[Firmware 3.2beta3] Can't resume after a filament-error0.g
@chrishamm Thats fixed the issue for me thanks.
Now pausing and resuming correctly -
@chrishamm Have you got time to check the result ? or do you need something else ?
@Krohm-Koala It should be fixed with RRF 3.2.0-b3.2, available from the unstable package feed. Your diagnostics output showed that you were still using 3.2.0-b3.
Let me know if the same problem is still present in that version.
@chrishamm i'll try as soon as my print finish and come back to you
thanks
@chrishamm So i've upgrade to beta 3.2, and still the same, here is the M122 after the error-gcode is done, the file haven't change since :
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3.2 running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SN-6J9DG-3SJ6Q-KBWBG Used output buffers: 3 of 24 (22 max) === RTOS === Static ram: 24108 Dynamic ram: 101512 of which 60 recycled Never used RAM 4368, free system stack 114 words Tasks: NETWORK(ready,136) HEAT(blocked,308) MAIN(running,435) IDLE(ready,20) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:09:08 ago, cause: software Last software reset at 2020-11-14 06:57, reason: User, GCodes spinning, available RAM 5148, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0x00 MCU temperature: min 33.0, current 34.8, max 35.2 Supply voltage: min 0.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 2000, standstill, SG min/max 0/530 Driver 1: position 1400, standstill, SG min/max 0/443 Driver 2: position 2217, standstill, SG min/max 0/0 Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2020-11-24 21:50:46 Cache data hit count 866645660 Slowest loop: 107.87ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.8ms, write time 40.4ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 143, MaxWait: 111806ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 546, completed moves 546, StepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.7 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 0 25, running macro Code queue is empty. === Network === Slowest loop: 85.57ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 2 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.24beta2-05b1 WiFi MAC address 84:f3:eb:42:b3:87 WiFi Vcc 3.34, reset reason Power up WiFi flash size 4194304, free heap 26600 WiFi IP address 192.168.1.33 WiFi signal strength -69dBm, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok
Hi @chrishamm i've updated to beta 4 and the problem is different, at the end of the macro, the printing resume automatically without going to previous Z position, XY are good but the interface locks in "pause" state so the print is running and i can't pause or cancel. Here is the M122 that i've done just after it resumed:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta4 running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SN-6J9DG-3SJ6Q-KBWBG Used output buffers: 3 of 24 (23 max) === RTOS === Static ram: 24108 Dynamic ram: 101308 of which 236 recycled Never used RAM 4396, free system stack 100 words Tasks: NETWORK(ready,158) HEAT(blocked,308) MAIN(running,390) IDLE(ready,20) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 57:54:31 ago, cause: software Last software reset at 2020-11-26 21:20, reason: User, GCodes spinning, available RAM 4780, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0x08 MCU temperature: min 25.3, current 34.6, max 37.9 Supply voltage: min 0.4, current 24.2, max 24.7, under voltage events: 7, over voltage events: 0, power good: yes Driver 0: position 26467, ok, SG min/max 0/1023 Driver 1: position 5481, ok, SG min/max 0/522 Driver 2: position 319, ok, SG min/max 0/96 Driver 3: position 0, ok, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2020-11-29 07:14:55 Cache data hit count 4294967295 Slowest loop: 167.67ms; fastest: 0.10ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 8 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 5.8ms, write time 48.1ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 165, MinFreeDm: 103, MaxWait: 78729874ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 814, completed moves 792, StepErrors 0, LaErrors 0, Underruns [0, 0, 25], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.8 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X132.337 Y34.381 E33.01870" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 0 25, running macro Code queue is not empty: Queued 'M106 P3 S1.0����������������������������������������������������' for move 795 Queued 'M106 P3 S1.0����������������������������������������������������' for move 804 2 of 16 codes have been queued. === Network === Slowest loop: 164.71ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 2 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.24beta2-05b1 WiFi MAC address 84:f3:eb:42:b3:87 WiFi Vcc 3.34, reset reason Power up WiFi flash size 4194304, free heap 26280 WiFi IP address 192.168.1.33 WiFi signal strength -70dBm, mode none, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok
@Krohm-Koala, does normal pause and resume work correctly?
Please post your resume.g file.
Hi @dc42, normal pause and resume work perfectly, i don't know why but filament errors resume automatically without calling the resume (it stays at Z pause height).
I've just tested in the last pre-release beta 4.1, exactly the same thing.Here is the resume.g
; resume.g ; called before a print from SD card is resumed ; ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 25 2018 07:35:06 GMT+0100 (heure normale d’Europe centrale) G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move G1 R1 X0 Y0 ; go back to the last print move M83 ; relative extruder moves ;G1 E10 F3600 ; extrude 10mm of filament
Hi @dc42 I've just updated to the 3.2RC1, still act as before, is there something i can do to have more info about what's going on at this moment ? If it can help, could be good
I don't know if i'm the only one to have this issue.
Can you confirm if this is still a problem in 3.2 RC2?
@Phaedrux I've just tested, yes, still a problem in 3.2 RC2.
@Krohm-Koala said in [Firmware 3.2beta3] Can't resume after a filament-error0.g:
Can you confirm that you are running regular RRF on your Duet in standalone mode, not the SBC version?
@dc42 Yes I'm running a duet2 wifi with regular rrf standalone (never really fond how sbc works on duet 2
Are you turning any axis motors off while the print is paused? Resume.g won't be called if any axes are flagged as not homed.
@dc42 No i don't turn any axis off, i just move the extruder + some meta code (exactly what i've put in my first post), it's weird that it's resuming directly after the purge is ending (i have a dialog to validate normally before i do anything else but it skip that) and it don't call resume.g
Hi @dc42, i've just installed 3.3.1Beta (it goes a lot better when you are doing it right
) and tested a thing, i've put an echo command at the end of my file, and it does not display it at all, even in the console, do you think it can be related to too much M291 or a certain type that made it crash ?
undefined T3P3Tony marked this topic as a regular topic 1 Nov 2021, 01:51
