    Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC
    1.5k
    • MikeGeppertundefined
      MikeGeppert @Phaedrux
      @Phaedrux The config file is pretty big and has lots of comments in it. I copied and pasted alot of the G-Code documentation to remind me what they do and what the parameters are. I can post tonight.
      For the Extruder I was just using the Buttons on the Web interface.
      For the "U" setup I used the console and "G1 U10". I did try "G1 E10" also when setup for the extruder and still got the issue.
      Now that I know the wiring is good and the stepper motor work like a champ I am really confused.
      Mike Geppert
        @Phaedrux OOO Cool - I will thanks...
        Is that what @Veti is trying to say with "rc-2" comment?
        Mike Geppert
          Veti was talking about release candidate 2 for 3.2, which is now defunct now that the final release of 3.2 is available.
            To be clear: if you use the buttons in the web interface to command extrusion, the extruder just vibrates?
            Please note, most of the extrusion speeds in the web interface are far too fast to extrude through a nozzle. They are intended for filament loading/unloading.
            Please post your config.g file.
            MikeGeppertundefined 1 Reply Last reply Reply Quote 0
              MikeGeppert @Veti
              @Veti The stepper motor is a Stepperonline 17HS08-1004S
              I am shooting for about 900mA.
              Mike Geppert
                @Phaedrux Here ya go (This is the version that has the "U" defined, the "E" is commented out):
                G90
                M83
                M550 P"X301"
                M669 K1
                M569 P0.0  S1 R0 D3 F3 B1 H200 V1000
                M569 P0.1  S1 R0 D3 F3 B1 H200 V1000
                M569 P0.2  S1 R0 D3 F3 B1 H200 V1000
                M569 P0.3  S1 R0 D3 F3 B1 H200 V1000
                M569 P0.4  S0 R0 D3 F3 B1 H200 V1000
                ;M569 P20.0 S0 R0 D3 F3 B1 H200 V1000
                ;M584 X0.0        Y0.1        Z0.2:0.3    E20.0
                ;M584 X0.0        Y0.1        Z0.2:0.3    E0.4
                M584 X0.0        Y0.1        Z0.2:0.3    U0.4
                ;M350 X256        Y256        Z256        E16         I0
                ;M92  X1280.00    Y1280.00    Z25600.00   E436.54
                ;M566 X900.00     Y900.00     Z60.00      E120.00
                ;M203 X12000.00   Y12000.00   Z6000.00    E1000.00
                M350 X256        Y256        Z256        U16         I0
                M92  X1280.00    Y1280.00    Z25600.00   U436.54
                M566 X900.00     Y900.00     Z50.00      U120.00
                M203 X12000.00   Y12000.00   Z6000.00    U1000.00
                ;M201 X5000.00    Y5000.00    Z500.00    E5000.00
                M201 X5000.00    Y5000.00    Z500.00    U5000.00
                M906 X{2000*0.8}
                M906 Y{2000*0.8}
                M906 Z{2000*0.8}
                ;M906 E{1000*0.9}
                M906 U{1000*0.9}
                M906 I30
                M84 S30
                M208 X0:330 Y0:330  Z-1:330
                ; M574 Z1 S2 P"!20.io0.in"
                M574 Z0 P"nil"
                M574 X1 Y1 S3
                M915 X Y S3  F0 H200 T1 R0
                M915 Z   S20 F0 H200 T1 R0
                ;M558 P8 F300 R0.4 C"!20.io0.in"
                M558 P8 F300 R0.4 C"!io1.in"
                G31  P100 X0 Y0 Z-0.180
                M557 X0:300 Y0:300 P5:5
                M671 X-25:314 Y157:157 S10
                M308 S0 P"temp0"    Y"thermistor" A"Bed"     T100000 B3950 H14
                ;M308 S1 P"20.temp0" Y"thermistor" A"Hot End" T100000 B4267 ; H-26
                M308 S1 P"temp1"    Y"thermistor" A"Hot End" T100000 B4267
                M308 S2             Y"mcu-temp"   A"MCU"
                M950 H0 C"out0"    T0
                ;M950 H1 C"20.out0" T1
                M950 H1 C"out1"    T1
                ;M307 H0 R0.293  C615.6 D2.40 S1.00 V24.1
                M307 H0 R0.300  C545.2 D2.36 S1.00 V24.1
                ;M307 H1 R36.204 C15.7  D1.22 S1.00 V24.2
                M307 H1 R3.201  C197.5 D5.04 S1.00 V24.2
                M140 H0
                M143 H0 S80  X0
                M143 H1 S280 X1
                ;M950 F0 C"20.out2" Q500
                ;M950 F1 C"20.out1" Q500
                M950 F0 C"out7"             Q500
                M950 F1 C"out8"             Q500
                M950 F2 C"!out4+^out4.tach" Q500
                M106 P0 S0 H-1 C"Part Cooling"
                M106 P1 S1 H1  C"Hot End"       T50
                M106 P2 S2 H-1 C"Case"
                M563 P0 S"Hot End" D0 H1 F0:1
                G10 P0 X0 Y0 Z0
                G10 P0 R0 S0
                M451
                ; Setup NeoPixel
                M150 X1 Q3000000
                M150 S2 F0 P128 R255 U000 B000
                G4   S1
                M150 S2 F0 P128 R000 U255 B000
                G4   S1
                M150 S2 F0 P128 R000 U000 B255
                G4   S1
                M150 S1 F1 P128 R255 U255 B000
                M150 S1 F0 P128 R000 U000 B255
                G4   S1
