    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.1k
    • stuartofmtundefined
      stuartofmt @JohnOCFII
      @JohnOCFII
      I'll take a look in the morning but -- the basedir should be an absolute path without the trailing /
      e.g /home/pi/DLVideos
        stuartofmt
        Made some more changes:
        Here https://github.com/stuartofmt/DuetLapse
        Changed from print commands to logging option -logtype [console, file, both] default is both. If -logtype console then only written to the console. If -logtype file then a logfile is written to basedir with the name DuelLapse.log If -logtype both then written to the console and the logfile. Messages are prefixed by the ip address set by -duet. This is to distinguish between printers if multiple are used (see also -instances (below)
        added a switch for inhibiting multiple instances -instances [single, oneip, many] default is single. If -instances single then the highlander principle applies. If -instances oneip then only one instance per duet ip address (set by -duet ip address). If -instances many then it's the wild west.
          @JohnOCFII
          I took a look at the log - I think it's just the path. So try it with -basedir set as an full path i.e. with leading / and no trailing / as I suggested above.
          Also - as a side note - I saw your systemctl restarting the script. I'm not entirely sure why it would not have worked with the single instance being enforced but I changed the exit(x) commands (apparently more applicable for interactive use) to sys.exit(x). The documentation suggests the latter is better form ...
          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          • JohnOCFIIundefined
            JohnOCFII @stuartofmt
            @stuartofmt said in DuetLapse available for Alpha testing:
            @JohnOCFII
            I'll give the new version a shot. I'll change -basedir to /home/pi/DLVideos
            Thanks!
            stuartofmtundefined 1 Reply Last reply Reply Quote 0
              @JohnOCFII
              I just tried with 264 images - no problems creating the Video file.
              JohnOCFIIundefined 1 Reply Last reply Reply Quote 1
                @JohnOCFII
                Correcting the -basedir to full path fixed my issues. The "held frame" is working great.
                Not the fanciest timelapse, but shows the hold: https://youtu.be/LW6hV-MECns
                Thanks!
                  @JohnOCFII
                  Looks like you have a nice setup.
                  I'm looking at a couple of other tweaks (e.g. updating the Duet API calls to the newest style) and making the package a single python script rather than two. I am looking at incorporate a capability or two from the other forks.
                  When that is done - I think we can start another thread without the "alpha" description (DuetLapse2 ?). I suspect the "alpha' bit turns a few folks off.
                  Will post the changes when I am done.
                  P.S. Unrelated and from a small side project - I noticed that the mp4 output from ffmpeg (depending on settings) may not be compatible with iphone/ipad e.g if sent as a text or email attachment. Not sure if the output from DueatLapse has the same problem but will check. If it does I'll tweak accordingly.
                  • PCRundefined
                    PCR
                    @stuartofmt please add this https://github.com/jaysuk/DuetWebAPI to the Readme. The old one of Danal does not work anymore with Duet 3 + SBC
                      stuartofmt @PCR
                      @PCR
                      In the next few days (maybe a week) I will be working on this comment "I'm looking at a couple of other tweaks (e.g. updating the Duet API calls to the newest style) and making the package a single python script rather than two"
                      Specifically - updating the API calls to the newest Duet standard and doing away with the separate DuetWebAPI. It (the separate API has unneeded calls etc. and use the old API versions).
                      When done - it should be good to go for Duet # + SBC. As they say in the classics -- "Stay tuned" 🙂
                        stuartofmt
                        I have started a new thread with a new version of DuetLapse here:
                        https://forum.duet3d.com/topic/20932/duetlapse3
                        Partly because this thread is quite long and difficult to track through and also because the new version has a lot of modifications.
                        @PCR This should work fine with Duet 3+ SBC
                        • bothamichaelundefined
                          bothamichael
                          pi@duet3:~/DuetLapse $ python3 ./DuetLapse.py -camera web -weburl http://168.172.185.177:8888/videostream.cgi -duet 168.172.188.18 -seconds 20 -detect none
                          Attempting to connect to printer at 168.172.188.18
                          http://168.172.188.18 does not appear to be a RRF2 or RRF3 printer
                          Device at 168.172.188.18 either did not respond or is not a Duet V2 or V3 printer.
                          I am trying to start my timelapse. what could be the problem. not password on my deut3, can access from web browsers.
                          duet3 6HC + SBC
                            jay_s_uk @bothamichael
                            @bothamichael this version isn't maintained anymore. you need to use duetlapse3 instead
                            https://forum.duet3d.com/topic/20932/duetlapse3?_=1620132755569
