    BL Touch doesn't work
    Third-party add-ons
    771
    • Hiroakiundefined
      Hiroaki
      Hello.
      I am now making my second 3D printer by copying everything from my 1st printer.
      As the constructions are the same, it seems to be easy to make.
      But unfortunately I am having a problem the BL Touch.
      It's possible to trigger up and down by the macro files I made. But When I try "Homeall" the BL touch wouldn't make the trigger down.
      I copied config.g homeall.g etc.
      The firmwares are the same.
      What's else do I need to check ?
      Please help me.
      • Vetiundefined
        Veti
        post all relevant files.
        • Hiroakiundefined
          Hiroaki
          Hello.
          Yes, This is the config file.
          ; Configuration file for Duet WiFi (firmware version 2.03)(+bed conpensation)
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 04 2020 21:15:41 GMT+0900 (日本標準時)
          M550 P"CR2020" ; set printer name
          M669 K1 ; select CoreXY mode
          M551 P"3310" ; set password
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P1 S0 ; physical drive 1 goes forwards
          M569 P4 S0 ; physical drive 4 goes forwards
          M569 P5 S1 ; physical drive 5 goes forwards
          M569 P6 S1 ; physical drive 6 goes forwards
          M569 P7 S1 ; physical drive 7 goes forwards
          M584 X0 Y1 Z2:5:6:7 E3:4 ; set drive mapping
          M92 X100.00 Y100.00 Z400.00 E381.97:381.97 ; set steps per mm
          M566 X600.00 Y600.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z600.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X800.00 Y800.00 Z200.00 E500.00:500.00
          M906 X1500 Y1500 Z1200 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-17 Y0 Z0 S1 ; set axis minima
          M208 X375 Y340 Z615 S0 ; set axis maxima
          M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H3 F120 T6000 ; set Z probe type to BLTouch and the dive height + speeds
          G31 P25 X-25 Y0 Z4.75
          ; set Z probe trigger value, offset and trigger height
          M557 X10:340 Y10:330 S150
          ;leadscrews location
          M671 X410:410:-65:-65 Y35:305:305:35 S10 ; leadscrews at rear left, front left, front right, and rear right
          M106 P0 T45:65 H100:101:102 ; set fan speed half at MCU TEMP 45 Full at MCU TEMP 65
          M563 P1 D1 H1 F0 ; define tool 1
          M563 P2 H1 F0 ; define tool 2
          G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
          G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
          ; Laser filament sensor
          M591 D0 P5 C3 S1 R1:120 E10.0 ;extruder drive 0 is connected to E0 endstop input, enabled, 40% to 130% tolerance, 3mm detection length
          T0 ; select first tool
          And here is the homeall.g
          G91 ; relative positioning
          G1 H1 X-250 Y-250 F3000 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-250 ; home X axis
          G1 H1 Y-258 ; home Y axis
          G1 H1 X-10 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-10 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X50 Y50 F6000 ; go to first bed probe point and home Z
          G1 X0 Y0 F6000
          ;G90 ; absolute positioning
          Thank you.
            jay_s_uk
            What version of the firmware are you running?
            Output of M115 please
            Hiroakiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              what about the deploy and retract scripts?
              • Hiroakiundefined
                Hiroaki @jay_s_uk
                @jay_s_uk Hello
                It's
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
                Thanks
                • Hiroakiundefined
                  Hiroaki @Veti
                  @Veti Hello.
                  I don't understand the meaning of scripts, but
                  M280 P7 S90 and
                  M280 P7 S10 are working correctly....
                  • fcwiltundefined
                    fcwilt @Hiroaki
                    @Hiroaki said in BL Touch doesn't work:
                    @Veti Hello.
                    M280 P7 S90 and
                    Have you created, in the firmware System folder, the deployprobe.g and retractprobe.g files containing the appropriate M280 command?
                    • Hiroakiundefined
                      Hiroaki @fcwilt
                      @fcwilt Hello.
                      Oh, I got it.
                      Yes, Deployprobe.g is
                      M280 P7 S90
                      and retractprobe.g is
                      M280 P7 S10
                      Vetiundefined 2 Replies Last reply Reply Quote 1
                      • Vetiundefined
                        Veti @Hiroaki
                        @Hiroaki
                        are those file in the system folder and not the macro folder?
                        • Hiroakiundefined
                          Hiroaki @Veti
                          @Veti Sorry
                          I should have put it.
                          Yes, these are in SYS folder.
                          Regards
                          • Vetiundefined
                            Veti
                            can you issue M401 and M402 to to see if the deploy and retract work that way?
                            • Vetiundefined
                              Veti @Hiroaki
                              Deployprobe.g
                              did you spell that with a captial D?
                              please rename the file
                              • Hiroakiundefined
                                Hiroaki @Veti
                                @Veti
                                With M401 it's pulled up,
                                with M402 it's pulled down.
                                Vetiundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                • Hiroakiundefined
                                  Hiroaki @Veti
                                  @Veti
                                  It's with "d" actually...
                                  • Vetiundefined
                                    Veti
                                    can you post the output of M558?
                                    • Hiroakiundefined
                                      Hiroaki @Veti
                                      @Veti
                                      Z Probe type 9, input 0, invert no, dive height 3.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
                                      • Vetiundefined
                                        Veti @Hiroaki
                                        M401: Deploy z-probe
                                        M402: Retract z-probe
                                        I think there is your problem.
                                        change the content of deploy and retract
                                        Hiroakiundefined 2 Replies Last reply Reply Quote 0
                                        • Hiroakiundefined
                                          Hiroaki @Veti
                                          @Veti Oh I see, let me confirm it.
                                          It's funny because I copied all the files from my first printer which works correctly,...
                                          Anyway thank you very much!
                                            jay_s_uk @Hiroaki
                                            @Hiroaki M401 should deploy the probe and not pull it up.
                                            you have the contents of your deploy and retract files the wrong way round.
                                            Deploy probe should be S10 and retract S90
