Ender 3 Pro and Duet 3 Mini 5+ Guide
A draft release of the Ender 3 Pro and Duet 3 Mini 5+ upgrade guide is now available for your perusal. Hopefully you find it helpful as the Mini 5+ starts to arrive at your doors. If you find any problems or have any questions, please let me know in this thread. Further guides on configuration etc are on the way.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
@Phaedrux The link points to the end of the docu, this one heads to the top:
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87 -
Part 2 of the guide is now up and goes through using the config tool to generate your first set of config files.
Next guide will go through getting connected for the first time, updating firmware, and initial testing and commissioning.
For reference, the dozuki links in the messages from 2020/1 don't work any more. You can find the upgrade guide here, under "Printer-specific guides":
https://docs.duet3d.com/en/How_to_guides/Getting_started
Note that as this was done quite a while ago, and I think the configuration was done with RRF 3.3, so it may be a little out of date. Any feedback is helpful though, thanks!Ian
