Mini 5 (with toolboard) and leveling using X2 Motors
So the final hurdle in setting up my new Mini 5 plus!!
I cant get the levelling using x2 Z axis motors to work.
I previously had a Duet-2 Wifi installed and everything worked with it (including the two motor leveling)
I had a Genuine Duet IR sensor installed and when i went to initiate G32 it would home fine (the probe showed as having triggered in the DWC momentarily showing a value of 1000), but as soon as it sent the probe to the designated point beside the first leadscrew it would probe but not trigger the probe (no value change) but no head crash occured and the same thing happened to the second probe point, after completion DWC reported the failure due to the probe not being triggered.
I thought my IR probe was now somehow faulty, and as i have a genuine BL touch spare i fitted and set that up. i can carry out homing with that, the probe deploys and the head drops, and as soon as the probe touches the bed the head lifts back up but when i tell it to carry out a G32 command it homes (as i have a G28 in my bed.g) the BL touch probes and the head lifts up again but the DWC doesnt report that the probe has triggered and G32 fails saying that the probe was not triggered but i am physically watching the BL touch react and again the head doesnt crash.
I have attached my config.g and bed.g but please remember this only started when i swapped over to the new mini 5 and a toolboard with my Duet-2 everything worked on the same settings..
any idea's ?
im considering a temporary rewire to bypass the toolboard so see how that effects things.
; Mega-3-Mini 5 config.g ; 1. General Preferences G90 ; Machine movement to use absolute coordinates M83 ; Extruder to use relative moves M550 P"Mega-3" ; Machine name ; 2. Network M552 S1 ; Network is enabled and acquires a dynamic address via DHCP M586 P0 S1 ; HTTP is enabled M586 P1 S0 ; FTP is disabled M586 P2 S0 ; Telnet is disabled ; 3. Drives M669 K0 ; Select kinematics type M671 X-70:410 Y170:170 S10 ; The Z axis pivot point locations to allow levelling to be undertaken M569 P0.0 S1 ; Drive 0.0 (Y Axis Motor) goes forwards M569 P0.1 S1 ; Drive 0.1 (Z1 Axis, Left Motor) goes forwards M569 P0.2 S1 ; Drive 0.2 (Z2 Axis, Right Motor) goes forwards M569 P0.3 S1 ; Drive 0.3 (X Axis Motor) goes forwards M569 P121.0 S1 ; Drive 121.0 (E0, Extruder Motor) goes forwards and is mapped to the Tool-Board-LC1 M584 X0.3 Y0.0 Z0.1:0.2 E121.0 ; Drive mapping M350 X16 Y16 Z16 E16:16 I1 ; Microstepping with interpolation M92 X80.00 Y100.00 Z400.00 E409.00 ; Steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; Maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; Accelerations (mm/s^2) M906 X1200 Y1200 Z800 E800 I30 ; Motor currents (mA) & motor idle factor % M84 S30 ; Idle timeou ; 4. Axis Limits M208 X0 Y0 Z-1 S1 ; Axis min M208 X350 Y350 Z350 S0 ; Axis max ; 5. Endstops M574 X1 S1 P"121.io1.in" ; X Axis endstop is at the low end and mapped to pin 121.io1.in on the Tool-Board-LC1 M574 Y1 S1 P"io1.in" ; Y Axis endstop is at the low end and mapped to pin io1.in on the Main Board M574 Z1 S2 ; The Z probe acts as a Z axis endstop & is located at Z axis's minimum & mapped/connected to the io0 port on the toolboard LC1 ; 6. Z-Probe ; 6.A BL-Touch code M950 S0 C"121.io0.out" ; Servo pin 121.io0.out for the BL-Touch M558 P9 C"121.io0.in" H5 F100 T6000 ; Signal pin 121.io.in for the BL-Touch G31 X-32 Y-1 Z0.777 P25 ; Probe's trigger value, offsets & trigger height ;M557 X5:270 Y0:280 S44 ; Mesh grid parameters ; 6.B IR sensor code ;M558 P8 C"121.io0.in" H5 F100 T6000 ; The Z probe is of type 8 & is mapped/connected to 121.io0.in port on the toolboard LC1 ;G31 P50 X11 Y0 Z1.298 ; Z probe trigger value, offset and trigger height ;M557 X45:370 Y8:330 S20 ; Mesh grid parameters ; 7. Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; Sensor 0 is a thermistor on temp0 M950 H0 C"out0" T0 ; Bed heater is on output on out0 & mapped to sensor 0 M307 H0 R0.885 C213.4 D5.27 S1.00 ; Bed heater is set to PID mode & set PWM limit M140 H0 ; Bed heater is mapped to heater 0 M143 H0 S120 ; Temperature limit for the bed heater is set to 120C ; M308 S1 P"121.temp1" Y"thermistor" T100000 B4138 ; Sensor 1 is a thermistor & mapped to pin 121.temp1 on the Tool-Board-LC1 M950 H1 C"121.out0" T1 ; The Hot end heater outputs on 121.out0 and is mapped to sensor 1 on the Tool-Board-LC1 M307 H1 A312.4 C202.6 D15 S1 V23.6 ; The Hot end heater is set to ise PID & set PWM limit M143 H1 S310 ; Temperature limit for the Hot end heater is set to 310C ; 8. Fans M950 F0 C"121.out1" ; The part cooling fan (fan0)is mapped/connected to out1 on the toolboard LC1 M106 P0 S0 H-1 C"Part Cooling Fan" ; The part cooling fan (fan0)is set to value 0 & thermostatic control is turned off M950 F1 C"121.out2" ; The hot end cooling fan(fan1)is mapped/connected to out2 on the toolboard LC1 M106 P1 S255 H-1 C"Hot End Fan" ; The hot end cooling fan(fan1)is set to value 1 & thermostatic control turned off ; 9. Tools M563 P0 S"Hot-End" D0 H1 F0 ; Define tool 0 G10 P0 X-40 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; 10. Miscellaneous ;T0 ; Select first tool ; Bed.g file called to level 2 Z axis motors via G32 G28 ; Home all axis's G30 P0 X50 Y170 Z-99999 ; Probe near the left lead-screw G30 P1 X350 Y170 Z-99999 S2 ; Probe near the right lead screw G30 P0 X50 Y170 Z-99999 ; Probe near the left lead-screw (Second Pass) G30 P1 X350 Y170 Z-99999 S2 ; Probe near the rear lead screw (Second Pass) G1 X170 Y170 F8000 ; Position the nozzle at the centre of the bed G30 ; Probe and set the height as probed G29 S1 P"heightmap.csv" ; Load the height map -
