    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
    • oozeBotundefined
      oozeBot
      I wanted to post a few photos of a Halloween "torture test" we recently completed. This was printed in ABS, with no supports, using a 1.2mm nozzle. Extrusion width was 1.8mm and layer height was .4mm. It is 300mm deep x 264mm wide x 244mm high, was printed in ~17 hours, and weighs right at 3.5lbs.
      This was our first time using a 1.2mm nozzle and getting the retraction settings right to (mostly) control stringing was a challenge, but firmware retraction made the changes easy! There was some mid-air printing near the base, but that was in the design and it recovered beautifully..
      1 Reply Last reply Reply Quote 5
        That's an impressive ABS print. well done.
          T3P3Tony administrators
          yeah really nice!
          • oozeBotundefined
            oozeBot
            Timelapse of the Cthulhu build.. You'll see the mid-air printing near the base as well as the stringing that we mostly got under control by about mid-way through the print.
            https://vimeo.com/473997293
            • doublec4undefined
              doublec4
              Been following on instagram for a while now. Once this thing gets released I'm going to convince my work place to get one. We currently do not have a printer for ABS and this looks like it puts out great prints.
              oozeBotundefined 1 Reply Last reply Reply Quote 1
              • oozeBotundefined
                oozeBot @doublec4
                @doublec4 Fun fact - we don't even own any PLA or PETG! When I got into 3DP years back, I decided to go straight to ABS. But that will have to change soon for testing purposes..
                The ele^gant is the accumulation of everything we learned and yearned for over the years.. and we are finally close to making our vision a reality, but are about to go heads down on one last round of significant changes before calling version 1.0 complete. I'm excited to show what we have in store! We'll be starting the build of our final prototype within the next few weeks.
                • Vetiundefined
                  Veti @oozeBot
                  @oozeBot said in oozeBot ele^gant:
                  what about asa?
                  oozeBotundefined 1 Reply Last reply Reply Quote 0
                  • oozeBotundefined
                    oozeBot @Veti
                    @Veti Yes - we've been using ASA lately, but not for our printer parts. It behaves extremely similar to ABS with a much higher UV resistance. Anything I print for outdoor use is in ASA. I've also had good luck with ABS outdoors with a top coat of clear UV spray paint, but ASA makes that step unnecessary..
                    I'm a big fan of a thin coat of ABS slurry over a PEI sheet on our build plate. ASA sticks just as good as ABS using it, which makes it even easier. Plus you can finish the parts in an acetone vapor bath just the same as ABS.
                    Our go-to ABS is made by IC3D. They are finally making the move into ASA. We've received samples, but will be exploring using it more once it's generally available.
                    • oozeBotundefined
                      oozeBot
                      If you've followed along, our design uses a belt driven z-axis. Early designs incorporated a relay bank to act as a pseudo-brake. It worked, but not 100% and the concern for shorting out the Duet was significant.
                      So to resolve the issue once and for all, we worked with LDO to add an electromagnetic brake to our z-axis steppers. The samples just arrived this week and I finally had time to install them on a prototype. They work great! If Z is dropping at all when power is cut, I have not found a way to measure it.
                      Outside of our upcoming kits, these will be available in our parts store once it launches next year.
                      Haggan90undefined 1 Reply Last reply Reply Quote 2
                      • Haggan90undefined
                        Haggan90 @oozeBot
                        I would love to buy 3 of those! Where can I find them? 😃
                        • oozeBotundefined
                          oozeBot @Haggan90
                          @Haggan90 We may be the only ones out there with this design as I worked with LDO on the specs for it. Testing is near complete and we will be placing an order soon. This will be something we stock in our parts store as soon as it launches.
                          And FYI, they work great!
                          Haggan90undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • Haggan90undefined
                            Haggan90 @oozeBot
                            @oozeBot Ok!
                            I have a belt driven Z-axis as well, and a break like this would be great to have!
                            • DaBitundefined
                              DaBit
                              Another ABS/ASA fan here: really nice ABS prints!
                              You don't use chamber heating, right?
                              I might want to try that IC3D stuff too, so far I am unable to complete prints the size of your Ctulhu without layer splitting in either Prusament or Formfutura ASA or eSun ABS. in my enclosed printer.
                              • oozeBotundefined
                                oozeBot @DaBit
                                @DaBit said in oozeBot ele^gant:
                                Yes, our printers are all enclosed with chamber heaters. For ABS, we set the chamber temperature to 60c and never have delamination issues. The Cthulhu was a hard one as we really pushed the printer with a 1.2mm nozzle and 1.8mm extrusion width..
                                We are in process of printing the first parts for our release candidates. I'll be posting much more about them soon as they are considerably different than our prototypes. Here is one of the first parts off the printer! In ABS of course..
                                • fcwiltundefined
                                  fcwilt @oozeBot
                                  Interesting.
                                  On my recent belted Z axes conversion of my Mark Forged style printer I used three Z steppers with integral 5-to-1 planetary gear boxes.
                                  The bed stays put when power is cut. It doesn't seem to need any sort of brakes.
                                  • oozeBotundefined
                                    oozeBot @fcwilt
                                    @fcwilt we briefly evaluated geared steppers but went a different direction. With our solution, we were able to move the z-axis much faster than with a geared stepper allowing for considerably faster z-hops, etc.
                                    • fcwiltundefined
                                      fcwilt @oozeBot
                                      Interesting.
                                      I have no problem moving the bed at the needed speeds.
                                      But I see you appear to be moving the entire XY gantry - curious.
                                      Are you seeing any Z belt stretch as the center of mass of the gantry moves?
                                      • oozeBotundefined
                                        oozeBot @fcwilt
                                        @fcwilt We use 9mm fiberglass reinforced Gates 2GT belts and have not experienced any stretch or degraded performance throughout the gantry’s range of motion- and we have really been pushing our prototypes hard.
                                        • fcwiltundefined
                                          fcwilt @oozeBot
                                          Thanks for the info.
                                          • oozeBotundefined
                                            oozeBot
                                            We've been heads down for awhile now wrapping up the design for our release candidate.. and finally have something to show - our new gantry! It has been completely redesigned to be smaller, lighter, and stiffer than the prototypes.
                                            We are in love! Check out the belt work..
                                            fcwiltundefined 1 Reply Last reply Reply Quote 3
