    Endstop wired in series, RRF3
    • Anto0131undefined
      Anto0131
      Hello all,
      I usually find my answers in the previous posts but didn't have any luck with this one.
      I run RRF3 (3.2) with a duet Ethernet.
      I want to use 2 endstops for Y axis and 2 for Z axis (Big 2d cartesian printer with 2 Y motors, 2 Z motors and independent dual X axis for two head).
      Attached is the simple schematic of what I want to achieve with my 2 endstop linked in series. My endstop are mechanical NC switch. In my config, I have the M574 configured like this,
      M574 Y1 S1 P"ystop+e1stop"
      M574 Z1 S1 P"ystop+e1stop"
      When I perform the homeall, it goes through the X and Y but give me this error on the Z axis :
      G28
      Error: Failed to enable endstops
      When I home X and Y, I move away from the endstop so its not an hardware problem (I also check the endstop with the leds and its all good for Z and Y).
      homeall.g looks like :
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-480 Y-480 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-480 Y-480 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G90
      G0 X-40 Y0              ; move away from the endstop
      G91
      G1 H1 Z-405 F360        ; move Z down stopping at the endstop
      G90                     ; absolute positioning
      G92 Z-2.4                  ; Adjust Z offset (if + then substract to this value)
      G1 Z20
      Can someone help me with this?
      Thank you.
      A.
        jay_s_uk
        Because you can't have a pin name used more than once.
        If you run M98 P"config.g" you'll see the error.
        You'll have you change your wiring.
        Or, map the endstops in the homing files.
        • Anto0131undefined
          Anto0131
          I could remap the endstop in the homeall file? Its not elegant but i guess it would do the trick.
          How do I do that? If I send M574 Z1 S1 P"ystop+e1stop" it will still give me the error of already having a sensor on the ystop.
          thanks.
            You may have to unbind the pin first by giving it nil as a pin name.
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
            Anto0131undefined 1 Reply Last reply Reply Quote 0
            • Anto0131undefined
              Anto0131 @Phaedrux
              @Phaedrux Wow this is working! I added this before the Z homing lines and everything work properly.
              I also added the switch back to initial mapping at the end (so I don't do this trick to the homey.g also)
              ; homeall.g
              ; called to home all axes
              G90
              G0 X-40 Y5
              G91
              M574 Y1 S1 P"nil"
              G1 Z20
              M574 Z1 S1 P"nil"
              Thank you Jay and Phaedrux for your help.
              A.
                Now you've learned the power of on the fly configuration!
