RepRapFirmware 3.2-RC2 released
@mikep419 said in RepRapFirmware 3.2-RC2 released:
Installed RC2 last night including updating the PanelDue firmware using M997 S4, which is nice. Tuned heaters this morning using new M303. Everything working as expected.
Thanks for the hard work. Happy New Year.
Have you seen within M303 the new T-parameter?
+1
Thanks everybody!
Just adjusting my printer
For some reason i can not set Toff to 1
M569 P3 F1
Error: M569: Bad off time for driver 3M569 P3 F2
This worksaccording to the data sheet
https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2209_Datasheet_V103.pdftoff 1 is a valid setting
It does not work on the maestro with tmc2224 either.
It's because the datasheet says you must use toff=1 only with tbl >= 2. What have you set tbl to ?
it does not work with that either
M569 P3 D2 S1 F1 B2
Error: M569: Bad off time for driver 3the datasheet says this
Hint
Highest motor velocities sometimes benefit from setting TOFFto 1 or 2 and a short TBLof 1 or 0 -
ok i have to set the tbl first and then i can set the toff
M569 P3 D2 S1 B2
M569 P3 D2 S1 F1 -
I can change the code to set tbl before toff, however if I do that then you would face the same issue if you try to set tbl=1 and toff>1 in the same command.
if you do the check on the values to be set it should work both waysi.e if the commands set tbl or toff use those values for the check
if one or the other is not set use the current value. -
@dc42 Any idea why the new 3.2 RC2 no longer recognizes this meta code?
if sensors.filamentMonitors[0].filamentPresent = false Error: meta command: unknown value 'filamentPresent'
@mitch said in RepRapFirmware 3.2-RC2 released:
Are you running with SBC or in standalone mode?
Is 'sensors.filamentMonitors[0]' non-null? Send M409 K"sensors.filamentMonitors[0]" to check.
@dc42 said in RepRapFirmware 3.2-RC2 released:
can you please add that info to this page
Running Duet2 Eth. No SBC.
{"key":"sensors.filamentMonitors[0]","flags":"","result":{"calibrated":{"percentMax":107,"percentMin":95,"sensitivity":101,"totalDistance":562.7},"configured":{"calibrationFactor":0.418,"percentMax":110,"percentMin":90,"sampleDistance":3.0},"enabled":false,"status":"ok","type":"laser"}}
This change is documented in the release notes for 3.2beta3 at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md. When RRF 3.2 stable is released, the change will be copied over to the release notes for that version.
Thanks, Sorry, I went from 3.1.1 straight to 3.2 RC2 and I missed that note back in beta 3.
if sensors.filamentMonitors[0].status = "noFilament"
