    HELP WITH HEIGHT MAP HAS SUBSTANTIAL Z OFFSET WARNING
    1.5k
    • Vetiundefined
      Veti
      @Jaw8850 said in HELP WITH HEIGHT MAP HAS SUBSTANTIAL Z OFFSET WARNING:
      here is my Bed Thermistor (E3D mains powered heat bed with E3D thermistor (B4725 from E3D documentation)
      can you link that, because its wrong. its missing the C parameter
      see
      https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_Thermistor_parameters
      Jaw8850undefined 1 Reply Last reply Reply Quote 0
      • Jaw8850undefined
        Jaw8850 @Veti
        @Veti here is link to Wiki for Duet (I'm running Duet 2 Ethernet board) says Duet 3 needs C but Duet 2 doesnt?
        ![edbe464d-5f3b-4a9f-a04d-de6bcec8ed4c-image.png]
        (/assets/uploads/files/1610138829376-edbe464d-5f3b-4a9f-a04d-de6bcec8ed4c-image.png)
        • Vetiundefined
          Veti @Jaw8850
          it doesnt say that at all.
          the duet 2 example is for a completely different thermistor.
          • Jaw8850undefined
            Jaw8850 @Veti
            @Veti
            I see it now. I used the configurator then did PID and thought I was good. How does this look?
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" Q10 T0 ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 R1.115 C329.1 D4.73 S1.00 V24.2 ; disable bang-bang mode for the bed heater and set PWM limit
            M143 H0 S200 ; set temperature limit for heater 0 to 200C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp
            M307 H1 R1.415 C284.6 D6.03 S1.00 V24.2 ; disable bang-bang mode for heater and set PWM limit
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            M570 S360 ; Heater fault detections allow 1 minute
            • Vetiundefined
              Veti
              dont forget to pid tune again. because you were operating at the wrong temperature
              • Jaw8850undefined
                Jaw8850 @Veti
                @Veti
                I will definitely do that. I'm just fighting this homing mess. G28 Z throws an error and says insufficient axes homed. this is after I did G28 Y and G28 X it won't let me use G28 Z
                • Vetiundefined
                  Veti
                  thats because you modified the homez and removed the H2 part
                  • Jaw8850undefined
                    Jaw8850 @Veti
                    @Veti
                    Thank You!!!!!!!!! I truly appreciate your help. Now I have a baseline I can build from. PID tune in progress
                    • Jaw8850undefined
                      Jaw8850
                      @Veti
                      OK, I have re-run PID tuning on bed 1st then hotend. I have trimmed down my config files I believe. I am running G32 which homes all then probes center then probes each side lead screws. I then run G1 X137 Y156 Z5 to move the print head to the center of the bed. I then run G30 to get a zero value followed by G29. When done my mesh is a mess and the original z in the center of the bed is WAY BELOW 0, like -.962. any ideas what may cause this? I am running a mini IR probe and probing each spot 5 times with an S value of 0. I am probing a black textured pei sheet.
                      config.g
                      bed.g
                      homeall.g
                      homez.g
                        Can you show a photo of your bed surface?
                        Was it working at all before you updated from 2.05?
                        Taking a look at your latest files now.
                          I notice you have S0 in your M558. Delete that. The default is 0.03 and I don't think 0 is a valid way to use it.
                          Can you also post the results of M122 and M98 P"config.g"?
                            By the way, if you're using stall detection for X and Y you really only need to make a single pass. A slower second pass makes no sense in this context since a good stall needs a short sharp shock.
