; down a few mm so that we can centre the head
;G90 ; back to absolute positioning
;G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate; homeall.g
; called to home all axes
G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-240 Y-240 F240 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-265 F240 ; move Z down stopping at the endstop
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Dec 27 2020 15:42:12 GMT-0600 (Central Standard Time)
M280 P3 S10 I1 ; deploy BLTouch
; retractprobe.g
; called to retract a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Dec 27 2020 15:42:14 GMT-0600 (Central Standard Time)
M280 P3 S90 I1 ; retract BLTouch -
@Phaedrux when i send M122 and M98 gcode to the printer it says "response to long. see console"
@Veti whenever i go to the config tool to check what channel the BL Touch is on it keeps changing it to PWM1 after I change it to PWM5 and upload the changed with the proper channel config
your homing scripts still assume there is a z endstop.
copy the generated homing scripts from the configurator. there should be a G30 in them when homing z.G31 P50 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
you forgot to define all offsets. this will cause problems. you need to define x y and z.
this does not match. your deploy scripts and heater configuration must be identical.
@Zayy said in need some help please Duet 2 Wifi BL touch Ender 3:
So go to the console for the full response.
@Phaedrux it gives me this with the M98 gcode
Warning: Macro file config-override.g not found.
12/29/2020, 5:42:18 AM M98 P"config.g"
Warning: M918 command is not supported
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled...and this with the M122 gcode
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MS8-6JKF6-3S86R-19GAN
Used output buffers: 1 of 24 (9 max)
Static ram: 25712
Dynamic ram: 93184 of which 44 recycled
Exception stack ram used: 272
Never used ram: 11860
Tasks: NETWORK(ready,900) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:55 ago, cause: software
Last software reset at 2020-12-29 05:42, reason: User, spinning module GCodes, available RAM 11860 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 33.5, current 35.2, max 35.2
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-12-29 05:43:55
Cache data hit count 338494399
Slowest loop: 5.26ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.43ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b2:6c:8a
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22688
WiFi IP address 10.0.0.237
WiFi signal strength -48dBm, reconnections 0, sleep mode modem
- WiFi -
@Veti i have the z endstop still plugged in and i have the BL touch plugged into probe input on the board, and i just updated to the latest version so the config tool is different now it looks like this...
in https://configtool.reprapfirmware.org/Endstops you need to select z probe for z or the bltouch will not be used.
@Veti do you have a discord I could get in contact via a call with you because it honestly feels like I've taken 2 steps forward and 3 steps back because after I updated the firmware to 3.1.1 its now giving me a "G28 X" error saying it failed to enable endstop.
@Zayy How do you have your endstops defined in config.g? They not in the config.g you posted.
@Stephen6309 im sorry but what exactly do you mean. I have them in the first screenshot it shows
M574 Z1 S2 ; Define Z to use Probe. Home to Min -
M574 X1 Y2 S1 ;
that is the rrf2 config, you need to switch to rrf3 config
we want the information available for everyone. the forum is a important part of the community info.
if we move to discord this dissipaters. -
@Zayy For 3.0 to 3.2rc2, endstops need the pin.
My defines:
M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 1.io1.in
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H10 F120 T6000 ;A2 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-11 Y-50 Z0 ; set Z probe trigger value, offset and trigger height
M557 X10:400 Y10:300 S30 ; define mesh grid -
@Stephen6309 should i copy what you have because i honestly do not know what it should say and im lost. sorry i feel bad for not knowing but i basically have a $400 metal brick on my desk at this point
@Veti i do not even know what rrf2 config please elaborate
its the firmware version you selected in the first step.
the config you posted is for version 2
in the screenshot you posted of the configurator, you selected version 3
the config version needs to match the installed version
so post your new config.g and homing and retract and deploy scripts.
still showing up as "M574 X1 Y2 S1"
