    Filaprint heightmap off - Rail alignment off?
    • seeul8erundefined
      seeul8er
      I have a CoreXY with genuine HiWin Rails on a frame made out of linear extrusion profiles (I know that this setup kind of kills the accuracy demands of HiWin). My print bed is a 6mm alu-plate from FilaFarm with a verified flatness (I do not have the test certificate at hand). On top I have a FilaPrint surface glued with some double-sided transfer glue. Because of that I do not expect to get the flatness of the alu-plate on the very top.
      I level my bed with three points (left-, right-front and center in the back).
      However when I do a manual mesh bed probing my heightmap always looks something like this:
      9eb718df-52d5-4991-a319-3538791e7148-grafik.png b2e763da-7d3b-46dc-8612-d858f30166a0-grafik.png
      The front is fairly on the same level. Same goes for the centre in the back. The further back I probe the more the heightmap shifts up on the left and goes down on the right. That shift is kind of linear with a linear increase of Y. That kind of got me wondering.
      My question: Is my glued print surface simply that uneven or is something wrong with my setup. I suspect the left rail to be not on the same plane as the right rail of my CoreXY. Could that explain the shift? I already tried putting 0.1mm shims under the left rail, but with very little success.
      • DIY-O-Sphereundefined
        DIY-O-Sphere
        To me it seems as if the rails are twisted to each other.
        (UTC+1)
        • fcwiltundefined
          fcwilt
          I think your XY rails are not in the same plane.
