    Rotary delta calibration not implemented?
    LPC
    3.6k
    • Orang_undefined
      Orang_
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 22:12:55 GMT+0200 (Восточная Европа, стандартное время)
      G28
      G30 P0 X0.00 Y80.00 Z-99999 H33.385
      G30 P1 X69.28 Y-40.00 Z-99999 H33.385
      G30 P2 X-69.28 Y-40.00 Z-99999 H33.385
      G30 P3 X0.00 Y40.00 Z-99999 H33.385
      G30 P4 X34.64 Y-20.00 Z-99999 H33.385
      G30 P5 X-34.64 Y-20.00 Z-99999 H33.385
      G30 P6 X0 Y0 Z-99999 S6
      • Orang_undefined
        Orang_ @Phaedrux
        G90                                            ; send absolute coordinates...
        M83                                            ; ...but relative extruder moves
        M550 P"Orang_"                                 ; set printer name
        ;M669 K10 Uxx    Lxx  Rrr    Aaa: bb Hxx
        M669 K10 U170 L319 R55.94 A-45:52 B135 H439.2 X-60,Y60,Z180
        M666 X-1.2 Y-0.7 Z1.4
        M569 P0 S1                                     ; physical drive 0 goes forwards using default driver timings |D3 stealthChop2
        M569 P1 S1                                     ; physical drive 1 goes forwards using default driver timings
        M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
        M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
        M584 X0 Y1 Z2 E3                               ; set drive mapping
        M350 X64 Y64 Z64 E64                           ; configure microstepping with interpolation
        M92 X1761.5 Y1761.5 Z1761.5 E1488.59              ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z500.00 E1000.00       ; set accelerations (mm/s^2)
        M906 X700 Y700 Z700 E600                       ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                        ; Set idle timeout
        M208 Z-2:270                                  ; set minimum Z
        M574 X2 S1 P"!xstopmax"                            ; configure active-high endstop for low end on X via pin xstop
        M574 Y2 S1 P"!ystopmax"                            ; configure active-high endstop for low end on Y via pin ystop
        M574 Z2 S1 P"!zstopmax"                            ; configure active-high endstop for low end on Z via pin zstop
        M558 P5 C"^zstop" H5 F120 T2000 X0 Y0 Z1
        M557 R80 S20                                   ; define mesh grid
        G31 X0 Y0 Z33.385 P25
        M563 P0 D0 H1 F0                               ; define tool 0
        G10 P0 X0 Y0 Z                               ; set tool 0 axis offsets
        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
        M563 P2 S"2rr" D0 H1 F0                     ; define tool 2
        G10 P2 X0 Y0 Z-23.3                                ; set tool 2 axis offsets
        G10 P2 R0 S0
        M563 P5 S"TEST" D0 H1 F0                     ; define tool 2
        G10 P2 X0 Y0 Z-29.3                                ; set tool 2 axis offsets
        G10 P2 R0 S0
        T2
        M575 P1 B57600 S0
        Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • Orang_undefined
          Orang_
          RepRapFirmware 3.2-RC2 Port for LPC
          Have you gone over your printer mechanics? - Yes
          https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_Rotary_Delta
          https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
          " - yes
            Moved to the LPC port forum since that may be relevant.
            Can you also send M98 P"config.g" and post the results?
            Also your homedelta.g?
            • Orang_undefined
              Orang_
              ; homedelta.g
              G91                        ; relative positioning
              G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
              G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
              G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
              ;G1 Z-5 F1000               ; move down a few mm so that the nozzle can be centred
              G90                        ; absolute positioning
              • Orang_undefined
                Orang_
                M98 P "config.g"
                Warning: Macro file "config.g" not found
                  Phaedrux Moderator @Orang_
                  @Orang_ said in Rotary delta calibration not implemented?:
                  M98 P "config.g"
                  Was there a space between the P and " when you sent the command?
                  Orang_undefined 1 Reply Last reply Reply Quote 0
                  • Orang_undefined
                    Orang_ @Phaedrux
                    @Phaedrux
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                      Thanks. I'm afraid that's the extent of my delta knowledge and I know even less about the LPC port.
                      A video may help and the results of M122 never hurt.
                      Is RC2 the latest for the LPC port, or can you update to 3.2 final?
