    Duet3 6CH + 3CH expansion board - Missing steps.
    153
    9.2k
      deckingman @evomotors
      @evomotors Which firmware version are you using? If by "latest official" you mean 3.1, then the step pulse frequency for expansion boards is appallingly bad. I'm told this is fixed in 3.2 but personally, I'm waiting for that to become a stable release before I try it. The only thing that surprises me is why so few people have noticed this problem.
      evomotorsundefined 1 Reply Last reply Reply Quote 1
        @evomotors, please upgrade to 3.2RC2, or wait a few days for the release of 3.2 stable.
        evomotorsundefined 1 Reply Last reply Reply Quote 0
        • evomotorsundefined
          evomotors @deckingman
          @deckingman said in Duet3 6CH + 3CH expansion board - Missing steps.:
          I guess not everyone who is using expansion and or tool boards running fast machines, or not running 1/16 micro-stepping. If I reduce to 1/8 it will be fine on printing speed of 80mm/s, but I will lose extruder accuracy, also 80mm/s is the slowest I ever print.
            evomotors @dc42
            Is it really going to be out in a few days?
              dc42 administrators @evomotors
              @evomotors said in Duet3 6CH + 3CH expansion board - Missing steps.:
              It's out already.
              evomotorsundefined 2 Replies Last reply Reply Quote 0
                evomotors @dc42
                Woo hoo! I will be upgrading in about an hour.
                  @evomotors Just be aware that RC= Release Candidate. That's not the same as a final, stable, release. Personally, I'll continue to wait.
                    Phaedrux Moderator @deckingman
                    Wait no longer.
                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
                      deckingman @Phaedrux
                      @Phaedrux Confused now 😕 . DC wrote earlier today quote "please upgrade to 3.2RC2, or wait a few days for the release of 3.2 stable."
                        I guess things progressed more smoothly than anticipated?
                          @deckingman
                          Well, 3.2 is official stable now.
                            @evomotors That's the quickest few days I've ever come across ☺ Let me know if it fixes your problem - then I'll give it a shot myself.
                              evomotors @dc42
                              @dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
                              It's out already.
                              Issue is not fixed!
                              M122 B1
                              Diagnostics for board 1:
                              Duet EXP3HC firmware version 3.2 (2021-01-05)
                              Bootloader ID: not available
                              Never used RAM 154848, free system stack 158 words
                              HEAT 90 CanAsync 94 CanRecv 84 TMC 30 MAIN 305 AIN 257
                              Last reset 01:37:18 ago, cause: power up
                              Last software reset data not available
                              Driver 0: position 0, 80.0 steps/mm,  standstill, reads 36849, writes 11 timeouts 0, SG min/max 0/0
                              Driver 1: position 226160, 344.0 steps/mm,  ok, reads 36831, writes 32 timeouts 0, SG min/max 0/1013
                              Driver 2: position 0, 80.0 steps/mm,  standstill, reads 36855, writes 11 timeouts 0, SG min/max 0/0
                              Moves scheduled 15696, completed 15694, in progress 1, hiccups 380
                              Next step interrupt due in 3606 ticks, enabled
                              VIN: 24.6V, V12: 12.3V
                              MCU temperature: min 43.8C, current 44.0C, max 44.2C
                              Ticks since heat task active 228, ADC conversions started 5838220, completed 5838219, timed out 0
                              Last sensors broadcast 0x00000000 found 0 232 ticks ago, loop time 0
                              CAN messages queued 35, send timeouts 0, received 68218, lost 0, free buffers 36
                                evomotors
                                Should I change something else in the config? CAN bus timing?
                                  I presume you are referring to the hiccup rate. It looks like the hiccup rate has reduced from 1 hiccup every ~5.6 moves to 1 hiccup every 41 moves. That's a seven-fold improvement!
                                  Hiccups are not lost steps, they are delayed steps. The delay may be only a few microseconds.
                                  I am still a little surprised that the hiccup rate is not lower. What speed are you printing at, and what nozzle size are you using?
                                  evomotorsundefined 2 Replies Last reply Reply Quote 1
                                    evomotors @dc42
                                    BMG direct drive extruder, 1/16 micro-stepping
                                    0.4 nozzle
                                    Current print speed 40mm/s perimeters (looks beautiful), 80mm/s infill (look like crap)
                                    When extruder connected directly to Duet3 I print perimeters and infill at < 200mm/s without issues.
                                      evomotors @dc42
                                      Sorry @dc42, but it looks like missing steps if you looking on the print.
                                        You haven't shown us the print! What makes you think whatever print problems you are seeing are caused by the hiccups? If it is, then presumably the problem is only 1/7 as bad as it was before.
                                          PS:
                                          The fact that the SG min is zero suggests to me that the moor may be stalling. What model of motor is it, and what motor current are you using? Are you sure the hot end temperature is high enough for the filament?
                                            evomotors @dc42
                                            Like I say if I plug in extruder to main (Duet3) board, extruder works as it should.