                M150 S1 F1 P128 R255 U000 B255
                M150 S1 F0 P128 R255 U255 B000
                G4   S1
                M150 S1 F1 P128 R000 U255 B255
                M150 S1 F0 P128 R255 U000 B255
                G4   S1
                M150 S1 F1 P128 R255 U140 B000
                M150 S1 F0 P128 R000 U255 B255
                G4   S1
                M150 S1 F1 P128 R255 U255 B255
                M150 S1 F0 P128 R255 U140 B000
                G4   S1
                M150 S2 F0 P128 R255 U255 B255
                G4   S2
                ;M575 P1 S1 B57600
                T0
                Mike Geppert
                  @Phaedrux Hmmm the update did not go well. Trying to recover the system now.
                  Mike Geppert
                    MikeGeppert @dc42
                    @dc42 Thanks for the response.
                    If I do a "G1 E10" I get the same effect.
                    I actually removed the stepper from the extruder and it is just sitting on the bed now. I am looking at the gear on the motor.
                    If I set it up as a "U" it turns as expected with "G1 U10".
                    If I set up as a "E" it vibrates with almost no torque. I can put my finger on the gear and feel almost no torque at all.
                    Mike Geppert
                      Can you send M98 P"config.g" and post the response?
                      Your spacing is very odd and I wonder if there is a non-standard character in there causing something to barf.
                      Could you maybe try a basic config generated by the online config tool just to rule out the config?
                      https://configtool.reprapfirmware.org/Start
                        @Phaedrux Is this right? I was expecting an rc2 somewhere:
                        1/5/2021, 10:42:56 PM M115
                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-01-05
                        Mike Geppert
                          Yup that is correct. 3.2 RC2 has been replaced by 3.2 final, which you appear to be using.
                            @Phaedrux said in Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC:
                            M98 P"config.g"
                            1/5/2021, 10:44:40 PM M98 P"config.g"
                            Kind of unexciting? Its got a green background I think that is a good thing?
                            Mike Geppert
                              @Phaedrux Great Thanks!
                              Same issue. "U" works, "E" not so much...
                              Mike Geppert
                                Hmm.. no, there should be a few messages if everything is good and some errors if it's not. I think something is amiss with your config.
                                Can you try a basic config generated by the config tool?
                                MikeGeppertundefined 2 Replies Last reply Reply Quote 0
                                  @Phaedrux Sure - give me like 30 min or so.
                                  Mike Geppert
                                    MikeGeppert @MikeGeppert
                                    @MikeGeppert said in Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC:
                                    M98 P"config.g"
                                    The lights blink like I expect when I run the command. What should give an output?
                                    Mike Geppert
                                      If everything executes cleanly you should get something like
                                      M98 PCONFIG.G
                                      HTTP is enabled on port 80
                                      FTP is disabled
                                      TELNET is disabled
                                      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 893C.
                                      Well, actually, looking at your config it looks like you may not have any of the network commands and your heaters may not be overpowered.
                                        And for good measure can you post the results of M122 as well when configured as E?
                                        We could also start sending the basic axis setup commands by themselves to see what the firmware thinks is configured and see if it meets expectation.
                                        M201, M203, M566, M584, etc etc
                                        But I think we may get good results from a clean config.
                                          Ok so a generated Config file seems to work.
                                          Hmmm - I will start modifying it slowly to see what broke it.
                                          Mike Geppert
                                            M98 PCONFIG.G
                                            FTP is disabled
                                            TELNET is disabled
                                            With the generated config file it also does not print anything to the console.
                                            Mike Geppert
