    Set current to zero?
    805
    • tenajaundefined
      tenaja
      Is there a way to set the current to zero? The "idle current" command says it has a minimum of 100mA, and I would like to set it to zero so it can free-wheel.
      Thanks!
      garyd9undefined 1 Reply Last reply Reply Quote 0
      • tenajaundefined
        tenaja @Veti
        @Veti said in Set current to zero?:
        G92
        I did that, from the command line (top of DWC web page), and it did not work.
        Perhaps G92 after a M913?
        coming back after Duet restart (because it always loses connection)
        Yes!
        M913 Y100 does not turn power back on... It's still freewheeling after that....but the commands do work. (M913 then G92)
        Thanks, I'm back in business!
        Vetiundefined tenajaundefined dc42undefined 3 Replies Last reply Reply Quote 0
        • garyd9undefined
          garyd9 @tenaja
          @tenaja
          Some more context might be useful. For example, I'm taking a guess that you're referring to M906 as the "idle current command", but I'm not entirely sure.
          If you ARE referring to M906, please note the footnote to the "I" ("eye", not "el") parameter. I've added emphasis to the part that seems to relate to your query:
          This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30% and will always be at least 100mA - starting from RRF 2.02 setting it to 0 will disable the steppers after timeout like M18|M84 do and if an axis is related to the motor, throw out the "homing" of it, since it is likely that the position cannot be precisely determined anymore. Note that the idle current is applied globally for all motors and cannot be set per axis.
          Source: https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
          tenajaundefined 1 Reply Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt
            As I recall you can turn individual stepper drivers off with M84.
            • tenajaundefined
              tenaja @garyd9
              @garyd9 , Yes, that is what I meant. This is not an axis that is "homed"--it is rotary, which needs to freewheel at times. So, how do I do that? I'm getting a "axis not homed" error or something like that.
              Should I just issue a G92 to set it to zero right before I turn it back on?
              Thanks again!
              • tenajaundefined
                tenaja @fcwilt
                @fcwilt said in Set current to zero?:
                That did it, now I need to figure out how to "home" an axis that is not homed, and can not be homed.
                • Vetiundefined
                  Veti @tenaja
                  @tenaja said in Set current to zero?:
                  use G92 to set a position
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position
                  • tenajaundefined
                    tenaja @Veti
                    G92
                    Yes!
                    • Vetiundefined
                      Veti @tenaja
                      whats the exact G92 command you issued?
                      • tenajaundefined
                        tenaja @tenaja
                        I guess the only question left is how you cancel an M84 (Stop Idle Hold), without issuing a move command? Or to put it another way, how do you Resume Idle Hold?
                        • tenajaundefined
                          tenaja @Veti
                          G92 Y0
                          • fcwiltundefined
                            fcwilt @tenaja
                            What is the letter assigned to this axis and what G92 command did you issue?
                            Issuing a G1 command for that axis should turn the driver back on - is there some reason you cannot do that?
                            • Vetiundefined
                              Veti
                              I just tested it and the axis became homed
                              • tenajaundefined
                                tenaja @Veti
                                @Veti
                                Thanks, as I pointed out in Post #8, it does work if you put it in the gcode. But you have to do it in sequence, with the M913 first.
                                And, the motor does not have power, even though you issued an M913 Y100. ("Set motor percentage of normal current", to 100%)
                                • Vetiundefined
                                  Veti @tenaja
                                  @tenaja
                                  try a small movement G0 Y0.1 followed by G0 Y0
                                  • tenajaundefined
                                    tenaja @Veti
                                    @tenaja
                                    As expected, that will do it. It seems odd there's a way to power-down a motor, but not a "safe" way to power it back up. ("Safe" = no-motion).
                                    I would like to know how to restore it safely, for trivial/future reasons, but for my current application, my needs are met.
                                    I really appreciate all of the help provided.
                                      dc42 administrators @tenaja
                                      Any movement command will turn it back on. RRF 3.3 (for which we will soon release a beta) also supports M17 to turn on motor current.
                                      oozeBotundefined tenajaundefined 2 Replies Last reply Reply Quote 0
                                      • oozeBotundefined
                                        oozeBot @dc42
                                        @dc42 said in Set current to zero?:
                                        I'm very interested in testing this as I believe it will really help when releasing the stepper brake on our z-axis.. currently, we have to slightly move the z-axis to energize the steppers to keep the gantry from dropping.
                                        • tenajaundefined
                                          tenaja @dc42
                                          Thanks...
                                          Will a "relative" move of zero, like G1 Y0 do it? Or is physical motion the only way to get power back on?
                                            If you work out your step resolution you could have a move of exactly a single motor step.
                                              dc42 administrators @oozeBot
                                              @oozeBot said in Set current to zero?:
                                              I expect to provide an unofficial 3.3beta tomorrow.
