    start.g -> end.g?
    Firmware wishlist
    1.1k
      A Former User
      I just stumbled across the info, that I could create within the sys folder or macros folder an optional file named start.g that would be executed before all else if a print gets started.
      Does the same hold true, if I create an (obviously optional) file called end.g that is the absolut last thing executed in the end of a print?
      • alankilianundefined
        alankilian
        Here's a page that describes start.g and other files and says when they are run.
        https://duet3d.dozuki.com/Wiki/Macros
          A Former User @alankilian
          @alankilian
          Thanks so much for the fast reply!
          So it seems there is a standardization for a start.g
          https://duet3d.dozuki.com/Wiki/Macros#Section_Start_pause_stop_and_power_fail
          within the "system" folderstructure
          but sadly not yet an end.g
          (I would like to have certain things done before and after a print without having the need to have in the slicer the call for a macro -> the reason is it would be more error proof to have certain things not in the hands of diffrent users slicing ther different models and maybe include/forget to call some start and end stuff but rather have it always on the printer no matter what file is printed)
          Guess I call for a feature-request then to think about adding this to 3.2-alpha or 3.3 or so?
            alankilian
            "stop.g is optional, but if present is run when a print finishes normally with an M0 command at the end of the print job."
            Will this do what you want automatically when a print finishes?
            I don't quite understand the " with an M0 command at the end of the print job." so I don't know if you would need to make sure that got added in the slicer or not.
            It might be fun just to try and see what happens. (My printer is unavailable or I'd test it myself.)
            A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
              @alankilian
              Thanks I read about this with some posts from phaedrux but there is a chance here at work that some people might forget to put that ("M0") into their slicer? The best would be to have the freedom to have all that end-stuff on the printer in an optional end.g so it does not matter who prints what. This is especially useful if you want to print the same file on different hardware that need different endings. What do you think?
                alankilian @A Former User
                @LB I think that would work best for you since you don't feel everyone will add the M0 in their slicer configuration.
                A Former User? 2 Replies Last reply Reply Quote 0
                  This post is deleted!
                    @alankilian
                    Where this idea comes from: We have at work here 3 different types of printers that will all get a new "brain"-board the duet3mini, but they are different in their size, buildup, hotend maybe (to be discussed) and I fear that everything that is machinerelated should be out of the way when we save the actual "print-files" on the company server (and of course always the raw-cad-file + the .stl-file) that way a once generated print file for let´s say:
                    • RRF-flavour
                    • ABSolut-xyz
                    • RELative-E-steps
                    • YOUR-DESIRED-material
                    or so will print even after years pretty fine, because basically there is only the actual print in the file with the filamenttemperature or the filament call and that´s it. Basically nothing about the hardware and homing and so on.
                    What do you think about that? Thanks so much for your input!
                    I think I wait a day or more to see what people might post here?
                      Phaedrux Moderator @alankilian
                      @alankilian said in start.g -> end.g?:
                      Yes you would need M0 at the end of the print file to execute stop.g
                      I'll move this to the wishlist since having an end.g that behaved similar to start.g without requiring a call would be a useful addition.
                      A Former User? 1 Reply Last reply Reply Quote 4
                        A Former User
                          A Former User @Phaedrux
                          More people giving this a vote up?
                          fcwiltundefined 1 Reply Last reply Reply Quote 3
                          • fcwiltundefined
                            fcwilt @A Former User
                            @LB said in start.g -> end.g?:
                            I think it is a grand idea and my gut says it would not be hard to do.
                            As you have observed we have start.g but I don't happen to use it because it occurs before any slicer generated code.
                            I endeavor to find how to have the slicer call my own "start" file just before it starts the actual printing so any code I include does not get overridden by slicer code.
                            For the firmware to do this it would have to analyze the slice code stream and determine when actual printing starts and I don't see that as happening.
                            The file end.g would work just fine since it occurs at what I see as the appropriate time.
                              A Former User @fcwilt
                              @fcwilt
                              Thanks!
                              (Any more voting this (optional system file) up, maybe for 3.3 or 3.4?)
                              Lucas
                              • oliofundefined
                                oliof
                                I would like to see an end.g because I use many slicers for specific printers or use cases, and tweaking endcode in the slicer is not always appropriate for me.
                                Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                  Phaedrux Moderator @oliof
                                  @oliof M0 at the end of the print file to execute stop.g is not sufficient?
