Laser sensor calibration info
Filament Monitor
    Ladusse
    Hi I just installed my laser sensor and I don't now what I should for the ''R" value. here is my result.
    Thanks
      Have you seen?
      https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion
      undefined 1 Reply Last reply 13 Jan 2021, 15:44 Reply Quote 0
        Ladusse @Phaedrux
        @Phaedrux yes I seen it I don't understand the R value the minimum and maximum permitted measured movement as a percentage of commanded movement. As the example calibration reports 43% to 115% then you might choose R30:130.
        Why it choose R30:130 with the reports of 43% to 115%?
          alankilian
          The R value says:
          STOP the print if the measured filament amount is less than 30% of the commanded filament amount.
          STOP the print if the measured filament amount is more than 130% of the commanded filament amount.
          Since the filament sensor is not completely accurate, you need to set a range of acceptable values or your print will stop on almost every single extrusion.
          What I did is to set the range large like R10:500 then I did a print and looked at the result values and saw a range of something like 85% to 115% so I set my range to R50:150.
          undefined 1 Reply Last reply 13 Jan 2021, 16:27 Reply Quote 1
            Ladusse @alankilian
            @alankilian thanks for the explication it's now more clear.
            1 out of 5