dont load the heightmap in bed.g
bed.g should only execute the probing. and that only once.
so remove the second probing, g30 and g29.
can you connect the probe to the mini 5 and retest?
did you update the firmware on the toolboard to match the one on the mini 5?
I had an issue with miss-matched firmware earlier in the week which left me with a heater issue, the toolboard update took but the mainboard firmware didnt.
I had updated it (or so i thought) but the update hadnt taken, until it was done manually again, that updated evertything fully to the latest release candidates.
the final G30 in my bed.g was the result of a thread here on the forum which recommended a final G30 to re-set the Z datum in the middle of the bed after the leadscrews had carried out their compensation actions.
i commented it out the final G30, and the G29 that made no difference .
Although im puzzled why it would be a problem to load the height map aftwards when everything worked perfectly well on my Duet-2 with the same firmware and same bed.g .
i will make up a loom to remove the toolboard from the equation to see how that works
@JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
best to do that in a macro.
what difference does it make where it is done ?
@JayJay
so it makes things like this
https://forum.duet3d.com/topic/20598/bed-g-repeated-execution-based-on-deviation-results
easier -
@Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
@JayJay
easierThanks but i dont need that, and doesnt actually help me with the issue i am encountering.
i wired the Bl touch directly to the mini 5 and the problem still exists, i tried my IR probe direct to the board too and it too encounters the issue, really considering putting my Duet 2 back in at least i know it works.
EDIT
I just tested the probe(s) in all the other IO ports and the probes dont work in io0 or io4 dont know if that is relevant or not.
io0 and io4 are not pwm capable.
see
https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities -
ok.
i tried homing Z at the points where my bed.g would probe to level the leadscrews and that works.
so its only when G32 is requested that the probe is not being seen
i am running bed leveling on my mini 5 fine using an ir probe.
only difference i see is that i have the M671 after the M208, but that should not matter
could that be a problem with the wiring?
maybe at the probing position the wires are not making a good contact -
maybe at the probing position the wires are not making a good contactif it was a wiring issue then when i home at the probe points that would fail too, its only when G32 is requested, the probes work fine on the toolboard too when requsted to home at those points which rule out the wiring.
As i said in my post about the heaters which turned out to be the firmware, im confident in my wiring
G30 P1 X350 Y170 Z-99999 S2can you issue those commands manually? whats the output in the console
i issued both manually
G30 P0 X50 Y170 Z-99999 completes fine (shows green in the console)
G30 P1 X350 Y170 Z-99999 S2 shows: Error: Z probe was not triggered during probing movebut i can physically see the probe operate and the Z axis react and the head lifts back up
and a g29 across the bed works?
yes it does.
I re-installed my Duet-2 all is working again with the same bed.g file.
i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
neither can i. and the probing working sometimes is not something you can configure.
Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
Firmware version? Can you post the results of M122?
@Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
The Board is removed so the M122 will show some errors i think.
i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
i have been racking my brains with this one as it makes no sense at all.
M115:
FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
Used output buffers: 3 of 40 (11 max)
Static ram: 98732
Dynamic ram: 107196 of which 496 recycled
Never used RAM 38792, free system stack 140 words
Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:54 ago, cause: power up
Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Date/time: 2021-01-01 15:00:52
Cache data hit count 222524317
Slowest loop: 5.31ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 10.70ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25beta0
WiFi MAC address f4:cf:a2:6f:bd:af
WiFi Vcc 3.37, reset reason Power up
WiFi flash size 2097152, free heap 25264
WiFi IP address 192.168.0.115
WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
=== CAN ===
Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
- WiFi -
That is confusing. An intermittent short in something connected?
