    Did I fry my new board....
    1.9k
    • Harvdog1undefined
      Harvdog1
      Here is what I am running:
      Stock Ender 3
      Rip Rap Firmware v3.1.1
      Duet Wifi 2.03, Board Revision 1.04c
      Duet Web Contril 3.1.1, Panel Due Firmware 1.24
      I have had difficulty ever since I upgraded from the SKR Mini E3 V2.0. Multiple hours attempting to get the Duet 2 running. Is thee a way to do a function test on this board to see if it's compromised? Is there anyone that can help get this set up by remoting in for a fee? I am happy to pay for a resolution.
      Thank you.
      • Vetiundefined
        Veti
        can you elaborate on what is not working?
        i assume you mean firmware 2.03
        if you are using web control 3.1.1 you should also be using the 3.1.1 firmware.
          https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
          Or
          https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
          How far do you get?
          Harvdog1undefined 1 Reply Last reply Reply Quote 0
          • Harvdog1undefined
            Harvdog1
            This is copied from the Machine-Specific:
            Board: Duet 2 WiFi (2WiFi)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
            Duet WiFi Server Version: 1.23
            I may have written it down incorrectly. I am getting multiple errors, such as, "Error: Heater 1 fault: temperature rising much more slowly than the expected 1.8°C/sec, Error: G0/G1: insufficient axes homed,Error: Homing failed, Error: short-to-ground reported by driver(s) 2".
            The heater was working but not any longer. I dont think there is anything that is currently working, except for the PanelDue and thats after I had to reload the firmware.
            • Harvdog1undefined
              Harvdog1 @Phaedrux
              @Phaedrux I made it through all of the first link a couple of times. I searched for the info in the 2nd link, but could not find it. Thank you for providing that.
                Phaedrux Moderator @Harvdog1
                @Harvdog1 said in Did I fry my new board....:
                This means you haven't PID tuned the heater.
                This means you're trying to move an axis before it's been homed.
                This means an axis failed to trigger an endstop.
                That means either the wiring for driver 2 has the motor phase pairs miss-matched or the driver is damaged.
                • Harvdog1undefined
                  Harvdog1 @Phaedrux
                  @Phaedrux That sounds right, and regarding the possible damaged driver, is there a way to test that to see if I fried anything?
                    Have you used this to generate your first config set?
                    https://configtool.reprapfirmware.org/Start
                    Tuning heaters: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                    Identify stepper motor phases: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                    M122 will give a diagnostic report. Can you please provide that here?
                    M98 P"config.g" will check for any syntax errors in the config.g file that may not show up at startup. Post that as well.
                    Harvdog1undefined 2 Replies Last reply Reply Quote 0
                    • Harvdog1undefined
                      Harvdog1 @Phaedrux
                      @Phaedrux M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                      Board ID: 0JD0M-9P6M2-NW4SJ-6J9DL-3SN6N-9TSRK
                      Used output buffers: 3 of 24 (21 max)
                      Static ram: 27980
                      Dynamic ram: 93648 of which 192 recycled
                      Exception stack ram used: 264
                      Never used ram: 8988
                      Tasks: NETWORK(ready,384) HEAT(blocked,536) MAIN(running,1840) IDLE(ready,80)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:17:05 ago, cause: power up
                      Last software reset at 2021-01-03 02:15, reason: User, spinning module GCodes, available RAM 8836 bytes (slot 0)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                      Error status: 0
                      MCU temperature: min 21.6, current 23.2, max 23.7
                      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                      Date/time: 2021-01-03 13:26:56
                      Cache data hit count 1752787848
                      Slowest loop: 11.05ms; fastest: 0.13ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 3.7ms, write time 2.7ms, max retries 0
                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 201.68ms; fastest: 0.09ms
                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi firmware version 1.23
                        WiFi MAC address f4:cf:a2:e2:ea:ef
                        WiFi Vcc 3.46, reset reason Unknown
                        WiFi flash size 4194304, free heap 25432
                        WiFi IP address 192.168.1.200
                        WiFi signal strength -32dBm, reconnections 0, sleep mode modem
                        Socket states: 4 0 0 0 0 0 0 0
                        === Filament sensors ===
                        Extruder 0 sensor: no filament
                        Well yes, first check that you have the phase pairs correct and then test that motor on another driver to make sure it works, then try a different motor on driver 2 and see if it works.
