Cetus Mk11 to Duet wifi 2. Pay $$ for Config file
Ok, how do you have it wired up? Looks like you'll need 5v, ground, and an input pin.
Where you get the 5v and ground from isn't as important, but the input pin needs to be named in your M558 command.
@oliof
I have changed the M558 command;
M558 P5 I1 C"zprobe.in" H5 F300 T6000The Dashboard shows the z probe but it is active
low? Goes to "0" from 1000 when triggered.
I have tried to invert but unsuccessful.
Would this be symptomatic of a need for the ^ pull up resistor setting.? If so where exactly would I insert that?Thanks in advance
@Rodsterman said in Cetus Mk11 to Duet wifi 2. Pay $ for Config file:
the i1 is rrf2.
in rrf3 you invert the signal with !so
M558 P5 C"!zprobe.in" H5 F300 T6000
also you can try P8, as its a bit faster
Btw, I get no response from the z probe with M119.
that is for end stops, not for z probes i think (unless it also shows zprobe)
@bearer
M119 does show zprobe status if you configured the endstop as zprobe -
So the question becomes how is OPs
M574
line for Z?should it be
M574 Z1 S2
to work as he expects withM119
?edit: no, i think the mk3 does have a z-endstop, so
S2
is probably not what OP wants. -
M119 will report zprobe status regardless if it's an endstop based zprobe.
@Phaedrux
I have it wired as you have stated. This is the current M558 command
M558 P5 I1 C"zprobe.in" H5 F300 T6000Change this to
and check again. -
@oliof said in Cetus Mk11 to Duet wifi 2. Pay $ for Config file:
Many thanks to Phaedrux, bearer, veti and oliof. The new setting worked and now I can do a G29 and level bed probing.
Onward and forward to bigger and (better?) challenges.I hope all of you Have a Very Happy New Year.
and I also hope I can tap your Brains again! -
Happy New Year, @Rodsterman! This is a much better outcome than a perfectly usable machine in the trash (-:
Its amazing what you can achieve if you try.
Happy new year to all
