    Mini 5 (with toolboard) and leveling using X2 Motors
    968
    • Vetiundefined
      Veti @JayJay
      @JayJay
      so it makes things like this
      https://forum.duet3d.com/topic/20598/bed-g-repeated-execution-based-on-deviation-results
      easier
      JayJayundefined 1 Reply Last reply Reply Quote 0
      • JayJayundefined
        JayJay @Veti
        @Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
        @JayJay
        easier
        Thanks but i dont need that, and doesnt actually help me with the issue i am encountering.
        i wired the Bl touch directly to the mini 5 and the problem still exists, i tried my IR probe direct to the board too and it too encounters the issue, really considering putting my Duet 2 back in at least i know it works.
        EDIT
        I just tested the probe(s) in all the other IO ports and the probes dont work in io0 or io4 dont know if that is relevant or not.
        • Vetiundefined
          Veti @JayJay
          @JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
          io0 and io4 are not pwm capable.
          see
          https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities
          • JayJayundefined
            JayJay
            ok.
            i tried homing Z at the points where my bed.g would probe to level the leadscrews and that works.
            so its only when G32 is requested that the probe is not being seen
            • Vetiundefined
              Veti
              i am running bed leveling on my mini 5 fine using an ir probe.
              only difference i see is that i have the M671 after the M208, but that should not matter
              could that be a problem with the wiring?
              maybe at the probing position the wires are not making a good contact
              • JayJayundefined
                JayJay @Veti
                if it was a wiring issue then when i home at the probe points that would fail too, its only when G32 is requested, the probes work fine on the toolboard too when requsted to home at those points which rule out the wiring.
                As i said in my post about the heaters which turned out to be the firmware, im confident in my wiring
                • Vetiundefined
                  Veti
                  G30 P0 X50 Y170 Z-99999
                  G30 P1 X350 Y170 Z-99999 S2
                  can you issue those commands manually? whats the output in the console
                  • JayJayundefined
                    JayJay @Veti
                    i issued both manually
                    G30 P0 X50 Y170 Z-99999 completes fine (shows green in the console)
                    G30 P1 X350 Y170 Z-99999 S2 shows: Error: Z probe was not triggered during probing move
                    but i can physically see the probe operate and the Z axis react and the head lifts back up
                    • Vetiundefined
                      Veti
                      and a g29 across the bed works?
                      • JayJayundefined
                        JayJay @Veti
                        @Veti
                        yes it does.
                        I re-installed my Duet-2 all is working again with the same bed.g file.
                        i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
                        • Vetiundefined
                          Veti @JayJay
                          @JayJay
                          neither can i. and the probing working sometimes is not something you can configure.
                          JayJayundefined 1 Reply Last reply Reply Quote 1
                          • JayJayundefined
                            JayJay @Veti
                            @JayJay
                            Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
                              Firmware version? Can you post the results of M122?
                              • JayJayundefined
                                JayJay @Phaedrux
                                @Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
                                The Board is removed so the M122 will show some errors i think.
                                i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
                                i have been racking my brains with this one as it makes no sense at all.
                                M115:
                                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
                                M122
                                RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
                                Used output buffers: 3 of 40 (11 max)
                                Static ram: 98732
                                Dynamic ram: 107196 of which 496 recycled
                                Never used RAM 38792, free system stack 140 words
                                Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:01:54 ago, cause: power up
                                Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
                                Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
                                Date/time: 2021-01-01 15:00:52
                                Cache data hit count 222524317
                                Slowest loop: 5.31ms; fastest: 0.11ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Bed heaters = 0 -1, chamberHeaters = -1 -1
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 10.70ms; fastest: 0.00ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  WiFi firmware version 1.25beta0
                                  WiFi MAC address f4:cf:a2:6f:bd:af
                                  WiFi Vcc 3.37, reset reason Power up
                                  WiFi flash size 2097152, free heap 25264
                                  WiFi IP address 192.168.0.115
                                  WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Clock register 00002002
                                  === CAN ===
                                  Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
                                  Phaedrux Moderator @JayJay
                                  That is confusing. An intermittent short in something connected?
                                  • JayJayundefined
                                    JayJay @Phaedrux
                                    its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
                                      Some thoughts:
                                      • Is the tool board definitely running 3.2RC2 as well?
                                      • Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
                                      • You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
                                      • JayJayundefined
                                        JayJay
                                        @Phaedrux
                                        @Veti
                                        Well I finally fixed it....
                                        My homeall.g had G30 S-3 in the script.
                                        I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
                                          dc42 administrators @JayJay
                                          @Phaedrux
                                          @Veti
                                          Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
                                          • JayJayundefined
                                            JayJay @dc42
                                            @dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
                                            @Phaedrux
                                            @Veti
                                            The Duet-2 was/is on Release 3.2-RC1
                                            And to confirm
                                            Duet-2 WOULD complete the action with G30 S-3
                                            Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
                                            The Mini-5+ would only complete after i removed the S-3 switch