                      • Orang_undefined
                        Orang_ @Phaedrux
                        @Phaedrux https://drive.google.com/file/d/1xEPkmPwHct_ov90Fp8C5e6YM0wNrkLN9/view?usp=sharing
                        • Orang_undefined
                          Orang_
                          @Phaedrux said in Rotary delta calibration not implemented?:
                          yes, i can
                            From your video is seems like it's triggering the probe, but then skipping steps on one arm when it tries to return to the dive height causing it to lurch.
                            Are you sure there's no slipping grub screw or something like that?
                            jay_s_ukundefined Orang_undefined 2 Replies Last reply Reply Quote 0
                            • Orang_undefined
                              Orang_ @Orang_
                              @Orang_
                              	M122
                              RepRapFirmware for LPC176x based Boards (biquskr_1.3) version 3.2-beta4.1_1 running on LPC176x at 100Mhz
                              Used output buffers: 3 of 16 (11 max)
                              Static ram: 5044
                              Dynamic Memory (RTOS Heap 5): 2056 free, 1992 never used
                              Never used RAM 80, free system stack 6 words
                              Tasks: NETWORK(blocked,196) HEAT(blocked,242) MAIN(running,353) IDLE(ready,20)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:55:21 ago, cause: [software]
                              Last software reset at 2021-01-11 22:25, reason: User, GCodes spinning, available RAM 256, slot 1
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00428000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                              Error status: 0x00
                              Supply voltage: under voltage events: 0
                              Driver 0: position 43414, no-driver-detected
                              Driver 1: position 43808, no-driver-detected
                              Driver 2: position 41828, no-driver-detected
                              Driver 3: position 0, no-driver-detected
                              Driver 4: position 0
                              Driver 5: position 0
                              Driver 6: position 0
                              Date/time: 2021-01-11 23:20:45
                              Slowest loop: 95.26ms; fastest: 0.12ms
                              Step timer: target 2615712365 count 3321023289 delta -705310924 late 0
                              USBSerial connected 0
                              ADC not ready 2 ADC error threshold 10 ADC Init 1
                              Ints: 0; Calls 0; fast: 4294967295uS; slow 0uS adj 0 bad 0 big delta 0
                              PWM Channels
                              Delta -1446546330 Start -1 End -1
                              === Storage ===
                              Free file entries: 4
                              SD card 0 detected
                              SD card longest read time 5.7ms, write time 5.3ms, max retries 0
                              FreeDm 100 (min 97), maxWait 1181857ms, bed compensation in use: none, comp offset 0.000
                              === DDARing ===
                              Scheduled moves 91, completed moves 91, hiccups 39525, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                              Bed heaters = 0, chamberHeaters = -1
                              Heater 1 is on, I-accum = 0.0
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 322.64ms; fastest: 0.00ms
                              Responder states: HTTP(2) HTTP(0)
                              HTTP sessions: 1 of 2
                              - WiFi -
                              Network state is active
                              WiFi firmware version 1.25B0-01L-D
                              WiFi MAC address e0:3f:49:23:39:c4
                              WiFi Vcc 2.93, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 35560
                              WiFi IP address 192.168.1.97
                              WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00181001
                              Socket states: 0 0
                                jay_s_uk @Phaedrux
                                There should be no differences between the LPC port and the normal version in terms of kinematics etc that I'm aware of. There are some other restrictions but that's mainly due to memory.
                                  jay_s_uk
                                  You can upgrade to 3.2 final from here https://github.com/gloomyandy/RepRapFirmware/releases/tag/v3.2_1
                                  • Orang_undefined
                                    Orang_ @Phaedrux
                                    it happens only with delta calibration and mesh compensation, with normal use it is not observed
                                    • Orang_undefined
                                      Orang_
                                      RepRapFirmware 3.2 does not solve the problem(((
                                        M350 X64 Y64 Z64 E64 ; configure microstepping with interpolation M92 X1761.5 Y1761.5 Z1761.5 E1488.59 ; set steps per mm
                                        Pardon my ignorance on the LPC port, but perhaps you can try using x16 microstepping to get a baseline?
                                        I notice in your M122 there are a lot of hiccups which can mean skipped steps, so reducing the microstepping could help
                                        hiccups 39525
                                        • Orang_undefined
                                          Orang_ @Phaedrux
                                          hiccups 39525
                                          The printer behaves the same way only with delta calibration and mesh compensation, no problems with printing and moving, I do not think the problem is microstepping but I can try
                                          jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                            jay_s_uk @Orang_
                                            @Orang_ yea, I really wouldn't run anything higher than x16 on an LPC