                        Posting your config.g and homing files would be a good idea too so we can see what's going on.
                        • Harvdog1undefined
                          Harvdog1 @Phaedrux
                          @Phaedrux ; Configuration file for Duet WiFi (firmware version 3)
                          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sat Jan 02 2021 04:57:58 GMT-0800 (Pacific Standard Time)
                          M550 P"LoanHarvey" ; set printer name
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M92 X80.00 Y80.00 Z400.00 E80.00 ; set steps per mm
                          M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X30000.00 Y30000.00 Z300.00 E4800.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                          M906 X400 Y400 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S300 ; Set idle timeout
                          M208 X235 Y235 Z240 S0 ; set axis maxima
                          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                          ;M558 P0 H2.5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                          ;M557 X20:215 Y20:215 S64 ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                          M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                          M143 H1 S300 ; set temperature limit for heater 1 to 300C
                          M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
                          M106 P2 S1 H0:1 T45 ; set fan 2 value. Thermostatic control is turned on
                          ; Custom settings
                          M591 D0 C3 P1 E1 S1 ; Turn on functionality for a filament run-out switch
                            Do you have 2 Z motors connected or just one? If only 1, do you have the jumpers installed on the second motor connector?
                            If you have only one Z stepper motor, plug it in to the ZA connector, and plug two jumpers into the ZB connector. Duet 2 boards are normally supplied with these jumpers already fitted.
                            • Harvdog1undefined
                              Harvdog1 @Harvdog1
                              @Harvdog1 ; homeall.g
                              ; called to home all axes
                              G91 ; relative positioning
                              G1 H2 Z2.5 F6000 ; lift Z relative to current position
                              G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 H2 X5 Y5 F6000 ; go back a few mm
                              G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
                              G1 H1 Z-245 F360 ; move Z down stopping at the endstop
                              G90 ; absolute positioning
                              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                              ;G91 ; relative positioning
                              ;G1 Z2.5 F100 ; lift Z relative to current position
                              ;G90 ; absolute positioning
                              homex.g
                              ; called to home the X axis
                              G1 H2 Z4.5 F6000 ; lift Z relative to current position
                              G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass)
                              G1 H2 X5 F6000 ; go back a few mm
                              G1 H1 X-240 F360 ; move slowly to X axis endstop once more (second pass)
                              G1 H2 Z-2.5 F6000 ; lower Z again
                              ; homey.g
                              ; called to home the Y axis
                              G1 H1 Y-240 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                              G1 H2 Y5 F6000 ; go back a few mm
                              G1 H1 Y-240 F360 ; move slowly to Y axis endstop once more (second pass)
                              ; homez.g
                              ; called to home the Z axis
                              G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered
                              • Harvdog1undefined
                                Harvdog1 @Phaedrux
                                @Phaedrux One Z motor and the jumper is installed.
                                  Can you post a photo of driver 2 in case there's some damage visible?
                                  If the driver is damaged and you have a free extruder driver you can remap it to the z axis to get up and running.
                                  would become
                                  M584 X0 Y1 Z4 E3 ; set drive mapping
                                  What are the specs of your motors? What is the rated current?
                                  It's recommended to set the current to 60-85% of the motors rated current.
                                  Do the other drivers work?
                                  • Harvdog1undefined
                                    Harvdog1 @Phaedrux
                                    @Phaedrux I had been working on this exact thing, I finally got the X going, I could issue it a command to move left or right and it started working. Prior to that it and the other 2 would just make horrible noises. Once it was working on the X, i checked the connections on the wiring, meaning how the wires were plugged into the little plastic things. The others were not matching that one, so I started moving wires around trying to replicate the one what was working. That did not work, now that one good wire will not work on the x axis...
                                    • Vetiundefined
                                      Veti
                                      do not just randomly try wire position
                                      please follow this guide
                                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
                                      • Harvdog1undefined
                                        Harvdog1 @Phaedrux
                                        @Phaedrux
                                        • Vetiundefined
                                          Veti
                                          you configured e0heat but connected the heater to e1
                                          you really should be recrimping those connectors.
                                          • Harvdog1undefined
                                            Harvdog1 @Veti
                                            @Veti The crimper is in route. The hot end was connected like it is because I did it like one of the you tubers, he had his there. I see it now in position 1 and should be moved over to the left to zero.
                                            Thank you
