    Rotary delta calibration not implemented?
    LPC
    3.6k
      Thanks. I'm afraid that's the extent of my delta knowledge and I know even less about the LPC port.
      A video may help and the results of M122 never hurt.
      Is RC2 the latest for the LPC port, or can you update to 3.2 final?
      Orang_undefined 1 Reply Last reply Reply Quote 0
      • Orang_undefined
        Orang_ @Phaedrux
        @Phaedrux https://drive.google.com/file/d/1xEPkmPwHct_ov90Fp8C5e6YM0wNrkLN9/view?usp=sharing
        • Orang_undefined
          Orang_
          @Phaedrux said in Rotary delta calibration not implemented?:
          yes, i can
            From your video is seems like it's triggering the probe, but then skipping steps on one arm when it tries to return to the dive height causing it to lurch.
            Are you sure there's no slipping grub screw or something like that?
            jay_s_ukundefined Orang_undefined 2 Replies Last reply Reply Quote 0
            • Orang_undefined
              Orang_ @Orang_
              @Orang_
              	M122
              RepRapFirmware for LPC176x based Boards (biquskr_1.3) version 3.2-beta4.1_1 running on LPC176x at 100Mhz
              Used output buffers: 3 of 16 (11 max)
              Static ram: 5044
              Dynamic Memory (RTOS Heap 5): 2056 free, 1992 never used
              Never used RAM 80, free system stack 6 words
              Tasks: NETWORK(blocked,196) HEAT(blocked,242) MAIN(running,353) IDLE(ready,20)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:55:21 ago, cause: [software]
              Last software reset at 2021-01-11 22:25, reason: User, GCodes spinning, available RAM 256, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00428000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 0x00
              Supply voltage: under voltage events: 0
              Driver 0: position 43414, no-driver-detected
              Driver 1: position 43808, no-driver-detected
              Driver 2: position 41828, no-driver-detected
              Driver 3: position 0, no-driver-detected
              Driver 4: position 0
              Driver 5: position 0
              Driver 6: position 0
              Date/time: 2021-01-11 23:20:45
              Slowest loop: 95.26ms; fastest: 0.12ms
              Step timer: target 2615712365 count 3321023289 delta -705310924 late 0
              USBSerial connected 0
              ADC not ready 2 ADC error threshold 10 ADC Init 1
              Ints: 0; Calls 0; fast: 4294967295uS; slow 0uS adj 0 bad 0 big delta 0
              PWM Channels
              Delta -1446546330 Start -1 End -1
              === Storage ===
              Free file entries: 4
              SD card 0 detected
              SD card longest read time 5.7ms, write time 5.3ms, max retries 0
              FreeDm 100 (min 97), maxWait 1181857ms, bed compensation in use: none, comp offset 0.000
              === DDARing ===
              Scheduled moves 91, completed moves 91, hiccups 39525, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
              Bed heaters = 0, chamberHeaters = -1
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 322.64ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0)
              HTTP sessions: 1 of 2
              - WiFi -
              Network state is active
              WiFi firmware version 1.25B0-01L-D
              WiFi MAC address e0:3f:49:23:39:c4
              WiFi Vcc 2.93, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 35560
              WiFi IP address 192.168.1.97
              WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00181001
              Socket states: 0 0
                jay_s_uk @Phaedrux
                There should be no differences between the LPC port and the normal version in terms of kinematics etc that I'm aware of. There are some other restrictions but that's mainly due to memory.
                  jay_s_uk
                  You can upgrade to 3.2 final from here https://github.com/gloomyandy/RepRapFirmware/releases/tag/v3.2_1
                  • Orang_undefined
                    Orang_ @Phaedrux
                    it happens only with delta calibration and mesh compensation, with normal use it is not observed
                    • Orang_undefined
                      Orang_
                      RepRapFirmware 3.2 does not solve the problem(((
                        Phaedrux Moderator @Orang_
                        @Orang_ said in Rotary delta calibration not implemented?:
                        M350 X64 Y64 Z64 E64 ; configure microstepping with interpolation M92 X1761.5 Y1761.5 Z1761.5 E1488.59 ; set steps per mm
                        Pardon my ignorance on the LPC port, but perhaps you can try using x16 microstepping to get a baseline?
                        I notice in your M122 there are a lot of hiccups which can mean skipped steps, so reducing the microstepping could help
                        hiccups 39525
                        • Orang_undefined
                          Orang_ @Phaedrux
                          hiccups 39525
                          The printer behaves the same way only with delta calibration and mesh compensation, no problems with printing and moving, I do not think the problem is microstepping but I can try
                          jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            jay_s_uk @Orang_
                            @Orang_ yea, I really wouldn't run anything higher than x16 on an LPC
                              Yes, and it's the quick movements to raise Z after probing that it's skipping, and those moves would be generating the most step pulses. The hiccups are indicating an issue caused by too high microstepping values.
