Duet2 wifi endstops not recognized on boot
M574 S0 is not correct. Should be S1.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
Please share your entire config.g as well as the results of sending M122 and M98 P"config.g"
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6J1F4-3SD6N-9TDYN
Used output buffers: 1 of 20 (7 max)
Static ram: 28380
Dynamic ram: 95672 of which 0 recycled
Exception stack ram used: 276
Never used ram: 6744
Task NETWORK ready, free stack 532
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3568
Last reset 00:00:36 ago, cause: power up
Last software reset at 2021-01-12 17:19, reason: User, spinning module GCodes, available RAM 6664 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 21.8, current 25.3, max 25.5
Supply voltage: min 14.7, current 14.8, max 14.9, under voltage events: 0, over voltage events: 0
Date/time: 2021-01-13 15:31:21
Slowest loop: 17.58ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is ready with "m122" in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 17.70ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi module is providing access point
WiFi firmware version 1.25
WiFi MAC address da:bf:c0:fb:5c:45
WiFi Vcc 3.31, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25792
WiFi IP address 10.10.10.10
Connected clients 1
=== Expansion ===
- WiFi -
Entire Config G
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 12 2021 15:48:42 GMT-0800 (PST); General preferences
M550 P"BigPrinter" ; set printer name; Network
M552 S2 ; enable access point
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes backwards
M350 X128 Y128 Z128 E16 I0 ; configure microstepping without interpolation
M92 X640.00 Y640.00 Z3200.00 E100.00 ; set steps per mm
M566 X500.00 Y500.00 Z6.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1200.00 E3000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X855 Y855 Z855 E855 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; set X limit switch
M574 Y1 S1 P"!ystop" ; set Y limit switch
M574 Z1 S1 P"!zstop" ; set Z limit switch; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X25:250 Y25:250 S20 ; define mesh grid; Heaters
M308 S0 P"bedheat" Y"thermistor T100000 B3988 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"ext1" Y"thermistor" T100000 B3988 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"ext1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M950 F0 C"fan0" Q25000 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: M308 command is not supported
Warning: M950 command is not supported
Warning: M950 command is not supported -
NEMA 17 steppers
FLSUN Metal setup used to use an MKS which worked okay
I can move the motors all fine and they go in the right directionI was able to get the thermistors to read the right values with the same setting but now they all say 2000 and the bed isn't showing up. When they worked the hot end worked fine as did the extruder I have provisioned (it has two - Bowden tube into cyclops - plan to set up later and with inductive bed leveling). However, the bed fuse blew as soon as I sent power.
Now the bed doesn't show up at all - maybe I need to replace the fuse? But I am using a Duet2 on my workbee cnc and it shows all the end stops and doesn't seem to care that there isn't a fuse in the bed.
Oh - and thanks so much for any help! You can see I already fixed the S0 to S1.
Also - the APS is set high to accommodate the larger bed.
@kto1243 said in Duet2 wifi endstops not recognized on boot:
So you are only using RRF 2.0, not 3.2 as you thought.
You must update the firmware first.
You will need to do 3 updates to get to 3.2
The updates should be pretty easy to do and will involve uploading 3 zip files. First download these files.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
Start by uploading the 2.05.1 file to the system tab in DWC. It should install and reboot. Then upload 3.0 and reboot, and finally 3.2 and reboot.
Then the syntax of your config.g will be correct.
Use M115 to verify your firmware versions.
Thanks - I actually figured it out by sending you all this stuff! I really appreciate your help.
Okay - on to next problem. Thermistors. Bed thermistor isn't registering. It is exactly the same as my hot end. Any ideas?
Last thing - I blew two bed fuses. I have the black wire closest to VIN and red furthest on the Bed. Is it possible that is backwards?
Thanks again for helping dumb me out! I do public policy for a living - learning electronics is my effort at brain expanding. This one has been a hoot!
Oh - one more dumb thing. When I upgraded from 3.0 to 3.2 the endstops disappeared from the webcontrol. They work, but I can't see their state under system/machine specific like I could in 3.0. Did I do something dumb?
Here is my current Config.g
M574 X1 S1 P"xstop" ; set X limit switch
M574 Y1 S1 P"ystop" ; set Y limit switch
M574 Z1 S1 P"zstop" ; set Z limit switch; Z-Probe
M308 S0 P"bedtemp" Y"thermistor T100000 B3888 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedtemp" T0 ; create bed heater output on bedheat and map it to sensor 0
M308 S1 P"e0temp" Y"thermistor" T100000 B3988 ; configure sensor 1 as thermistor on pin e0temp
They were removed from DWC 3.2 - they may be coming back in the future.
But for now you can see the state in the Object Model display that is in 3.2 under Settings.
Last thing - I blew two bed fuses. I have the black wire closest to VIN and red furthest on the Bed. Is it possible that is backwards?What does the temp of the bed show in the interface?
Which fuse exactly did you blow? The one on the duet or do you have an inline or something else?
Photo of your wiring?
Keep it up!
@Phaedrux The 15 amp fuse on the Duet between VIN and BED terminals.
I get an error message that says that the temp sensor is unknown. The thermistor is plugged into the pin right next to the BED terminal.
I will try to get a picture up tomorrow.
Thanks again for the help and encouragement!
