RepRapFirmware 3.2-RC2 released
ok i have to set the tbl first and then i can set the toff
M569 P3 D2 S1 B2
M569 P3 D2 S1 F1 -
I can change the code to set tbl before toff, however if I do that then you would face the same issue if you try to set tbl=1 and toff>1 in the same command.
if you do the check on the values to be set it should work both waysi.e if the commands set tbl or toff use those values for the check
if one or the other is not set use the current value. -
@dc42 Any idea why the new 3.2 RC2 no longer recognizes this meta code?
if sensors.filamentMonitors[0].filamentPresent = false Error: meta command: unknown value 'filamentPresent'
@mitch said in RepRapFirmware 3.2-RC2 released:
Are you running with SBC or in standalone mode?
Is 'sensors.filamentMonitors[0]' non-null? Send M409 K"sensors.filamentMonitors[0]" to check.
@dc42 said in RepRapFirmware 3.2-RC2 released:
It's because the datasheet says you must use toff=1 only with tbl >= 2. What have you set tbl to ?
can you please add that info to this page
Running Duet2 Eth. No SBC.
{"key":"sensors.filamentMonitors[0]","flags":"","result":{"calibrated":{"percentMax":107,"percentMin":95,"sensitivity":101,"totalDistance":562.7},"configured":{"calibrationFactor":0.418,"percentMax":110,"percentMin":90,"sampleDistance":3.0},"enabled":false,"status":"ok","type":"laser"}}
This change is documented in the release notes for 3.2beta3 at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md. When RRF 3.2 stable is released, the change will be copied over to the release notes for that version.
Thanks, Sorry, I went from 3.1.1 straight to 3.2 RC2 and I missed that note back in beta 3.
if sensors.filamentMonitors[0].status = "noFilament"