                              If this isn't the problem I'll be surprised.
                              • Orang_undefined
                                Orang_ @Phaedrux
                                M350 X16 Y16 Z16 E16
                                M92 X440.375 Y440.375 Z440.375 E440.375
                                How to reduce the speed of movement during calibration
                                  Are you still getting hiccups in M122 after a fresh reboot and running G32?
                                  You can add some commands to bed.g to lower the acceleration, jerk, and max speed before the probing and then return it to normal again at the end.
                                  • Orang_undefined
                                    Orang_ @Phaedrux
                                    m122
                                    RepRapFirmware for LPC176x based Boards (biquskr_1.3) version 3.2_1 running on LPC176x at 100Mhz
                                    Static ram: 4956
                                    Dynamic Memory (RTOS Heap 5): 8488 free, 8448 never used
                                    Allocations: 212 Frees: 51
                                    Never used RAM 256, free system stack 16 words
                                    Tasks: NETWORK(ready,195) HEAT(blocked,243) MAIN(running,354) IDLE(ready,21)
                                    Last reset 00:13:28 ago, cause: [power up][reset button]
                                    Last software reset at 2021-01-11 23:51, reason: User, GCodes spinning, available RAM 256, slot 1
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00428000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    Driver 0: position -21712, standstill, SG min/max 0/398, error r/w 2/0, ifcnt 19, cnt r/w 25110/19, timeout 0, failedOp 0xff
                                    Driver 1: position -21712, standstill, SG min/max 0/270, error r/w 1/0, ifcnt 20, cnt r/w 25109/20, timeout 0, failedOp 0xff
                                    Driver 2: position -21712, standstill, SG min/max 0/302, error r/w 3/0, ifcnt 19, cnt r/w 25108/19, timeout 0, failedOp 0xff
                                    Date/time: 2021-01-12 00:08:22
                                    Slowest loop: 69.25ms; fastest: 0.12ms
                                    Step timer: target 216165456 count 808616327 delta -592450871 late 0
                                    PWM Channels
                                    Delta 1234083299 Start -1 End -1
                                    === Storage ===
                                    SD card 0 detected
                                    SD card longest read time 6.8ms, write time 5.9ms, max retries 0
                                    DMs created 40, maxWait 72981ms, bed compensation in use: none, comp offset 0.000
                                    === DDARing ===
                                    Scheduled moves 38, completed moves 38, hiccups 37, stepErrors 0, LaErrors 0, Underruns [0, 0, 6], CDDA state -1
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 240.66ms; fastest: 0.00ms
                                    Responder states: HTTP(0) HTTP(0)
                                    - WiFi -
                                    WiFi flash size 4194304, free heap 35656
                                    WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    Socket states: 0 0
                                    • Orang_undefined
                                      Orang_
                                      ; bed.g
                                      ; called to perform automatic delta calibration via G32
                                      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 22:12:55 GMT+0200 (Восточная Европа, стандартное время)
                                      G1 F500
                                      G0 F500
                                      G28
                                      G30 P0 X0.00 Y80.00 Z-99999 H33.385
                                      G30 P1 X69.28 Y-40.00 Z-99999 H33.385
                                      G30 P2 X-69.28 Y-40.00 Z-99999 H33.385
                                      G30 P3 X0.00 Y40.00 Z-99999 H33.385
                                      G30 P4 X34.64 Y-20.00 Z-99999 H33.385
                                      G30 P5 X-34.64 Y-20.00 Z-99999 H33.385
                                      G30 P6 X0 Y0 Z-99999 S6
                                      • Orang_undefined
                                        Orang_
                                        https://drive.google.com/file/d/17lobb0XFThtsjyVlk1SSF1ID_IGeao0-/view?usp=sharing
                                        • Orang_undefined
                                          Orang_
                                          it seems to be a problem with the firmware in particular rotary delta kinematics
                                            G1 F500 G0 F500
                                            That won't have any effect on the G30 moves. You'll need to do something like this.
                                            ; bed.g
                                            G28
                                            M566 X400 Y400 Z400       ; set maximum instantaneous speed changes (mm/min)
                                            M203 X6000 Y6000 Z6000    ; set maximum speeds (mm/min)
                                            M201 X400 Y400 Z400       ; set accelerations (mm/s^2)
                                            M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
                                            M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
                                            M201 X500.00 Y500.00 Z500.00 E1000.00       ; set accelerations (mm/s^2)
                                            You might also want to reduce the travel speed in M558
                                            M558 P5 C"^zstop" H5 F120 T1000
                                            hiccups 37
                                            That's much better
                                            Also, is your motor current set appropriately for your motors? 60-85% of rated max is the rule of thumb.
