    Duet 3 keeps blowing the breakers in my house when powered on!!!
    1.3k
      Phaedrux Moderator @eddygara
      @eddygara said in Duet 3 keeps blowing the breakers in my house when powered on!!!:
      Pics of the fired power cable and outlet
      https://imgur.com/gallery/SFfP6Bc
      Looks like a bad connection in the socket.
      eddygaraundefined 2 Replies Last reply Reply Quote 1
      • eddygaraundefined
        eddygara @Phaedrux
        @Phaedrux It was perfectly fine until it was plugged in directly. This happened after I removed all cables to the PSU and connected everything.
        I figured out the problem thanks for helping me troubleshoot, turns out, one of my connectors to the power socket was bad. You guys rock!
        • eddygaraundefined
          eddygara @Phaedrux
          @Phaedrux
          Ok so it’s not fixed,
          This is getting out of hand. At one point it worked perfectly fine. Once everything back connected to to the board the entire things blows my breakers again.
          I’ve switched out power connections, cables, removed and re did all my wiring.
          The board will blow my home breakers ever time it’s powered on.
          My other printers which again are wired exactly the same, (minus the new board) do not do this at all.
            Can we get some more photos of your current setup? Are you still getting blown sockets?
              A Former User @eddygara
              with the risk of repeating myself - its very unlikely to be the board, but rather the mains wiring.
                What breakers are blowing: current limit breakers, or RCD (aka GFCI) breakers?
                I had a problem last year that the master RCD breaker in the consumer unit would trip whenever I turned on the laser printer in my office. Suspecting a faulty class Y capacitor (the ones between mains input and ground that help suppress EMI), I replaced the Class Y capacitors in it. A little while later, the problem returned. Eventually I realised that it only occurred when both our new induction hob and several pieces of equipment in my office were turned on.
                What was happening is that the leakage of the hob plus mains wiring capacitance plus the class Y capacitors in all my office equipment together created enough current between live and neutral to trip the 30mA RCD.
                I fixed it by relocating the hob/cooker circuit to the non-RCD-protected side of the consumer unit, using a RCBO (combined current breaker and RCD) on that circuit instead of a plain current breaker.
                I've since read that induction hobs are renowned for tripping RCDs. I guess they have larger class Y filtering capacitors than most other devices, because of the amount of EMI they would otherwise generate.
                  Phaedrux Moderator @dc42
                  @dc42 said in Duet 3 keeps blowing the breakers in my house when powered on!!!:
                  Based on the photos earlier no, they look like standard north america breakers.
                    A Former User
                    Some of them were tagged GFI - does that refer to protected outlets in the circuit?
                      dc42 administrators @Phaedrux
                      @Phaedrux said in Duet 3 keeps blowing the breakers in my house when powered on!!!:
                      Here in the UK you can get RCBOs, which combine a current breaker with a RCD (aka GFCI). Might it be one of those?
                      EDIT: the ones with TEST buttons are RCBOs.
                      • whosrdaddyundefined
                        whosrdaddy
                        I had an instance with one of my printers where the IEC connector fuse would blow after 10 minutes.
                        At first I thought that the fuse had died, but after 2 additional fuses died, I replaced the fuse again and
                        monitored the printer while powered, at that moment I realized that the IEC connector was getting really hot!!! (It was a crappy chinese one, bought via Amazon). After replacing the connector with a better specimen, the problem was solved, for some reason there was a bad connection inside the connector causing sparks and resulting heat.
                        Long story short, check your IEC connector (and get one with a fuse) 😉
                          A Former User
                          One of the IEC connects were questionable to say the least.
                            dc42 administrators @eddygara
                            @bearer just removed the bed wiring all together, so no power is being drawn in from the bed. Breakers still blew. Again not sure what my issue could be?? So strange that this thing could be drawing that much power!
                            Here’s a pic of my breaker terminal if that help!
                            https://i.imgur.com/LV4RTOI.jpg
                            Which of those breakers trips?
                              Phaedrux Moderator @A Former User
                              @bearer said in Duet 3 keeps blowing the breakers in my house when powered on!!!:
                              Yes. In North America any ground fault protection is typically present in the socket at the point of use rather than at the breaker.
                                Yes. In North America any ground fault protection is present in the socket at the point of use rather than at the breaker.
                                Some of the breakers illustrated have TEST buttons. Those look like RCBOs (combined current breaker and GFCI) to me.
                                  @dc42 That could be.
                                    A Former User
                                    It doesn't make a whole lot of sense to have the full rated breaker current as the fault current without being able to see/hear/smell it to me.
