    Duet 2 Wifi USB PORT smoke
    556
      A Former User @sniper23
      @sniper23 google acme magic smoke oil or something like that?
      Anyways, if the board still works with Vin (and no USB), is just a bit of fiddly work replacing the USB connector.
      If it didn't work is a bit more work, but still possible to repair most likely.
      Picture of the USB port would and traces would help determine how much repairing would be needed.
      See https://forum.duet3d.com/post/127089 if you need help with repairs.
      • sniper23undefined
        sniper23
        After doing some experiments with smoke, I understand now. The smoke comes from the mosfet numbered "R97"
          A Former User
          Oh, thats a bit unusual, its an older board as well - which revision is it? Should say something Rev 1.2 somewhere on the silkscreen just to the right of whats shown on the picture.
          Anyways, that is diode D13 with a bulge on it. SS14M or similar.
          Again if the board still works with Vin then you're OK and only need to replace that diode to power the board from USB.
          However, odds are there is a fault in your wiring somewhere.
          • sniper23undefined
            sniper23
            My board is V1.04 I purchased it back in 2018. In the picture the board is powered by USB nothing is connected otherwise. That smoke doesn't happen with 24V (red and black wiring) but when that is connected I don't see the blue led.
            I have the solder machine that I was using for my Arduino projects but It looks like I need more specialized tools for that.
              A Former User
              Looks like a cloned board?
              If so, its easier to solder because they're usually not extra heavy copper (just 1oz instead of 2oz) - should be possible to just add more solder to each side of the diode and try to get both sides melted at the same time and pick up the part with tweezers. Clean pads with solder wick then solder in a new diode one pad at the time with a regular iron.
              But you'll want to find out where you have a wiring error of the computer USB port is damaged.
              sniper23undefined 1 Reply Last reply Reply Quote 0
              • sniper23undefined
                sniper23 @A Former User
                @bearer I'm not sure about the board. I have multiple computers in the office so the same result with them. Where can I buy that replacement diode?
                • Vetiundefined
                  Veti
                  check the back. thats a good indication if its a cloned board.
                    @sniper23 said in Duet 2 Wifi USB PORT smoke:
                    mouser, digikey, farnel, rs, arrow or any of the masjor players will have it, or you can look at ebay or amazon etc as well.
                    top silkscreen says Bas .. ed on Duet2Wifi so pretty sure its a colone, but doesn't really matter other than being easier to repair (and break for that matter)
                    • whosrdaddyundefined
                      whosrdaddy @sniper23
                      I was using my Duet Wifi 2 from 2018-2019. About a year ago, the board suddenly stopped, and after it didn't work again. It was showing VIN light when connected to 24v power. When I connect it to a USB to a computer, I can see also the blue light and the computer can detect it but smokes are coming from the USB port when it is connected to USB. Is it possible to repair this or should I get a new one? I am using the spare Duet I have with the machine.
                      Are you using a laptop or a desktop?
                      When using a laptop, do not connect the power supply as you can cause a usb ground loop.
                        A Former User
                        It's perfectly-safe(tm) to use both desktops and laptops when everything is in working order. Sure a laptop running off batteries can alleviate pottenial ground loop issues but ensuring everything is at the same ground potential is the best bet.
                        However this issue might not be a clear cut ground loop, it tends to fry the ground pin/trace on the usb port - but it could be the diode on a cloned board is an even weaker link
                        • sniper23undefined
                          sniper23 @whosrdaddy
                          @whosrdaddy No desktop.
                          • oliofundefined
                            oliof
                            you could:
                            • disable power via USB by taping off the power connection in your USB cable
                            • power the board via the optional external 5V input (see https://duet3d.dozuki.com/Wiki/Hardware_Overview for the wiring diagram).
                            Also make sure to check the back of the board for any bad solder spots, and as others said before, triple check your wiring.