                            M913 X50 Y50 Z50	    ; drop motor currents to 50%
                            M915 X Y S3 R0	    	; set sensitivity to +3 unfiltered
                            G1 H1 X-305  F4800    	; move X all the way left and stop at end
                            G4 P250                 ; wait 250msec
                            G1 X10 F12000	        ; go back a few mm
                            G1 H1 X-305  F4800    	; move slowly to X axis endstop once more (second pass)
                            G4 P500                 ; wait 500msec
                            G1 H1 Y-305  F4800	    ; move Y all the way forward and stop at end
                            G1 Y10 F12000	        ; go back a few mm
                            G1 H1 Y-305  F4800    	; move slowly to Y axis endstop once more (second pass)
                            G0 X127 Y142	F12000  ; go to back center of bed for measurement
                            • Jaw8850undefined
                              Jaw8850 @Phaedrux
                              @Phaedrux
                              Thank you, I've taken out the S, and changed up Home All and HomeY and HomeX
                              Here is M122
                              1/8/2021, 8:06:43 PM	M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later
                              Board ID: 08DGM-9T6BU-FG3S0-7JTD8-3S06N-KB4BD
                              Used output buffers: 3 of 24 (16 max)
                              Static ram: 23460
                              Dynamic ram: 68864 of which 100 recycled
                              Never used RAM 19656, free system stack 104 words
                              Tasks: NETWORK(ready,185) HEAT(blocked,309) MAIN(running,400) IDLE(ready,19)
                              Owned mutexes:
                              Last reset 00:30:06 ago, cause: software
                              Last software reset at 2021-01-08 19:36, reason: User, GCodes spinning, available RAM 19864, slot 2
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 33.8, current 34.6, max 35.5
                              Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: position 81011, standstill, SG min/max 0/352
                              Driver 1: position 5994, standstill, SG min/max 0/348
                              Driver 2: position 16295, standstill, SG min/max 0/1023
                              Driver 3: position 0, standstill, SG min/max not available
                              Driver 4: position 0, standstill, SG min/max 0/1023
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-01-08 20:06:40
                              Cache data hit count 2734090471
                              Slowest loop: 295.16ms; fastest: 0.17ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 2.0ms, write time 18.7ms, max retries 0
                              DMs created 83, maxWait 392107ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 492, completed moves 492, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 6], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 295.42ms; fastest: 0.02ms
                              HTTP sessions: 1 of 8
                              Interface state active, link 100Mbps full duplex
                              homeall (1).g
                              homex.g
                              homey.g
                              • Jaw8850undefined
                                Jaw8850 @Phaedrux
                                @Phaedrux
                                Here is result of M98"config.g"
                                1/8/2021, 8:08:09 PM m98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                Error: Pin 'fan1' is not free
                                Error: Fan number 2 not found
                                  G30 Z ; home z by probing the bed
                                  G1 H1 Z3 ; lower bed for clearance
                                  In your homeall there are two things that aren't right.
                                  First G30 doesn't need Z. G30 by itself just means probe z at the current location.
                                  and you definitely don't want G1 H1 Z3 there. The H1 is a homing move. In your case both these things don't really have any effect, but figured you should know.
                                  If you want to raise the Z axis to a certain height at that point just use G1 Z
                                    Phaedrux Moderator @Jaw8850
                                    Looks like you've got some fan problems too.
                                    M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                                    M106 P1 S1 H1 T70                                  ; set fan 1 value. Thermostatic control is turned on
                                    M950 F2 C"fan1" Q500                               ; create fan 2 on pin fan1 and set its frequency
                                    M106 P2 S0.5 H1 T60                                ; set fan 2 value. Thermostatic control is turned on
                                    You're using fan1 twice. One of them is probably supposed to be fan2.
                                      The position that you use to probe the Z axis should be the same between homeall and homez. It should also be the same point you use for the G30 before running G29.
                                      G1 X137 Y156 F2000 ; put head over the centre of the bed, or wherever you want to probe
                                      Jaw8850undefined 3 Replies Last reply Reply Quote 0
                                      • Jaw8850undefined
                                        Jaw8850 @Phaedrux
                                        @Phaedrux
                                        Got the fans sorted, thank you
                                        1/8/2021, 8:20:45 PM m98 P"config.g"
                                        FTP is disabled
                                        TELNET is disabled
                                        and I adjusted the Homez and homeall to match
                                        config.g
                                        bed.g
                                        homeall.g
                                        homez.g
                                        • Jaw8850undefined
                                          Jaw8850 @Phaedrux
                                          @Phaedrux
                                          Reference a Mesh Bed Leveling Macro, does this look right? I commented out the temperature settings until I know it's probing correctly etc.
                                          ;M140 S70 ; Start Heating the bed
                                          ;M109 S200 ; Start Heating the nozzle
                                          G32 ; Home all & adjust lead screws
                                          G1 X137 Y156 Z5 ; move to center of the bed
                                          G30 ; probe Z
                                          G29 ; run mesh bed leveling
                                          G1 H1 X240 Y240 Z50
                                          ;M140 S0
                                          ;M109 S0
                                          • Jaw8850undefined
                                            Jaw8850 @Phaedrux
                                            @Phaedrux
                                            Here is a picture of my bed surface. I also have a buildtak flexplate with PEI on it but it's translucent yellow and shiny in spots, I was going to wetsand it with 1000 grit to try and dull it out if I can't get this textured sheet to work
